vtkSMVRInteractorStyleProxy.h
14 #ifndef vtkSMVRInteractorStyleProxy_h
15 #define vtkSMVRInteractorStyleProxy_h
16
17 #include "vtkCommand.h" // For UserEvent
18 #include "vtkPVIncubatorCAVEInteractionStylesModule.h" // for export macro
19 #include <vtkSMProxy.h>
20
21 #include <map>
22 #include <memory>
23 #include <string>
24 #include <vector>
25
26 class vtkCamera;
27 class vtkMatrix4x4;
28 class vtkPVXMLElement;
29 class vtkSMProxyLocator;
30 class vtkSMProxy;
33 class vtkStringList;
34 struct vtkVREvent;
35
36 class VTKPVINCUBATORCAVEINTERACTIONSTYLES_EXPORT vtkSMVRInteractorStyleProxy : public vtkSMProxy
37 {
38 public:
41  void PrintSelf(ostream& os, vtkIndent indent) override;
42
43  // Description:
44  // Get the vector size of the controlled property this style expects, e.g. a
45  // 4x4 matrix will be 16, a 3D vector will be 3, etc. This is used to limit
46  // the number of options presented to the user when prompting for a property.
47  // This is NOT checked internally by SetControlledPropertyName.
48  //
49  // A value of -1 means no filtering will be done, and all available properties
50  // will be shown.
51  virtual int GetControlledPropertySize() { return -1; }
52
53  virtual void SetControlledProxy(vtkSMProxy*);
54  vtkGetObjectMacro(ControlledProxy, vtkSMProxy);
55
56  vtkSetStringMacro(ControlledPropertyName);
57  vtkGetStringMacro(ControlledPropertyName);
58
59  // An internal interactor style proxy should not be shown in the
60  // UI, but can still be used by the CAVEInteraction plugin for
61  // internal purposes.
62  vtkSetMacro(IsInternal, bool);
63  vtkGetMacro(IsInternal, bool);
64  vtkBooleanMacro(IsInternal, bool);
65
66  virtual bool HandleEvent(const vtkVREvent& event);
67
72  virtual bool Update();
73
74  // Description:
75  // Get a list of defined roles for each output type.
76  void GetValuatorRoles(vtkStringList*);
77  void GetButtonRoles(vtkStringList*);
78  void GetTrackerRoles(vtkStringList*);
79
80  // Description:
81  // Get the number of roles defined for each output type.
82  int GetNumberOfValuatorRoles();
83  int GetNumberOfButtonRoles();
84  int GetNumberOfTrackerRoles();
85
86  // Description:
87  // Get the role of the input with the given name. If the name is not
88  // set or recognized, an empty string is returned.
89  std::string GetButtonRole(const std::string& name);
90  std::string GetTrackerRole(const std::string& name);
91
92  // Description:
93  // Valuators are special in that data from all channels is
94  // delivered in an array in a single event. This method allows
95  // finding that index for any named role which the user has
96  // bound to an event
97  unsigned int GetChannelIndexForValuatorRole(const std::string& role);
98
99  // Description:
100  // Add a new input role to the interactor style.
101  void AddValuatorRole(const std::string& role);
102  void AddButtonRole(const std::string& role);
103  void AddTrackerRole(const std::string& role);
104
105  void ClearAllRoles();
106
107  // Description:
108  // Set/Get the name of the input that fulfills the specified role.
109  bool SetValuatorName(const std::string& role, const std::string& name);
110  std::string GetValuatorName(const std::string& role);
111  bool SetButtonName(const std::string& role, const std::string& name);
112  std::string GetButtonName(const std::string& role);
113  bool SetTrackerName(const std::string& role, const std::string& name);
114  std::string GetTrackerName(const std::string& role);
115
117  virtual bool Configure(vtkPVXMLElement* child, vtkSMProxyLocator*);
118
120  virtual vtkPVXMLElement* SaveConfiguration();
121
122  enum
123  {
124  INTERACTOR_STYLE_REQUEST_CONFIGURE = vtkCommand::UserEvent + 7370,
125  INTERACTOR_STYLE_NAVIGATION = vtkCommand::UserEvent + 7371
126  };
127
128  // Description:
129  // Get active objects or return nullptr
130  static vtkSMRenderViewProxy* GetActiveViewProxy();
131  static vtkCamera* GetActiveCamera();
132
133  // Description:
134  // Get/Set the matrix used to navigate the scene. If no proxy argument
135  // is provided, the active view proxy will be used.
136  vtkMatrix4x4* GetNavigationMatrix(vtkSMRenderViewProxy* proxy = nullptr);
137  static void SetNavigationMatrix(vtkMatrix4x4*, vtkSMRenderViewProxy* proxy = nullptr);
138
139  // Description:
140  // Get/Set the scale of the navigation matrix, as an array of 3 doubles.
141  // If no proxy argument is provided, the active view proxy will be used.
142  static std::vector<double> GetNavigationScale(vtkSMRenderViewProxy* proxy = nullptr);
143  static void SetNavigationScale(
144  const std::vector<double>& scale, vtkSMRenderViewProxy* proxy = nullptr);
145
146  // Description:
147  // Update a matrix property on a proxy. If the proxy is a render view
148  // proxy and the property name is "ModelTransformMatrix", then internally
149  // the steps required for proper navigation are taken (inverting the matrix
150  // and storing it in the PhysicalToWorldMatrix, as well as invoking the
151  // navigation event).
152  void UpdateMatrixProperty(vtkSMProxy* proxy, const char* propertyName, vtkMatrix4x4* matrix);
153
154  typedef std::map<std::string, std::string> StringMap;
155  typedef std::map<std::string, StringMap> StringMapMap;
156
157  void SetValuatorLookupTable(std::shared_ptr<StringMapMap>);
158
159 protected:
161  virtual ~vtkSMVRInteractorStyleProxy();
162
163  virtual void HandleButton(const vtkVREvent& event);
164  virtual void HandleValuator(const vtkVREvent& event);
165  virtual void HandleTracker(const vtkVREvent& event);
166
168
172  virtual void SaveProxyProperties(vtkPVXMLElement* xml);
173  virtual bool LoadProxyProperties(vtkPVXMLElement* xml, vtkSMProxyLocator* locator);
175
176  static std::vector<std::string> Tokenize(std::string input);
177
180
181  StringMap Valuators;
182  StringMap Buttons;
183  StringMap Trackers;
184  void MapKeysToStringList(const StringMap& source, vtkStringList* target);
185  bool SetValueInMap(StringMap& map_, const std::string& key, const std::string& value);
186  std::string GetValueInMap(const StringMap& map_, const std::string& key);
187  std::string GetKeyInMap(const StringMap& map_, const std::string& value);
188
190
191  std::shared_ptr<StringMapMap> valuatorLookupTable;
192
193 private:
195  void operator=(const vtkSMVRInteractorStyleProxy&) = delete;
196
197  vtkNew<vtkMatrix4x4> NavigationMatrix;
198 };
199
200 #endif
the base class for all interactor styles
virtual void Update()
std::map< std::string, std::string > StringMap
name
implementation for View that includes render window and renderers.
property representing a vector of doubles
static vtkSMProxy * New()
Definition: vtkSMProxy.h:140
void operator=(const vtkSMProxy &)=delete
std::map< std::string, StringMap > StringMapMap
Manages allocation and freeing for a string list.
Definition: vtkStringList.h:20
std::shared_ptr< StringMapMap > valuatorLookupTable
