| #define | VTK_MODULE_USE_EXTERNAL_VTK_scn 0 |
| When using 'scn' in VTK, this header enables use to use either the scn version provided by VTK or an externally built version based on compile time flags. More... | |
| #define | VTK_SCN(header) <vtkscn/include/vtk##header> |
| #define VTK_MODULE_USE_EXTERNAL_VTK_scn 0 |
When using 'scn' include this header and then include any scn header you need as follows:
Note the clang-format sentinels are need avoid incorrect formatting the VTK_SCN macro call when using clang-format to format the code.
1.8.13 on Fri Aug 28 2026
