vtkSMDataAssemblyDomain.h
112 #ifndef vtkSMDataAssemblyDomain_h
113 #define vtkSMDataAssemblyDomain_h
114
115 #include "vtkRemotingServerManagerModule.h" // needed for exports
116 #include "vtkSMDomain.h"
117 #include "vtkSmartPointer.h" // needed for vtkSmartPointer
118
119 #include <string> // for std::string
120
121 class vtkDataAssembly;
123 {
124 public:
125  static vtkSMDataAssemblyDomain* New();
127  void PrintSelf(ostream& os, vtkIndent indent) override;
128
132  const char* GetDataAssemblyName() const
133  {
134  return this->Name.empty() ? nullptr : this->Name.c_str();
135  }
136
140  vtkDataAssembly* GetDataAssembly() const;
141
142  void Update(vtkSMProperty* requestingProperty) override;
143
144  enum Modes
145  {
146  ALL = 0,
147  LEAVES = 1,
148  };
149
151
156  vtkGetMacro(Mode, int);
158
159  int SetDefaultValues(vtkSMProperty* prop, bool use_unchecked_values) override;
160
161 protected:
163  ~vtkSMDataAssemblyDomain() override;
164
165 private:
167  void operator=(const vtkSMDataAssemblyDomain&) = delete;
168
169  void ChooseAssembly(const std::string& name, vtkDataAssembly* assembly);
170  void FetchAssembly(int tag);
171
177  int ReadXMLAttributes(vtkSMProperty* prop, vtkPVXMLElement* element) override;
178
179  void OnDomainModified();
180
181  int LastTag = 0;
182
184  std::string AssemblyXMLContents;
185  std::string Name;
186  int EntityType = -1;
187  int Mode = ALL;
188 };
189
190 #endif
virtual void Update(vtkSMProperty *requestingProperty)
Update self based on the "unchecked" values of all required properties.
virtual int SetDefaultValues(vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
Definition: vtkSMDomain.h:92
represents the possible values a property can have
Definition: vtkSMDomain.h:38
virtual int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *elem)
const char * GetDataAssemblyName() const
Returns the name for the chosen assembly, if any.
a domain that uses vtkDataAssembly
static vtkSMDomain * New()
