vtkSMMultiplexerSourceProxy.h
122 #ifndef vtkSMMultiplexerSourceProxy_h
123 #define vtkSMMultiplexerSourceProxy_h
124
125 #include "vtkRemotingServerManagerModule.h" //needed for exports
126 #include "vtkSMSourceProxy.h"
127 #include <memory> // for std::unique_ptr
128
130 class vtkSMInputProperty;
131
133 {
134 public:
137  void PrintSelf(ostream& os, vtkIndent indent) override;
138
140
146  int LoadXMLState(vtkPVXMLElement* element, vtkSMProxyLocator* locator) override;
147  void LoadState(const vtkSMMessage* msg, vtkSMProxyLocator* locator) override;
149
150 protected:
152  ~vtkSMMultiplexerSourceProxy() override;
153
154  void CreateVTKObjects() override;
155
157  vtkSMSessionProxyManager* pm, vtkPVXMLElement* element) override;
158
160  int IsInDomain(vtkSMInputProperty* property);
161
162  void Select(vtkSMProxy*);
163
164 private:
166  void operator=(const vtkSMMultiplexerSourceProxy&) = delete;
167
168  void CurateApplicableProxies();
169  void SetupSubProxies();
170
171  void SetupSubProxy(vtkSMProxy* proxy);
172
173  class vtkInternals;
174  std::unique_ptr<vtkInternals> Internals;
175 };
176
177 #endif
vtkPVXMLElement * SaveXMLState(vtkPVXMLElement *root, vtkSMPropertyIterator *iter) override
Overridden to handle selections.
virtual int CreateSubProxiesAndProperties(vtkSMSessionProxyManager *pm, vtkPVXMLElement *element)
input domain used for vtkSMMultiplexerSourceProxy
Call superclass&#39; and then assigns a new executive (vtkCompositeDataPipeline)
int LoadXMLState(vtkPVXMLElement *element, vtkSMProxyLocator *locator) override
int IsInDomain(vtkSMProperty *property) override
proxy for a VTK source on a server
The vtkSMSessionProxyManager is esponsible for creating and managing proxies for a given session...
void LoadState(const vtkSMMessage *msg, vtkSMProxyLocator *locator) override
This method is used to initialise the object to the given state If the definitionOnly Flag is set to ...
Definition: vtkSMProxy.h:140
vtkSMProxyInternals * Internals
Definition: vtkSMProxy.h:1029
virtual vtkPVXMLElement * SaveXMLState(vtkPVXMLElement *root)
Saves the state of the proxy.
static vtkSMSourceProxy * New()
iterates over the properties of a proxy
proxy representing inputs to a filter
