10 #ifndef vtkSIDoubleMapProperty_h 11 #define vtkSIDoubleMapProperty_h 26 vtkGetStringMacro(CleanCommand);
27 vtkSetStringMacro(CleanCommand);
Map property that manage double value to be set through a method on a vtkObject.
unsigned int NumberOfComponents
static vtkSIProperty * New()
virtual bool Push(vtkSMMessage *, int)
vtkSIProxy is the server-implementation for a vtkSMProxy that helps the vtkSMProxy with managing/upda...
#define PARAVIEW_DEPRECATED_IN_6_3_0(reason)
virtual bool ReadXMLAttributes(vtkSIProxy *proxyhelper, vtkPVXMLElement *element)
Parse the xml for the property.
Basic ServerImplementation property used to call a method with no argument on a VTK object...
