vtkImageSliceRepresentation.h
13 #ifndef vtkImageSliceRepresentation_h
14 #define vtkImageSliceRepresentation_h
15
16 #include "vtkNew.h" // for vtkNew.
18 #include "vtkRemotingViewsModule.h" //needed for exports
19 #include "vtkStructuredData.h" // for VTK_*_PLANE
20
21 class vtkImageData;
23 class vtkPVLODActor;
24 class vtkScalarsToColors;
25
27 {
28 public:
31  void PrintSelf(ostream& os, vtkIndent indent) override;
32
35
40  int idx, int port, int connection, int fieldAssociation, const char* name) override;
42  int idx, int port, int connection, int fieldAssociation, int fieldAttributeType) override
43  {
45  idx, port, connection, fieldAssociation, fieldAttributeType);
46  }
47  void SetInputArrayToProcess(int idx, vtkInformation* info) override
48  {
49  this->Superclass::SetInputArrayToProcess(idx, info);
50  }
51  void SetInputArrayToProcess(int idx, int port, int connection, const char* fieldAssociation,
52  const char* attributeTypeorName) override
53  {
55  idx, port, connection, fieldAssociation, attributeTypeorName);
56  }
58
66  vtkInformation* outInfo) override;
67
73  void SetVisibility(bool val) override;
74
76
79  virtual void SetSlice(unsigned int);
80  vtkGetMacro(Slice, unsigned int);
82
83  enum
84  {
85  XY_PLANE = vtkStructuredData::VTK_STRUCTURED_XY_PLANE,
86  YZ_PLANE = vtkStructuredData::VTK_STRUCTURED_YZ_PLANE,
87  XZ_PLANE = vtkStructuredData::VTK_STRUCTURED_XZ_PLANE
88  };
89
91
94  virtual void SetSliceMode(int);
95  vtkGetMacro(SliceMode, int);
97
98  //---------------------------------------------------------------------------
99  // Forwarded to Actor.
100  void SetOrientation(double, double, double);
101  void SetOrigin(double, double, double);
102  void SetPickable(int val);
103  void SetPosition(double, double, double);
104  void SetScale(double, double, double);
105  virtual void SetCoordinateSystem(int);
106
107  //---------------------------------------------------------------------------
108  // Forwarded to vtkProperty.
109  void SetOpacity(double val);
110
111  //---------------------------------------------------------------------------
112  // Forwarded to vtkPVImageSliceMapper.
113  void SetLookupTable(vtkScalarsToColors* val);
114  void SetMapScalars(int val);
115  void SetUseXYPlane(int val);
116
120  vtkPVLODActor* GetActor() { return this->Actor; }
121
122 protected:
124  ~vtkImageSliceRepresentation() override;
125
129  void UpdateSliceData(vtkInformationVector**);
130
134  int FillInputPortInformation(int port, vtkInformation* info) override;
135
147
153  bool AddToView(vtkView* view) override;
154
160  bool RemoveFromView(vtkView* view) override;
161
163  unsigned int Slice;
164
168
169  // meta-data about the input image to pass on to render view for hints
170  // when redistributing data.
171  double WholeBounds[6];
172
173 private:
175  void operator=(const vtkImageSliceRepresentation&) = delete;
176 };
177
178 #endif
void SetInputArrayToProcess(int idx, vtkInformation *info) override
Set the input data arrays that this algorithm will process.
vtkPVDataRepresentation adds some ParaView specific API to data representations.
bool AddToView(vtkView *view) override
Making these methods public.
info
virtual void SetVisibility(bool val)
virtual int ProcessViewRequest(vtkInformationRequestKey *request_type, vtkInformation *inInfo, vtkInformation *outInfo)
virtual void SetInputArrayToProcess(int idx, int port, int connection, int fieldAssociation, const char *name)
virtual int FillInputPortInformation(int port, vtkInformation *info)
int RequestData(vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
Overridden to invoke vtkCommand::UpdateDataEvent.
void SetInputArrayToProcess(int idx, int port, int connection, int fieldAssociation, int fieldAttributeType) override
Mapper for vtkImageData that renders the image using a texture applied to a quad. ...
representation for showing slices from a vtkImageData.
bool RemoveFromView(vtkView *view) override
static vtkDataRepresentation * New()
an actor that supports multiple levels of detail
Definition: vtkPVLODActor.h:25
void SetInputArrayToProcess(int idx, int port, int connection, const char *fieldAssociation, const char *attributeTypeorName) override
vtkPVLODActor * GetActor()
Provides access to the actor used by this representation.
port
