vtkSMDataTypeQueryDomain.h
33 #ifndef vtkSMDataTypeQueryDomain_h
34 #define vtkSMDataTypeQueryDomain_h
35
36 #include "vtkRemotingServerManagerModule.h" //needed for exports
37 #include "vtkSMDomain.h"
38
40 {
41 public:
42  static vtkSMDataTypeQueryDomain* New();
44  void PrintSelf(ostream& os, vtkIndent indent) override;
45
50  int IsInDomain(vtkSMProperty* property) override;
51
56  void Update(vtkSMProperty*) override;
57
61  int SetDefaultValues(vtkSMProperty* prop, bool use_unchecked_values) override;
62
63 protected:
65  ~vtkSMDataTypeQueryDomain() override;
66
67 private:
69  void operator=(const vtkSMDataTypeQueryDomain&) = delete;
70
71  int InputDataType = -1;
72
73  void OnDomainModified();
74 };
75
76 #endif // vtkSMDataTypeQueryDomain_h
virtual void Update(vtkSMProperty *requestingProperty)
Update self based on the "unchecked" values of all required properties.
virtual int SetDefaultValues(vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
Definition: vtkSMDomain.h:92
represents the possible values a property can have
Definition: vtkSMDomain.h:38
virtual int IsInDomain(vtkSMProperty *vtkNotUsed(property))
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes.
Definition: vtkSMDomain.h:65
A domain for getting the input data type and setting it.
static vtkSMDomain * New()
