1 # TODO: Split these up and put them in the conditional which actually requires 3 ExternalData_Expand_Arguments(ParaViewData _
4 "DATA{${paraview_test_data_directory_input}/Data/,REGEX:tensors_.*\\.vti}" 5 "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/,REGEX:.*}" 6 "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00000/,REGEX:.*}" 7 "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00000/Level_0/,REGEX:.*}" 8 "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00000/particles/,REGEX:.*}" 9 "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00000/particles/Level_0/,REGEX:.*}" 10 "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00005/,REGEX:.*}" 11 "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00005/Level_0/,REGEX:.*}" 12 "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00005/particles/,REGEX:.*}" 13 "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00005/particles/Level_0/,REGEX:.*}" 14 "DATA{${paraview_test_data_directory_input}/Data/AxisAlignedSliceBackwardCompat.pvsm}" 15 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00000.temp/,REGEX:.*}" 16 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00000.temp/Level_0/,REGEX:.*}" 17 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00010.temp/,REGEX:.*}" 18 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00010.temp/Level_0/,REGEX:.*}" 19 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00020.temp/,REGEX:.*}" 20 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00020.temp/Level_0/,REGEX:.*}" 21 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00030.temp/,REGEX:.*}" 22 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00030.temp/Level_0/,REGEX:.*}" 23 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00040.temp/,REGEX:.*}" 24 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00040.temp/Level_0/,REGEX:.*}" 25 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00050.temp/,REGEX:.*}" 26 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00050.temp/Level_0/,REGEX:.*}" 27 "DATA{${paraview_test_data_directory_input}/Data/paraview_icon.svg}" 28 "DATA{${paraview_test_data_directory_input}/Data/3GQP.pdb}" 29 "DATA{${paraview_test_data_directory_input}/Data/bake/bake.e}" 30 "DATA{${paraview_test_data_directory_input}/Data/CameraWidgetViewLinkState.pvsm}" 31 "DATA{${paraview_test_data_directory_input}/Data/can-restarts/,REGEX:.*}" 32 "DATA{${paraview_test_data_directory_input}/Data/CellDataWithNan.vtu}" 33 "DATA{${paraview_test_data_directory_input}/Data/cloud_layers_1k.jpg}" 34 "DATA{${paraview_test_data_directory_input}/Data/CompositeGlyphInput.vtp}" 35 "DATA{${paraview_test_data_directory_input}/Data/CompositeGlyphTree/,REGEX:.*}" 36 "DATA{${paraview_test_data_directory_input}/Data/CompositeGlyphTree.vtm}" 37 "DATA{${paraview_test_data_directory_input}/Data/ConfigureCategories.xml}" 38 "DATA{${paraview_test_data_directory_input}/Data/convergecfd_post_5016_spray.h5}" 39 "DATA{${paraview_test_data_directory_input}/Data/cth.vtr}" 40 "DATA{${paraview_test_data_directory_input}/Data/cube_1ts_mod.e}" 41 "DATA{${paraview_test_data_directory_input}/Data/CubeStringArray.vtk}" 42 "DATA{${paraview_test_data_directory_input}/Data/EnSight/,REGEX:.*}" 43 "DATA{${paraview_test_data_directory_input}/Data/ExRestarts/,REGEX:.*}" 44 "DATA{${paraview_test_data_directory_input}/Data/FDS/test_core/,REGEX:.*}" 45 "DATA{${paraview_test_data_directory_input}/Data/FieldDataBlocks/,REGEX:.*}" 46 "DATA{${paraview_test_data_directory_input}/Data/FieldDataBlocks/FieldDataBlocks/,REGEX:.*}" 47 "DATA{${paraview_test_data_directory_input}/Data/FileSeries/,REGEX:.*}" 48 "DATA{${paraview_test_data_directory_input}/Data/FileListPropertyWidgetPlugin.xml}" 49 "DATA{${paraview_test_data_directory_input}/Data/GenericIOReader/,REGEX:.*}" 50 "DATA{${paraview_test_data_directory_input}/Data/HeadMRVolume.mhd}" 51 "DATA{${paraview_test_data_directory_input}/Data/HeadMRVolume.raw}" 52 "DATA{${paraview_test_data_directory_input}/Data/hdf_fpm_simulation.erfh5}" 53 "DATA{${paraview_test_data_directory_input}/Data/half_sphere_commented.csv}" 54 "DATA{${paraview_test_data_directory_input}/Data/Iron_Xdmf/,REGEX:.*}" 55 "DATA{${paraview_test_data_directory_input}/Data/LoadState.pvsm}" 56 "DATA{${paraview_test_data_directory_input}/Data/LoadStateDialog.pvsm}" 57 "DATA{${paraview_test_data_directory_input}/Data/LoadStateTextSourceRepresentation.pvsm}" 58 "DATA{${paraview_test_data_directory_input}/Data/MinimalTensors.vtu}" 59 "DATA{${paraview_test_data_directory_input}/Data/MultiBlockWithPieces.vtm}" 60 "DATA{${paraview_test_data_directory_input}/Data/MultiBlockWithPieces_0_0.vtp}" 61 "DATA{${paraview_test_data_directory_input}/Data/MultiBlockWithPieces_1_0.vtp}" 62 "DATA{${paraview_test_data_directory_input}/Data/NE2_ps_bath.png}" 63 "DATA{${paraview_test_data_directory_input}/Data/OMETIFF/multi-channel-time-series.ome.tif}" 64 "DATA{${paraview_test_data_directory_input}/Data/OverridePropertyPlugin.xml}" 65 "DATA{${paraview_test_data_directory_input}/Data/PlotOverLineLegacy.pvsm}" 66 "DATA{${paraview_test_data_directory_input}/Data/PLOAD_C_xMax.bdf}" 67 "DATA{${paraview_test_data_directory_input}/Data/PNGReadersPlugin.xml}" 68 "DATA{${paraview_test_data_directory_input}/Data/PropertyLink.pvsm}" 69 "DATA{${paraview_test_data_directory_input}/Data/ReaderNamePlugin.xml}" 70 "DATA{${paraview_test_data_directory_input}/Data/RectGrid2.vtk}" 71 "DATA{${paraview_test_data_directory_input}/Data/RodPlate/,REGEX:.*}" 72 "DATA{${paraview_test_data_directory_input}/Data/SLAC/pic-example/,REGEX:.*}" 73 "DATA{${paraview_test_data_directory_input}/Data/SPCTH/,REGEX:.*}" 74 "DATA{${paraview_test_data_directory_input}/Data/SPCTH/Dave_Karelitz_Small/,REGEX:.*}" 75 "DATA{${paraview_test_data_directory_input}/Data/SPCTH/DerivedDensity/,REGEX:.*}" 76 "DATA{${paraview_test_data_directory_input}/Data/Scenario1_p1.h5}" 77 "DATA{${paraview_test_data_directory_input}/Data/Scenario1_p1.xmf}" 78 "DATA{${paraview_test_data_directory_input}/Data/Test1.h5}" 79 "DATA{${paraview_test_data_directory_input}/Data/Test1.xmf}" 80 "DATA{${paraview_test_data_directory_input}/Data/TestCompositePropertyWidgetDecoratorPlugin.xml}" 81 "DATA{${paraview_test_data_directory_input}/Data/TestMultipleNumberOfComponentsPlugin.xml}" 82 "DATA{${paraview_test_data_directory_input}/Data/VisItBridge/,REGEX:.*}" 83 "DATA{${paraview_test_data_directory_input}/Data/VisItBridge/chombo_hdf5_series/,REGEX:.*}" 84 "DATA{${paraview_test_data_directory_input}/Data/nek5000/eddy_uv/,REGEX:.*}" 85 "DATA{${paraview_test_data_directory_input}/Data/amr/,REGEX:.*}" 86 "DATA{${paraview_test_data_directory_input}/Data/amr/wavelet/,REGEX:.*}" 87 "DATA{${paraview_test_data_directory_input}/Data/amr/amr_rg/,REGEX:.*}" 88 "DATA{${paraview_test_data_directory_input}/Data/amr/amr_ug/,REGEX:.*}" 89 "DATA{${paraview_test_data_directory_input}/Data/amr/noamr_rg/,REGEX:.*}" 90 "DATA{${paraview_test_data_directory_input}/Data/amr/noamr_ug/,REGEX:.*}" 91 "DATA{${paraview_test_data_directory_input}/Data/artifact.dta}" 92 "DATA{${paraview_test_data_directory_input}/Data/amr_gaussian_pulse.vtkhdf}" 93 "DATA{${paraview_test_data_directory_input}/Data/blow.vtk}" 94 "DATA{${paraview_test_data_directory_input}/Data/blow_data.myvtk}" 95 "DATA{${paraview_test_data_directory_input}/Data/bluntfin.vts}" 96 "DATA{${paraview_test_data_directory_input}/Data/BoxWithFaceData.cgns}" 97 "DATA{${paraview_test_data_directory_input}/Data/can.ex2}" 98 "DATA{${paraview_test_data_directory_input}/Data/can.e.4/can.e.4.0}" 99 "DATA{${paraview_test_data_directory_input}/Data/can.e.4/can.e.4.1}" 100 "DATA{${paraview_test_data_directory_input}/Data/can.e.4/can.e.4.2}" 101 "DATA{${paraview_test_data_directory_input}/Data/can.e.4/can.e.4.3}" 102 "DATA{${paraview_test_data_directory_input}/Data/cavity/,REGEX:.*}" 103 "DATA{${paraview_test_data_directory_input}/Data/cavity/system/,RECURSE:,REGEX:.*}" 104 "DATA{${paraview_test_data_directory_input}/Data/cavity/constant/,RECURSE:,REGEX:.*}" 105 "DATA{${paraview_test_data_directory_input}/Data/cavity/0/,RECURSE:,REGEX:.*}" 106 "DATA{${paraview_test_data_directory_input}/Data/cavity/0.5/,RECURSE:,REGEX:.*}" 107 "DATA{${paraview_test_data_directory_input}/Data/cavity/1/,RECURSE:,REGEX:.*}" 108 "DATA{${paraview_test_data_directory_input}/Data/cavity/1.5/,RECURSE:,REGEX:.*}" 109 "DATA{${paraview_test_data_directory_input}/Data/cavity/2/,RECURSE:,REGEX:.*}" 110 "DATA{${paraview_test_data_directory_input}/Data/cavity/2.5/,RECURSE:,REGEX:.*}" 111 "DATA{${paraview_test_data_directory_input}/Data/cgns_np01/,REGEX:.*}" 112 "DATA{${paraview_test_data_directory_input}/Data/cgns_np04/,REGEX:.*}" 113 "DATA{${paraview_test_data_directory_input}/Data/bc_struct.cgns}" 114 "DATA{${paraview_test_data_directory_input}/Data/comb.q}" 115 "DATA{${paraview_test_data_directory_input}/Data/combxyz.bin}" 116 "DATA{${paraview_test_data_directory_input}/Data/cow.vtp}" 117 "DATA{${paraview_test_data_directory_input}/Data/cth.vtr}" 118 "DATA{${paraview_test_data_directory_input}/Data/cube.off}" 119 "DATA{${paraview_test_data_directory_input}/Data/cube.vtu}" 120 "DATA{${paraview_test_data_directory_input}/Data/cylinder_run1.e}" 121 "DATA{${paraview_test_data_directory_input}/Data/cylinder_run2.e}" 122 "DATA{${paraview_test_data_directory_input}/Data/disk_out_ref.ex2}" 123 "DATA{${paraview_test_data_directory_input}/Data/dualSphereAnimation.clone.pvd}" 124 "DATA{${paraview_test_data_directory_input}/Data/dualSphereAnimation.pvd}" 125 "DATA{${paraview_test_data_directory_input}/Data/dualSphereAnimation/,REGEX:.*}" 126 "DATA{${paraview_test_data_directory_input}/Data/dualSphereAnimation4.pvd}" 127 "DATA{${paraview_test_data_directory_input}/Data/DynamicComponentsPlugin.py}" 128 "DATA{${paraview_test_data_directory_input}/Data/elements.vtu}" 129 "DATA{${paraview_test_data_directory_input}/Data/EngineSector.cgns}" 130 "DATA{${paraview_test_data_directory_input}/Data/ensemble-wavelet/,REGEX:.*}" 131 "DATA{${paraview_test_data_directory_input}/Data/Fides/cartesian-attr.bp}" 132 "DATA{${paraview_test_data_directory_input}/Data/Fides/cartesian-attr.bp.dir/,REGEX:.*}" 133 "DATA{${paraview_test_data_directory_input}/Data/Fides/tris-blocks-time-attr.bp}" 134 "DATA{${paraview_test_data_directory_input}/Data/Fides/tris-blocks-time-attr.bp.dir/,REGEX:.*}" 135 "DATA{${paraview_test_data_directory_input}/Data/field.vtk}" 136 "DATA{${paraview_test_data_directory_input}/Data/filters.xml}" 137 "DATA{${paraview_test_data_directory_input}/Data/glTF/AnimatedMorphCube/,REGEX:.*}" 138 "DATA{${paraview_test_data_directory_input}/Data/glTF/BoxAnimated/,REGEX:.*}" 139 "DATA{${paraview_test_data_directory_input}/Data/glTF/InterpolationTest/,REGEX:.*}" 140 "DATA{${paraview_test_data_directory_input}/Data/glTF/NestedRings/NestedRings.glb}" 141 "DATA{${paraview_test_data_directory_input}/Data/glTF/Triangle/Triangle.glb}" 142 "DATA{${paraview_test_data_directory_input}/Data/glTF/SimpleSkin/SimpleSkin.gltf}" 143 "DATA{${paraview_test_data_directory_input}/Data/glTF/WaterBottle/WaterBottle.glb}" 144 "DATA{${paraview_test_data_directory_input}/Data/HTG/binary_3D_333_mask.htg}" 145 "DATA{${paraview_test_data_directory_input}/Data/HTG/donut_XZ_shift_2d.htg}" 146 "DATA{${paraview_test_data_directory_input}/Data/HTG/ghost.htg}" 147 "DATA{${paraview_test_data_directory_input}/Data/HTG2Dims.htg}" 148 "DATA{${paraview_test_data_directory_input}/Data/HTGCellCentersBackwardCompat.pvsm}" 149 "DATA{${paraview_test_data_directory_input}/Data/HTGFeatureEdgesBackwardCompat.pvsm}" 150 "DATA{${paraview_test_data_directory_input}/Data/HTGGhostCellsGeneratorBackwardCompat.pvsm}" 151 "DATA{${paraview_test_data_directory_input}/Data/HTGReflectionBackwardCompat.pvsm}" 152 "DATA{${paraview_test_data_directory_input}/Data/HTGVisibleLeavesSizeBackwardCompat.pvsm}" 153 "DATA{${paraview_test_data_directory_input}/Data/HTGMulti.vtm}" 154 "DATA{${paraview_test_data_directory_input}/Data/HTGMulti/HTGMulti_0_0.htg}" 155 "DATA{${paraview_test_data_directory_input}/Data/HTGMulti/HTGMulti_1_0.htg}" 156 "DATA{${paraview_test_data_directory_input}/Data/htg_multiblock.vtm}" 157 "DATA{${paraview_test_data_directory_input}/Data/htg_multiblock/htg_multiblock_0_0.htg}" 158 "DATA{${paraview_test_data_directory_input}/Data/htg_multiblock/htg_multiblock_2_0.htg}" 159 "DATA{${paraview_test_data_directory_input}/Data/HTGMultiBlockDistributed.vtkhdf}" 160 "DATA{${paraview_test_data_directory_input}/Data/HTGMultiBlockDistributed_part0.vtkhdf}" 161 "DATA{${paraview_test_data_directory_input}/Data/HTGMultiBlockDistributed_part1.vtkhdf}" 162 "DATA{${paraview_test_data_directory_input}/Data/HTGMultiBlockDistributed_part2.vtkhdf}" 163 "DATA{${paraview_test_data_directory_input}/Data/HTGMultiBlockDistributed_part3.vtkhdf}" 164 "DATA{${paraview_test_data_directory_input}/Data/HTG_PDC.vtkhdf}" 165 "DATA{${paraview_test_data_directory_input}/Data/HTG_PDC_part0.vtkhdf}" 166 "DATA{${paraview_test_data_directory_input}/Data/HTG_PDC_part1.vtkhdf}" 167 "DATA{${paraview_test_data_directory_input}/Data/HTG_PDC_part2.vtkhdf}" 168 "DATA{${paraview_test_data_directory_input}/Data/HTG_PDC_part3.vtkhdf}" 169 "DATA{${paraview_test_data_directory_input}/Data/ReflectBackwardCompat.pvsm}" 170 "DATA{${paraview_test_data_directory_input}/Data/WaveletGradientLegacy.pvsm}" 171 "DATA{${paraview_test_data_directory_input}/Data/img1.png}" 172 "DATA{${paraview_test_data_directory_input}/Data/img1.mypng}" 173 "DATA{${paraview_test_data_directory_input}/Data/img2.png}" 174 "DATA{${paraview_test_data_directory_input}/Data/iron_protein.vtk}" 175 "DATA{${paraview_test_data_directory_input}/Data/linesPolydata.vtk}" 176 "DATA{${paraview_test_data_directory_input}/Data/LogoSource.png}" 177 "DATA{${paraview_test_data_directory_input}/Data/manyTypes.vtu}" 178 "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces.vtm}" 179 "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces/pvi_Material_Remap2_0005_0_0.vtu}" 180 "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces/pvi_Material_Remap2_0005_0_1.vtu}" 181 "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces/pvi_Material_Remap2_0005_1_0.vtu}" 182 "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces/pvi_Material_Remap2_0005_1_1.vtu}" 183 "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces/pvi_Material_Remap2_0005_2_0.vtu}" 184 "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces/pvi_Material_Remap2_0005_2_1.vtu}" 185 "DATA{${paraview_test_data_directory_input}/Data/mg_diff_0062.vtm}" 186 "DATA{${paraview_test_data_directory_input}/Data/mg_diff_0062/,REGEX:.*}" 187 "DATA{${paraview_test_data_directory_input}/Data/multicomb_0.vts}" 188 "DATA{${paraview_test_data_directory_input}/Data/multicomb_1.vts}" 189 "DATA{${paraview_test_data_directory_input}/Data/multicomb_2.vts}" 190 "DATA{${paraview_test_data_directory_input}/Data/MultiPiece.vtm}" 191 "DATA{${paraview_test_data_directory_input}/Data/MultiPiece/Piece1.vts}" 192 "DATA{${paraview_test_data_directory_input}/Data/MultiPiece/Piece2.vts}" 193 "DATA{${paraview_test_data_directory_input}/Data/MultiPiece/Piece3.vts}" 194 "DATA{${paraview_test_data_directory_input}/Data/MultiPiece/Piece4.vts}" 195 "DATA{${paraview_test_data_directory_input}/Data/MultiPiece/Piece5.vts}" 196 "DATA{${paraview_test_data_directory_input}/Data/MultiPiece/Piece6.vts}" 197 "DATA{${paraview_test_data_directory_input}/Data/non_convex_polygon.vtu}" 198 "DATA{${paraview_test_data_directory_input}/Data/office.binary.vtk}" 199 "DATA{${paraview_test_data_directory_input}/Data/owave-hole.exdg}" 200 "DATA{${paraview_test_data_directory_input}/Data/OMF/test_file.omf}" 201 "DATA{${paraview_test_data_directory_input}/Data/OSPRayMaterials/materials.json}" 202 "DATA{${paraview_test_data_directory_input}/Data/pbrSpheres.vtp}" 203 "DATA{${paraview_test_data_directory_input}/Data/pbrSpheresAlbedo.jpg}" 204 "DATA{${paraview_test_data_directory_input}/Data/pbrSpheresORM.jpg}" 205 "DATA{${paraview_test_data_directory_input}/Data/pointSet.vtk}" 206 "DATA{${paraview_test_data_directory_input}/Data/ParaView_Mark.png}" 207 "DATA{${paraview_test_data_directory_input}/Data/ParaView_Logo.png}" 208 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_0_0.vtp}" 209 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_1_0.vtp}" 210 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_2_0.vtp}" 211 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_3_0.vtp}" 212 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_4_0.vtp}" 213 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_5_0.vtp}" 214 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_6_0.vtp}" 215 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_7_0.vtp}" 216 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_8_0.vtp}" 217 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_9_0.vtp}" 218 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_10_0.vtp}" 219 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_11_0.vtp}" 220 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_12_0.vtp}" 221 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_13_0.vtp}" 222 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_14_0.vtp}" 223 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData.vtm}" 224 "DATA{${paraview_test_data_directory_input}/Data/PolarAxesDeprecation.pvsm}" 225 "DATA{${paraview_test_data_directory_input}/Data/porphyrin.cml}" 226 "DATA{${paraview_test_data_directory_input}/Data/ProcessIdScalarsBackwardCompat.pvsm}" 227 "DATA{${paraview_test_data_directory_input}/Data/quadraticTetra01.vtu}" 228 "DATA{${paraview_test_data_directory_input}/Data/quadratic_tets_with_ghost_cells.pvtu}" 229 "DATA{${paraview_test_data_directory_input}/Data/quadratic_tets_with_ghost_cells_0.vtu}" 230 "DATA{${paraview_test_data_directory_input}/Data/quadratic_tets_with_ghost_cells_1.vtu}" 231 "DATA{${paraview_test_data_directory_input}/Data/random_torus.vtp}" 232 "DATA{${paraview_test_data_directory_input}/Data/raw2DImageBackwardCompat.pvsm}" 233 "DATA{${paraview_test_data_directory_input}/Data/raw3DImageBackwardCompat.pvsm}" 234 "DATA{${paraview_test_data_directory_input}/Data/room.cas}" 235 "DATA{${paraview_test_data_directory_input}/Data/room.dat}" 236 "DATA{${paraview_test_data_directory_input}/Data/room.cas.h5}" 237 "DATA{${paraview_test_data_directory_input}/Data/room.dat.h5}" 238 "DATA{${paraview_test_data_directory_input}/Data/sample.h5part}" 239 "DATA{${paraview_test_data_directory_input}/Data/servers-wiki.pvsc}" 240 "DATA{${paraview_test_data_directory_input}/Data/Udirectory/coneScript.py}" 241 "DATA{${paraview_test_data_directory_input}/Data/Udirectory/simpleScript.py}" 242 "DATA{${paraview_test_data_directory_input}/Data/Udirectory/LinkRenderViewsCheckSize.py}" 243 "DATA{${paraview_test_data_directory_input}/Data/Udirectory/resetSession.py}" 244 "DATA{${paraview_test_data_directory_input}/Data/rectilinear_grid_of_pixel.vtr}" 245 "DATA{${paraview_test_data_directory_input}/Data/sineWaves.csv}" 246 "DATA{${paraview_test_data_directory_input}/Data/singleSphereAnimation.pvd}" 247 "DATA{${paraview_test_data_directory_input}/Data/singleSphereAnimation/,REGEX:.*}" 248 "DATA{${paraview_test_data_directory_input}/Data/spiaggia_di_mondello_1k.hdr}" 249 "DATA{${paraview_test_data_directory_input}/Data/SliceDeprecation.pvsm}" 250 "DATA{${paraview_test_data_directory_input}/Data/SteeringDataGeneratorPlugin.xml}" 251 "DATA{${paraview_test_data_directory_input}/Data/squareBend/,REGEX:.*}" 252 "DATA{${paraview_test_data_directory_input}/Data/squareBend/system/,RECURSE:,REGEX:.*}" 253 "DATA{${paraview_test_data_directory_input}/Data/squareBend/constant/,RECURSE:,REGEX:.*}" 254 "DATA{${paraview_test_data_directory_input}/Data/squareBend/50/,RECURSE:,REGEX:.*}" 255 "DATA{${paraview_test_data_directory_input}/Data/squareBend/100/,RECURSE:,REGEX:.*}" 256 "DATA{${paraview_test_data_directory_input}/Data/sphere.stl}" 257 "DATA{${paraview_test_data_directory_input}/Data/tensors.pvti}" 258 "DATA{${paraview_test_data_directory_input}/Data/test_fielddata.vtk}" 259 "DATA{${paraview_test_data_directory_input}/Data/test_transient_poly_data.vtkhdf}" 260 "DATA{${paraview_test_data_directory_input}/Data/testxmlpartdscol/,REGEX:.*}" 261 "DATA{${paraview_test_data_directory_input}/Data/testxmlpartdscol.vtpc}" 262 "DATA{${paraview_test_data_directory_input}/Data/testxmlpartds/,REGEX:.*}" 263 "DATA{${paraview_test_data_directory_input}/Data/testxmlpartds.vtpd}" 264 "DATA{${paraview_test_data_directory_input}/Data/time_source.pvsm}" 265 "DATA{${paraview_test_data_directory_input}/Data/timestep_0_15.vts}" 266 "DATA{${paraview_test_data_directory_input}/Data/todd2_small/todd2_htg.pio}" 267 "DATA{${paraview_test_data_directory_input}/Data/todd2_small/todd2_ug.pio}" 268 "DATA{${paraview_test_data_directory_input}/Data/todd2_small/dumps/3D_nomix_diff-dmp000000}" 269 "DATA{${paraview_test_data_directory_input}/Data/todd2_small/dumps/3D_nomix_diff-dmp000010}" 270 "DATA{${paraview_test_data_directory_input}/Data/tube.exo}" 271 "DATA{${paraview_test_data_directory_input}/Data/Unbalanced3DepthOctTree3x2x3.htg}" 272 "DATA{${paraview_test_data_directory_input}/Data/vehicle_data.csv}" 273 "DATA{${paraview_test_data_directory_input}/Data/viscoplastic-ring.h5}" 274 "DATA{${paraview_test_data_directory_input}/Data/vtkHDF/pdc_multi.vtkhdf}" 275 "DATA{${paraview_test_data_directory_input}/Data/vtkHDF/sph4_mb.vtkhdf}" 276 "DATA{${paraview_test_data_directory_input}/Data/vtkHDF/sph4_mb_part0.vtkhdf}" 277 "DATA{${paraview_test_data_directory_input}/Data/vtkHDF/sph4_mb_part1.vtkhdf}" 278 "DATA{${paraview_test_data_directory_input}/Data/vtkHDF/sph4_mb_part2.vtkhdf}" 279 "DATA{${paraview_test_data_directory_input}/Data/vtkHDF/sph4_mb_part3.vtkhdf}" 280 "DATA{${paraview_test_data_directory_input}/Data/waveletElevation.vti}" 281 "DATA{${paraview_test_data_directory_input}/Data/waveletNamedMaterials.vti}" 282 "DATA{${paraview_test_data_directory_input}/Data/WaveletThresholdLegacy.pvsm}" 283 "DATA{${paraview_test_data_directory_input}/Data/WorldWithTexture.png}" 284 "DATA{${paraview_test_data_directory_input}/Data/x_ray_copy_1.json}" 285 "DATA{${paraview_test_data_directory_input}/Data/x_ray_copy_2.json}" 286 "DATA{${paraview_test_data_directory_input}/Data/YoungsMaterialInterface/youngs.vtm}" 287 "DATA{${paraview_test_data_directory_input}/Data/YoungsMaterialInterface/youngs/youngs_0.vtu}" 288 "DATA{${paraview_test_data_directory_input}/Data/YoungsMaterialInterface/youngs/youngs_1.vtu}" 289 "DATA{${paraview_test_data_directory_input}/Data/ugrid.nc}" 290 "DATA{${paraview_test_data_directory_input}/Data/UnstructuredGridWithTwoAdjacentHexahedraOfDifferentOrder.vtu}" 291 "DATA{${paraview_test_data_directory_input}/Data/DecimatePolyline.vtp}" 294 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AMRAxisAlignedSlice_A.png}" 295 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AAXAxis.png}" 296 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AAYAxis.png}" 297 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AAZAxis.png}" 298 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AnisotropyPBR.png}" 299 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid_A.png}" 300 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid_B.png}" 301 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid_C.png}" 302 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid_D.png}" 303 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid_E.png}" 304 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid_F.png}" 305 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid_G.png}" 306 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid_H.png}" 307 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid_I.png}" 308 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxisAlignedCutterPDCNoHierarchy.png}" 309 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxisAlignedCutterPDCNoHierarchy_1.png}" 310 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxisAlignedCutterPDCNoHierarchyYAxis.png}" 311 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxisAlignedCutterPDCNoHierarchyYAxis_1.png}" 312 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxisAlignedCutterMBHierarchy.png}" 313 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxisAlignedCutterMBHierarchy_1.png}" 314 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxisAlignedCutterMBHierarchyYAxis.png}" 315 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxisAlignedCutterMBHierarchyYAxis_1.png}" 316 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxisAlignedReflect.png}" 317 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BatchAxesGrid.png}" 318 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-bake-HideOneBlock.png}" 319 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-bake-HideTwoBlocks.png}" 320 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-bake-ShowAllBlocks.png}" 321 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-bake-ShowOneBlock.png}" 322 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-bake-ShowZeroBlock.png}" 323 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-BlockOpacity.png}" 324 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-ShowAllBlocks.png}" 325 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-ShowOnlyBlock.png}" 326 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-UnsetBlockOpacity.png}" 327 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockLinkedSelection-MB.png}" 328 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockLinkedSelection-MBWithPieces.png}" 329 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockLinkedSelection-PDC.png}" 330 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockLinkedSelection-PDC_1.png}" 331 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BoxWidget-Transform.png}" 332 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BoxWidget-ClipDefault.png}" 333 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BoxWidget-ClipCheckUseReferenceBounds.png}" 334 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BoxWidget-ClipUncheckUseReferenceBounds.png}" 335 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CalculatorQuotedVariable1.png}" 336 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CalculatorQuotedVariable2.png}" 337 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CameraLink-Parallel.png}" 338 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CameraLink-Parallel_1.png}" 339 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CameraLink-Perspective.png}" 340 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CameraLink-Perspective_1.png}" 341 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CategoricalAutomaticAnnotationsInterA.png}" 342 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CategoricalAutomaticAnnotationsInterB.png}" 343 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CategoricalAutomaticAnnotationsInterC.png}" 344 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CategoricalAutomaticAnnotationsInterD.png}" 345 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CategoriesWithNaN.png}" 346 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CellGridRenderView-Surface.png}" 347 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CellGridRenderView-AllCorners.png}" 348 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CellGridRenderView-AllEdges.png}" 349 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CellGridRenderView-SurfaceWithEdges.png}" 350 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CellGridRenderView-SurfaceWithEdgesAndVertices.png}" 351 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CGNSReaderCellMesh.png}" 352 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CGNSReaderFaceMesh.png}" 353 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsA.png}" 354 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsB.png}" 355 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsC.png}" 356 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsD.png}" 357 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsE.png}" 358 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsF.png}" 359 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsG.png}" 360 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsH.png}" 361 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartDefaultSettings_A.png}" 362 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartDefaultSettings_B.png}" 363 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartLoadNoVariablesA.png}" 364 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartLoadNoVariablesA_1.png}" 365 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartLoadNoVariablesA_2.png}" 366 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartLoadNoVariablesB.png}" 367 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartsClearSelection.png}" 368 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ClampAndUpdateColorMap-TS12-Clamped.png}" 369 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ClampAndUpdateColorMap-TS12-Unchanged.png}" 370 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ClampAndUpdateColorMap-TS6.png}" 371 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorBy.png}" 372 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorByDynamicComponent1.png}" 373 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorByDynamicComponent2.png}" 374 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityEditorFreehandDrawing.png}" 375 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityEditorFreehandDrawing_A.png}" 376 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityEditorRangeHandles.png}" 377 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityEditorRangeHandles_A.png}" 378 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityEditorRangeHandles_B.png}" 379 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_A.png}" 380 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_B.png}" 381 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_C.png}" 382 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_D.png}" 383 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_E.png}" 384 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_F.png}" 385 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_G.png}" 386 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_M.png}" 387 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_R.png}" 388 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_T.png}" 389 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_U.png}" 390 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_V.png}" 391 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorLegendBackground.png}" 392 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorLegendScaledScreenshot.png}" 393 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ComputeNormalInRepresentation-Default.png}" 394 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ComputeNormalInRepresentation-SurfaceEdgesRepr.png}" 395 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ComputeNormalInRepresentation-WithAngle.png}" 396 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ConnectivityCountAscending.png}" 397 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ConnectivityCountDescending.png}" 398 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Contour1.png}" 399 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Contour2.png}" 400 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Contour3.png}" 401 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Contour3_1.png}" 402 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Contour3_2.png}" 403 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ContourRange_A.png}" 404 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ContourRange_B.png}" 405 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ContourCellData.png}" 406 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CONVERGECFDCGNSReader.png}" 407 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CONVERGECFDReaderMesh.png}" 408 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CONVERGECFDReaderMesh_1.png}" 409 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CONVERGECFDReaderParcels.png}" 410 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CONVERGECFDReaderParcels_1.png}" 411 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ConvertToMoleculeBonds.png}" 412 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CriticalTimeBetweenX.png}" 413 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CriticalTimeBetweenZ.png}" 414 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CriticalTimeLowerMagnitude.png}" 415 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CriticalTimeUpperMagnitude.png}" 416 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CustomTCoords.png}" 417 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CustomViewpoints.png}" 418 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CustomViewpoints_A.png}" 419 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CustomViewpoints_B.png}" 420 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DataAxesGrid2X.png}" 421 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DataAxesGrid-Custom.png}" 422 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DataAxesGrid-CustomWithReset.png}" 423 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DataAxesGrid-IgnoreScaling.png}" 424 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DecimatePolylineAngle.png}" 425 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DecimatePolylineCustomFieldHigh.png}" 426 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DecimatePolylineCustomFieldLow.png}" 427 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DecimatePolylineDistance.png}" 428 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DataDimDefaultAxesPoint.png}" 429 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DataDimDefaultAxesLineX.png}" 430 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DataDimDefaultAxesLineX_1.png}" 431 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DataDimDefaultAxesLineY.png}" 432 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DataDimDefaultAxesLineY_1.png}" 433 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DeleteSubtreePipelineBrowser0.png}" 434 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DeleteSubtreePipelineBrowser1.png}" 435 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DeleteSubtreePipelineBrowser2.png}" 436 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EdgeTintPBR.png}" 437 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EDLWithSubsampling.png}" 438 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EDLWithSubsampling_1.png}" 439 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EllipseSource1.png}" 440 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EllipseSource2.png}" 441 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EllipseSource3.png}" 442 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EnsembleT0.png}" 443 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EnsembleT1.png}" 444 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EnsembleT3.png}" 445 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EqualizeLayoutA.png}" 446 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EqualizeLayoutB.png}" 447 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExpandSelection_A.png}" 448 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExpandSelection_B.png}" 449 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExtractSubsetWithSeed.png}" 450 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExtractSubsetWithSeed_1.png}" 451 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExtractSubsetWithSeed_2.png}" 452 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExtractSubsetWithSeed_3.png}" 453 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExodusModeShapes_A.png}" 454 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExodusModeShapes_B.png}" 455 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EyeDomeLighting.png}" 456 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FastUniformGridSource1.png}" 457 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FastUniformGridSource2.png}" 458 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FastUniformGridSource3.png}" 459 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FastUniformGridSource4.png}" 460 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FeatureEdgesFilterHTG.png}" 461 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FeatureEdgesHTG.png}" 462 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FeatureEdgesHTGNoMask.png}" 463 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FeatureEdgesNonlinearCells.png}" 464 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FeatureEdgesRepresentationHTG.png}" 465 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FidesReader_cartesian.png}" 466 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FidesReader_blocks.png}" 467 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FidesWriter.png}" 468 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FileSeries1.png}" 469 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FileSeries2.png}" 470 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataTrace.png}" 471 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Cell-GlobalElementId-is.png}" 472 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Cell-GlobalElementId-oneof.png}" 473 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Cell-GlobalElementId-range.png}" 474 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Cell-ID-is.png}" 475 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Cell-ID-min-max-per-block.png}" 476 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-ge.png}" 477 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-ge-mean.png}" 478 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-le.png}" 479 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-le-mean.png}" 480 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-max.png}" 481 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-mean.png}" 482 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-min.png}" 483 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-MultipleQueries.png}" 484 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataSelectLocation.png}" 485 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataSelectLocationMultiblock.png}" 486 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataDialogNaN.png}" 487 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FreezeQueryMultiblock.png}" 488 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ForceTimeDiamond.png}" 489 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFImporterNestedRings.png}" 490 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFImporterWaterBottle.png}" 491 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderTriangle.png}" 492 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderAnimatedMorphing.png}" 493 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderAnimatedMorphing_IsLoaded.png}" 494 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderMultipleScenes_IsLoaded.png}" 495 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderMultipleScenes_SceneOne.png}" 496 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderMultipleScenes.png}" 497 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderMultipleAnimations_IsLoaded.png}" 498 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderMultipleAnimations_ThreeAnimations.png}" 499 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderMultipleAnimations.png}" 500 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderToggleDeformation_IsLoaded.png}" 501 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderToggleDeformation_IsSkinned.png}" 502 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderToggleDeformation.png}" 503 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostCellsGeneratorImageDistributed.png}" 504 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostCellsGeneratorImageSerial.png}" 505 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostCellsHTGMultiblock_Empty.png}" 506 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostCellsHTGMultiblock_ProcessIds.png}" 507 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe1.png}" 508 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe2.png}" 509 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe3.png}" 510 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe4.png}" 511 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe5.png}" 512 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe6.png}" 513 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe7.png}" 514 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe8.png}" 515 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe9.png}" 516 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe10.png}" 517 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Glyph3DRepresentation_Cylinder.png}" 518 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Glyph3DRepresentation_Cylinder_1.png}" 519 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GlyphWithEmptyCells_A.png}" 520 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GlyphWithEmptyCells_B.png}" 521 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GlyphWithEmptyCells_C.png}" 522 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection1.png}" 523 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection1_1.png}" 524 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection2.png}" 525 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection2_1.png}" 526 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection3.png}" 527 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection4.png}" 528 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection4_1.png}" 529 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HTGCompositeDistributed.png}" 530 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGrid2DGeometryFillMaterial_Filled.png}" 531 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGrid2DGeometryFillMaterial_Lines.png}" 532 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridAxisClip1-Plane.png}" 533 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridAxisClip2-RevPlane.png}" 534 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridAxisClip3-Box.png}" 535 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridAxisCut.png}" 536 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridAxisReflection.png}" 537 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridCellCenters.png}" 538 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridContour.png}" 539 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridContourStrategyA.png}" 540 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridContourStrategyA_1.png}" 541 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridContourStrategyB.png}" 542 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridContourStrategyB_1.png}" 543 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridDataAndPolarAxes_Data.png}" 544 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridDataAndPolarAxes_Polar.png}" 545 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridDepthLimiter.png}" 546 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridEvaluateCoarse.png}" 547 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridEvaluateCoarse_1.png}" 548 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridExtractGhostCells.png}" 549 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridGeometry.png}" 550 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridGradient.png}" 551 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridMultiBlock.png}" 552 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridMultipleClip.png}" 553 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridObliquePlaneCutter.png}" 554 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridPlaneCutter.png}" 555 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridSourceDistributedA.png}" 556 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridSourceDistributedB.png}" 557 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridSurfaceMultiBlockSelectionA.png}" 558 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridSurfaceMultiBlockSelectionB.png}" 559 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridSurfaceMultiBlockSelectionC.png}" 560 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridSurfaceMultiBlockSelectionD.png}" 561 #
"DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridThreshold.png}" 562 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridThreshold-DepthOne.png}" 563 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridThreshold-DepthTwo.png}" 564 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/IndexedLookupInitialization.png}" 565 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/IndexedLookupInitialization_1.png}" 566 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LightAddRemove1.png}" 567 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LightAddRemove2.png}" 568 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LightWidget.png}" 569 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LightToolbar.png}" 570 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LineChartSelection1.png}" 571 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LineChartSelection2.png}" 572 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LineChartSelection3.png}" 573 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LineChartSelection4.png}" 574 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LinkCameraFromView.png}" 575 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LinkCameraFromView_A.png}" 576 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LinkCameraFromView_A_1.png}" 577 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LinkCameraFromView_B.png}" 578 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LinkViewsLinked.png}" 579 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LoadStateMultiView.png}" 580 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap1.png}" 581 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap2.png}" 582 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap3.png}" 583 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap4.png}" 584 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap5.png}" 585 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap6.png}" 586 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap7.png}" 587 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMapToggle1.png}" 588 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMapToggle2.png}" 589 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogoSource.png}" 590 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogoSourceDefault.png}" 591 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogoSourcesInChartViews.png}" 592 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MatchBoundariesIgnoringCellOrder.png}" 593 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorCreateMaterials1.png}" 594 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorCreateMaterials2.png}" 595 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorLoadMaterials1.png}" 596 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorLoadMaterials2.png}" 597 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorSaveMaterials1.png}" 598 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorSaveMaterials2.png}" 599 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorSaveMaterials3.png}" 600 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorShaderBallScene1.png}" 601 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorShaderBallScene2.png}" 602 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorShaderBallScene3.png}" 603 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MathTextColumn.png}" 604 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MergePointBlocks.png}" 605 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MergeVectorComponents.png}" 606 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MeshCacheBlockColorsOverTime.png}" 607 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MeshCacheCompositeIndexOverTime.png}" 608 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Molecule-BallStick.png}" 609 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Molecule-Custom.png}" 610 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Molecule-Liquorice.png}" 611 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockChartSelectionPlotView.png}" 612 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockChartSelectionRenderView.png}" 613 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorMultiBlock.png}" 614 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties.png}" 615 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_A.png}" 616 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_B.png}" 617 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_C.png}" 618 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_D.png}" 619 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_E.png}" 620 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_F.png}" 621 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_G.png}" 622 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_H.png}" 623 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_I.png}" 624 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_J.png}" 625 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_K.png}" 626 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorSelection-SelectBlock2.png}" 627 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorSelection-SelectElementBlocks.png}" 628 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorSelection-HideBlock1.png}" 629 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorWithoutSelectOnClickSetting.png}" 630 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultipleColorOnSelectionA.png}" 631 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NestedViews.png}" 632 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NestedViews_1.png}" 633 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NetCDFUGRID.png}" 634 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision0Display.png}" 635 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision0Display_1.png}" 636 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision1Display.png}" 637 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision1Display_1.png}" 638 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision2Display.png}" 639 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision2Display_1.png}" 640 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision3Display.png}" 641 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision3Display_1.png}" 642 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision4Display.png}" 643 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision4Display_1.png}" 644 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EmptyInitialCompositeReader.png}" 645 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/OBBMajorAxis.png}" 646 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/OBBMediumAxis.png}" 647 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/OBBMinorAxis.png}" 648 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/OffsetSliceWithPlane.png}" 649 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/OMFReader.png}" 650 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/OpacityWidgetRange.png}" 651 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ParallelCoordinatesView.png}" 652 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ParallelCoordinatesView_1.png}" 653 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PartitionedDataSet_Slice.png}" 654 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PartitionedDataSet_Slice_1.png}" 655 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PartitionedDataSet_Slice_2.png}" 656 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PartitionedDataSet_Slice_3.png}" 657 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PartitionedDataSet_Surface.png}" 658 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PartitionedDataSetCollection_Slice.png}" 659 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PartitionedDataSetCollection_Slice_1.png}" 660 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PartitionedDataSetCollection_Slice_2.png}" 661 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PartitionedDataSetCollection_Slice_3.png}" 662 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PartitionedDataSetCollection_Surface.png}" 663 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PBRSpheres.png}" 664 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PickCenter.png}" 665 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PickCenter_Vertex.png}" 666 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PLYWriter.png}" 667 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteBlackBackground.png}" 668 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteBlueGrayBackground.png}" 669 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteGradientBackground.png}" 670 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteLightGrayBackground.png}" 671 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteNeutralGrayBackground.png}" 672 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteWarmGrayBackground.png}" 673 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteDarkGrayBackground.png}" 674 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteWhiteBackground.png}" 675 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PlotOverLine_Boundary.png}" 676 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PlotOverLine_Center.png}" 677 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PlotOverLine_Uniform.png}" 678 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PointDataSetInterpolator_SourceData.png}" 679 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PointGaussianScaleOpacityArrayA.png}" 680 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PointGaussianScaleOpacityArrayA.png}" 681 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PolarAxes1.png}" 682 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PolarAxes2.png}" 683 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PolarAxes3.png}" 684 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Preview-SingleView.png}" 685 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Preview-AllViews.png}" 686 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PythonAlgorithmPlugin.png}" 687 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PythonAlgorithmReadersAndWriters.png}" 688 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PythonShellRunScript.png}" 689 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PVCellCentersHyperTreeGrid.png}" 690 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/QuartilePlotArea.png}" 691 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/QuartilePlotArea_1.png}" 692 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/QuartilePlotLines.png}" 693 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RandomAttributesHTGScalars.png}" 694 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RandomAttributesHTGVectors.png}" 695 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RandomHyperTreeGridSourceA.png}" 696 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RandomHyperTreeGridSourceB.png}" 697 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadPartitionedCGNS_BCOnly.png}" 698 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadPartitionedCGNS_BCOnlyBlockColors.png}" 699 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadPartitionedCGNS_CellData.png}" 700 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadPartitionedCGNS_LoadPatches.png}" 701 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadPartitionedCGNS_PointData.png}" 702 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadCGNSBCDataset.png}" 703 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadIOHDFFileSeries0.png}" 704 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadIOHDFFileSeries1.png}" 705 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadIOHDFFileSeries2.png}" 706 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadIOHDFWithCache0.png}" 707 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadIOHDFWithCache1.png}" 708 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadIOHDFWithCache2.png}" 709 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadFLUENTCFFFormat.png}" 710 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RectilinearVolumeRendering.png}" 711 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReloadAMReXGrid-AfterReload.png}" 712 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReloadAMReXGrid-BeforeReload.png}" 713 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReloadExodusFile-AfterReload.png}" 714 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReloadExodusFile-BeforeReload.png}" 715 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RemoteRenderingSurface.png}" 716 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RemoteRenderingSurface_1.png}" 717 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RemoteRenderingSurface_2.png}" 718 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RemoteRenderingVolume.png}" 719 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RenderNanDefaultColor.png}" 720 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RenderNanGUIColor.png}" 721 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RenderNanPresetColor.png}" 722 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RenderViewContextMenuArrayColoring.png}" 723 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RenderViewContextMenuSolidColoring.png}" 724 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleToHyperTreeGridBranching_3.png}" 725 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleImageToHyperTreeGrid.png}" 726 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleToHyperTreeGrid2DX.png}" 727 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleToHyperTreeGrid2DY.png}" 728 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleToHyperTreeGrid2DZ.png}" 729 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleToLine.png}" 730 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleWithDataset_A.png}" 731 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleWithDataset_B.png}" 732 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleWithDataset_C.png}" 733 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleWithDataset_D.png}" 734 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetSession.png}" 735 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeA.png}" 736 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeA_1.png}" 737 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeB.png}" 738 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeC.png}" 739 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeC_1.png}" 740 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeC_2.png}" 741 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeD.png}" 742 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeE.png}" 743 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreArrayDefaultTransferFunctionA.png}" 744 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreArrayDefaultTransferFunctionB.png}" 745 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreArrayDefaultTransferFunctionC.png}" 746 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreArrayDefaultTransferFunctionC_1.png}" 747 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreDefaultTransferFunctionA.png}" 748 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreDefaultTransferFunctionB.png}" 749 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreDefaultTransferFunctionC.png}" 750 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReverseLegend_A.png}" 751 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReverseLegend_B.png}" 752 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RotateAroundOriginTransform.png}" 753 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerA.png}" 754 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerB.png}" 755 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerC.png}" 756 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerD.png}" 757 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SaveLargeScreenshot.png}" 758 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SaveLargeScreenshot_1.png}" 759 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SaveSmallScreenshot.png}" 760 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SaveSmallScreenshot_1.png}" 761 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar1.png}" 762 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar2.png}" 763 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar3.png}" 764 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar4.png}" 765 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar5.png}" 766 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar6.png}" 767 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar7.png}" 768 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar8.png}" 769 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectCellsFrustumTrace.png}" 770 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectCellsInteractiveTrace.png}" 771 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectCellsTrace.png}" 772 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectColorMapFromComboBox_A.png}" 773 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectionByArray.png}" 774 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectionEditor.png}" 775 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectionLinkParallelCoordinatesView.png}" 776 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectionLinkScriptingA.png}" 777 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectionLinkScriptingB.png}" 778 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectPointsFrustumTrace.png}" 779 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectPointsInteractiveTrace.png}" 780 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectPointsTrace.png}" 781 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeparatedColorMapA.png}" 782 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeparatedColorMapB.png}" 783 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeparateOpacityArray_X.png}" 784 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeparateOpacityArray_Y.png}" 785 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeparateOpacityArray_Z.png}" 786 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeparateOpacityArray_Magnitude.png}" 787 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeriesPreset.png}" 788 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeriesPresetRegexpNoRegexp.png}" 789 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeriesPresetRegexpYD.png}" 790 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeriesPresetRegexp.png}" 791 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ShowMultiPieceFieldData.png}" 792 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SkyboxRotation_A.png}" 793 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SkyboxRotation_B.png}" 794 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SkyboxRotation_C.png}" 795 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SkyboxRotation_D.png}" 796 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Slice.png}" 797 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SliceDirectDoubleColoring.png}" 798 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SliceRepresentation.png}" 799 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SliceWithPlaneCellData.png}" 800 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SliceWithPlaneMultiBlock.png}" 801 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SliceWithPlane.png}" 802 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SpherePointSource_InterA.png}" 803 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SpherePointSource_InterB.png}" 804 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SplitViewTraceScreenshot.png}" 805 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SSAO.png}" 806 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SteeringDataGeneratorA.png}" 807 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SteeringDataGeneratorB.png}" 808 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SteeringDataGeneratorC.png}" 809 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/StepColorSpaceA.png}" 810 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/StructuredGridCellBlanking.png}" 811 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/StructuredGridVolumeRendering.png}" 812 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TableFFT1.png}" 813 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TableFFT2.png}" 814 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TemporalSmoothingHalfWidthSmall.png}" 815 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TemporalSmoothingHalfWidthLarge.png}" 816 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestAnnotateSelectionFilter.png}" 817 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCAVE-tile0.png}" 818 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCAVE-tile1.png}" 819 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCAVEVolRen-tile0.png}" 820 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCAVEVolRen-tile1.png}" 821 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCAVE2DAnnotations-tile0.png}" 822 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCAVE2DAnnotations-tile1.png}" 823 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCleanGridPointDataStrategies_0.png}" 824 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCleanGridPointDataStrategies_1.png}" 825 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCleanGridPointDataStrategies_2.png}" 826 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestColorMapModificationRendersAllViews.png}" 827 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestClipCylinder.png}" 828 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestColorHistogram.png}" 829 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCompositedGeometryCulling.png}" 830 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestGeometryBoundsClobber.png}" 831 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestERFReader.png}" 832 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t0_boundaries_cc.png}" 833 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t0_boundaries.png}" 834 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t0_slice_cc.png}" 835 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t0_slice.png}" 836 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t8_boundaries_cc.png}" 837 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t8_boundaries.png}" 838 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t8_slice_cc.png}" 839 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t8_slice.png}" 840 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestHTGSelection_A.png}" 841 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestHTGSelection_A_1.png}" 842 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestHTGSelection_B.png}" 843 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestHTGSelection_C.png}" 844 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestHTGSelection_D.png}" 845 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestHTGThreshold.png}" 846 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestHTGThreshold_1.png}" 847 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestIndependentViewers-tile0.png}" 848 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestIndependentViewers-tile1.png}" 849 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestIsoVolume1.png}" 850 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestIsoVolume2.png}" 851 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestIsoVolume3.png}" 852 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestIsoVolume4.png}" 853 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestIsoVolume5.png}" 854 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestLineChartLabelPrefix.png}" 855 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestMultiServer1.png}" 856 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestMultiServer2.png}" 857 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestMultiServer3.png}" 858 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestMultiServer4.png}" 859 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestOFFReader.png}" 860 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestParallelProjectionAnnotations-Off.png}" 861 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestPreviewTextScale.png}" 862 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestPreviewTextScale_A.png}" 863 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestPythonView.png}" 864 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestPythonView_1.png}" 865 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestPythonViewScript.png}" 866 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestResampleHyperTreeGridWithSphere.png}" 867 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TextSourceBorder.png}" 868 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TextSourceInteriorLines.png}" 869 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TextSourcesInChartViews.png}" 870 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TextSourcesInChartViews2.png}" 871 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TextSourcesInChartViews3.png}" 872 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Threshold.png}" 873 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdAllComponents.png}" 874 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdAnyComponent.png}" 875 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdInvert.png}" 876 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdSelectedComponentX.png}" 877 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdSelectedComponentY.png}" 878 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdSelectedComponentZ.png}" 879 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdSelectedMagnitude.png}" 880 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-1x1-tile0.png}" 881 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-2x1-tile0.png}" 882 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-2x1-tile1.png}" 883 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-2x2-tile0.png}" 884 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-2x2-tile1.png}" 885 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-2x2-tile2.png}" 886 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-2x2-tile3.png}" 887 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-3x1-tile0.png}" 888 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-3x1-tile1.png}" 889 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-3x1-tile2.png}" 890 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TimeStepProgressBar_Inter.png}" 891 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ToneMapping.png}" 892 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TraceExodus.png}" 893 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TraceMultiViews.png}" 894 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TraceMultiViews_1.png}" 895 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TraceTimeControls.png}" 896 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunctionResetOnVisibilityChange_AllBlocks.png}" 897 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunctionResetOnVisibilityChange_OneBlock.png}" 898 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunctionResetOnVisibilityChange_TwoBlocks.png}" 899 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DEditor.png}" 900 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DEditor_1.png}" 901 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DEditor_2.png}" 902 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalars.png}" 903 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalars_1.png}" 904 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalars_2.png}" 905 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalars_3.png}" 906 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalarsEditor.png}" 907 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalarsEditor_1.png}" 908 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalarsEditorA.png}" 909 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalarsEditorA_1.png}" 910 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalarsEditorA_2.png}" 911 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalarsEditorB.png}" 912 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalarsEditorB_1.png}" 913 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalarsEditorB_2.png}" 914 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalarsEditorB_3.png}" 915 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TriangleStrips.png}" 916 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UniformInverseTransformSamplingGlyph_A.png}" 917 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UniformInverseTransformSamplingGlyph_B.png}" 918 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UniformInverseTransformSamplingGlyph_C.png}" 919 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UnstructuredVolumeVectorComponent_Magnitude.png}" 920 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UnstructuredVolumeVectorComponent_X.png}" 921 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UnstructuredVolumeVectorComponent_Y.png}" 922 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UnstructuredVolumeVectorComponent_Z.png}" 923 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UpdateTransferFunctionRanges1.png}" 924 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UpdateTransferFunctionRanges2.png}" 925 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UpdateTransferFunctionRanges3.png}" 926 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UpdateTransferFunctionRanges4.png}" 927 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UpdateTransferFunctionRanges5.png}" 928 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UpdateTransferFunctionRanges6.png}" 929 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions1.png}" 930 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions1_1.png}" 931 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions1_2.png}" 932 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions2.png}" 933 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions2_1.png}" 934 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions2_2.png}" 935 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions3.png}" 936 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions4.png}" 937 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VolumeCellSelection.png}" 938 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VolumeCrop.png}" 939 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VolumeOfRevolution.png}" 940 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VolumeIsosurfaceBlendMode.png}" 941 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VolumeNoMapScalars.png}" 942 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VolumeSliceBlendMode.png}" 943 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VTKHDFReaderPieceDistribution_Block.png}" 944 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VTKHDFReaderPieceDistribution_Inter.png}" 945 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/WaveNoFontScale.png}" 946 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/WaveFontScale.png}" 947 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/YoungsMaterialInterface.png}" 948 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYChart_ChangeParameters.png}" 949 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYChart_LegendNoBlock.png}" 950 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYChart_Default.png}" 951 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYChart_DisableBlocks.png}" 952 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYChart_EnableBlocks.png}" 953 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_Default.png}" 954 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_UseIndexForX.png}" 955 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_UseIndexForX_1.png}" 956 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_WithResult.png}" 957 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_WithResult2.png}" 958 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_WithResultChanged.png}" 959 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_WithResultChangedNormalized.png}" 960 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomClosestA.png}" 961 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomClosestA_1.png}" 962 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomClosestB.png}" 963 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomClosestC.png}" 964 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomClosestD.png}" 965 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomToData.png}" 966 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomToData_A.png}" 967 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomToData_B.png}" 968 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomToEmptyData.png}" 971 # Set INTEL_MACOS so we can avoid running some tests on macos 972 # with intel CPUs. This is because there are OpenGL issues and 973 # intel-based macs are end-of-life soon. 974 set(INTEL_MACOS FALSE)
975 if (
"$ENV{CMAKE_CONFIGURATION}" MATCHES
"macos_x86_64")
976 # This is the most reliable detection method but is specific to Kitware's CI machines. 977 set(INTEL_MACOS TRUE)
978 elseif(APPLE AND
"${CMAKE_SYSTEM_PROCESSOR}" MATCHES
"x86_64")
979 # Builders may report arm architectures even when targeting x86_64 machines 980 # depending on the cmake executable's architecture. However, this is likely to 981 # work outside of Kitware's CI infrastructure. 982 set(INTEL_MACOS TRUE)
985 # Some tests can take a long time; increase their timeouts. 986 # Really very long (300 seconds): 987 set(SeparateOpacityArray_TIMEOUT 300)
988 set(TransferFunction2DYScalars_TIMEOUT 300)
989 set(UndoRedo1_TIMEOUT 300)
990 set(GhostFeatureEdgesAndWireframe_TIMEOUT 300)
992 # Very long (200 seconds): 993 set(EqualizeLayout_TIMEOUT 200)
995 # Somewhat
long (150 seconds):
996 set(AMReXParticlesReader_TIMEOUT 150)
997 set(Clip_TIMEOUT 150)
998 set(ColorOpacityEditorFreehandDrawing_TIMEOUT 150)
999 set(ColorOpacityTableEditorHistogram_TIMEOUT 150)
1000 set(ComparativeVisPanel_TIMEOUT 150)
1001 set(Ensemble_TIMEOUT 150)
1002 set(HelpWindowHistory_TIMEOUT 150)
1003 set(ImageVolumeRendering_TIMEOUT 150)
1004 set(LagrangianIntegrationModel_TIMEOUT 150)
1005 set(LagrangianParticleTrackerReseeding_TIMEOUT 150)
1006 set(LagrangianParticleTracker_TIMEOUT 150)
1007 set(MemoryInspectorPanel_TIMEOUT 150)
1008 set(MultiBlockVolumeRendering_TIMEOUT 150)
1009 set(MultiServer3_TIMEOUT 150)
1010 set(PropertyContextMenu_TIMEOUT 150)
1011 set(ProxyCategoriesConfiguration_TIMEOUT 150)
1012 set(ProxyCategoriesDialog_TIMEOUT 150)
1013 set(SaveTSV_TIMEOUT 150)
1014 set(ScalarBarRange_TIMEOUT 150)
1015 set(SeparatedColorMapOpacity_TIMEOUT 150)
1016 set(SliceRepresentation_TIMEOUT 150)
1017 set(SplitViewTrace_TIMEOUT 150)
1018 set(SpreadSheet3_TIMEOUT 150)
1019 set(TemporalParticleKeepDeadTrails_TIMEOUT 150)
1020 set(TraceExportAndSaveData_TIMEOUT 150)
1021 set(TraceMultiViews_TIMEOUT 150)
1022 set(TransferFunction2D_TIMEOUT 150)
1023 set(ZoomToData_TIMEOUT 150)
1025 # Test without baselines and could only run in built-in mode. 1026 list(APPEND TEST_WITHOUT_BASELINES_CLIENT_ONLY
1028 CellGridSpreadSheetViewClient.xml
1029 CellQualityForPixel.xml
1030 ComputeArrayMagnitudeSetting.xml
1031 DefaultReadersSetting.xml
1032 DelimitedTextReader.xml
1033 DescriptiveStatisticsByAssembly.xml
1034 DynamicFieldDataDomain.xml
1035 ExportFilteredColumnsSpreadsheet.xml
1036 ExportSpreadsheetFormatting.xml
1037 ExtractCellsByType.xml
1038 ExtractParticlesOverTime.xml
1039 FluentReaderZoneSelection.xml
1040 FieldDataToAttribute.xml
1041 HTGCellCentersBackwardCompat.xml
1042 HTGFeatureEdgesBackwardCompat.xml
1043 HTGGhostCellsGeneratorBackwardCompat.xml
1044 HTGReflectionBackwardCompat.xml
1045 HTGVisibleLeavesSizeBackwardCompat.xml
1046 InformationPanel.xml
1047 IntegrationStrategy.xml
1048 OverrideProperty.xml
1049 PartialArrayInLineChart.xml
1050 ProtractorRepositionToView.xml
1051 ProxyCategoriesConfiguration.xml
1052 ProxyCategoriesDialog.xml
1053 ProxyCategoriesDialogSettings.xml
1054 ProxyCategoriesMenusDefault.xml
1055 ProxyCategoriesToolbar.xml
1056 QuadricDecimation.xml
1057 RawImageDataReaderBackwardCompat.xml
1058 ReaderRegistrationName.xml
1059 ReadIOHDFAMRMaxLevels.xml
1060 RescaleVisibleRangeOption.xml
1061 RulerRepositionToView.xml
1062 SpatioTemporalHarmonicsAttribute.xml
1063 SpatioTemporalHarmonicsSource.xml
1064 SpreadSheetSelectedCellConnectivity.xml
1065 TensorPrincipalInvariants.xml
1066 TestFileListPropertyWidget.xml
1067 TestCompositePropertyWidgetDecorator.xml
1070 WriteXMLTimeValue.xml
1074 if (PARAVIEW_USE_PYTHON)
1075 list (APPEND TEST_WITHOUT_BASELINES_CLIENT_ONLY
1076 ColorByDynamicComponent.xml
1080 list (APPEND TEST_WITH_BASELINES_CLIENT_ONLY
1081 # Does not work in client/server when there is more than 1 node. 1082 # https://gitlab.kitware.com/vtk/vtk/-/issues/19951 1083 ImageBinaryThresholdFilter.xml)
1085 list (APPEND TESTS_WITHOUT_BASELINES
1090 AppendImplicitArrays.xml
1091 ArrayBoundsScaleDomain.xml
1092 ArraySelectionWidget.xml
1093 AutoConvertSingleProperty.xml
1094 CellGridInformationPanel.xml
1096 ChangeFileNameReaction.xml
1097 CustomOutputFormat.xml
1099 ExpressionsDialog.xml
1100 ExpressionsExporter.xml
1101 ExpressionsSettings.xml
1102 FileDialogOpenInteractClose.xml
1104 GradientBackwardsCompatibility.xml
1105 ImportCustomPresets.xml
1106 InformationOutOfDateLabel.xml
1109 ModifyGUIWindowTitle.xml
1110 OpacityWidgetRange.xml
1112 PlotOverLineLegacy.xml
1113 PointCellDataConversion.xml
1114 PolarAxesBackwardsCompatibility.xml
1115 PreservePropertyValues.xml
1116 ProcessIdScalarsBackwardCompat.xml
1117 ProxyCategoriesDialogDefault.xml
1118 ProxyCategoriesFavorites.xml
1119 QuadraturePointsDS.xml
1120 QuickLaunchCreateProxy.xml
1121 QuickLaunchNavigation.xml
1122 QuickLaunchRequest.xml
1123 ReadFLUENTCFFFaces.xml
1124 ReflectBackwardCompat.xml
1126 RenderViewUpdateLOD.xml
1128 ServerConnectDialog.xml
1129 SettingsNoCustomDefault.xml
1130 SettingsOverrideDomain.xml
1131 SettingsProxyProperty.xml
1132 SettingsRestoreProxyAppDefault.xml
1133 SettingsSubProxy.xml
1134 SliceBackwardsCompatibility.xml
1135 SpreadSheetFieldData.xml
1136 STLReaderMergePoints.xml
1137 StringInLineChartView.xml
1139 TemporalArrayOperator.xml
1140 TestOpenFOAMRestartFiles.xml
1142 TestTransformMatrixTab.xml
1143 ThresholdBackwardsCompatibility.xml
1144 TimeManagerPanel.xml
1145 TimeManagerSequence.xml
1149 if (PARAVIEW_PLUGIN_ENABLE_EULATestPlugin)
1150 list(APPEND TESTS_WITHOUT_BASELINES
1154 if (PARAVIEW_ENABLE_OPENVDB)
1155 list (APPEND TESTS_WITHOUT_BASELINES
1160 if (PARAVIEW_ENABLE_CATALYST)
1161 list (APPEND TESTS_WITHOUT_BASELINES
1162 CatalystLiveConnection.xml
1166 if (PARAVIEW_USE_QTHELP)
1167 list(APPEND TESTS_WITHOUT_BASELINES
1168 HelpWindowHistory.xml)
1172 list(APPEND TESTS_WITHOUT_BASELINES
1177 if (PARAVIEW_ENABLE_FFMPEG)
1178 list(APPEND TESTS_WITHOUT_BASELINES
1182 list (APPEND TESTS_WITH_INLINE_COMPARES
1184 AxisAlignedCutterMBHierarchy.xml
1185 AxisAlignedCutterPDCNoHierarchy.xml
1186 AxisAlignedReflect.xml
1189 BlockContextMenu.xml
1190 BlockLinkedSelection.xml
1191 CalculatorQuotedVariable.xml
1193 CellGridRenderViewRepresentations.xml
1194 CGNSReaderDataLocation.xml
1195 CGNSReaderSurfacePatches.xml
1196 ChartDefaultSettings.xml
1197 ChartLoadNoVariables.xml
1198 ClampAndUpdateColorMap.xml
1199 ColorOpacityTableEditorHistogram.xml
1200 ComputeNormalsInRepresentation.xml
1206 DataAxesGridIgnoreScaling.xml
1207 DataDimDefaultAxes.xml
1208 DecimatePolyline.xml
1209 DeleteSubtreePipelineBrowser.xml
1213 ExtractSubsetWithSeed.xml
1214 FastUniformGridSource.xml
1216 FeatureEdgesHTGNoMask.xml
1218 FontScalingInScreenshots.xml
1219 HyperTreeGrid2DGeometryFillMaterial.xml
1220 HyperTreeGridAxisClip.xml
1221 HyperTreeGridAxisCut.xml
1222 HyperTreeGridAxisReflection.xml
1223 HyperTreeGridCellCenters.xml
1224 HyperTreeGridContour.xml
1225 HyperTreeGridContourStrategy.xml
1226 HyperTreeGridDataAndPolarAxes.xml
1227 HyperTreeGridDepthLimiter.xml
1228 HyperTreeGridEvaluateCoarse.xml
1229 HyperTreeGridExtractGhostCells.xml
1230 HyperTreeGridGeometry.xml
1231 HyperTreeGridGradient.xml
1232 HyperTreeGridMultiBlock.xml
1233 HyperTreeGridMultipleClip.xml
1234 HyperTreeGridObliquePlaneCutter.xml
1235 HyperTreeGridPlaneCutter.xml
1236 HyperTreeGridThreshold.xml
1237 HyperTreeGridSurfaceMultiBlockSelection.xml
1240 LineChartSelection.xml
1241 LoadStateMultiView.xml
1243 LogColorMapToggle.xml
1244 LogoSourcesInChartViews.xml
1245 MemoryInspectorPanel.xml
1246 MeshCacheAddedArraysOverTime.xml
1248 MultiBlockInspectorMultiBlock.xml
1249 MultiBlockInspectorProperties.xml
1250 MultiBlockInspectorSelection.xml
1251 MultiBlockChartSelection.xml
1252 MultipleColorOnSelection.xml
1254 NonlinearSubdivisionDisplay.xml
1255 PaletteBackgrounds.xml
1256 ParallelCoordinatesView.xml
1257 PartitionedDataSet.xml
1258 PartitionedDataSetCollection.xml
1261 PreviewFontScaling.xml
1262 PropertyContextMenu.xml
1264 RandomHyperTreeGridSource.xml
1265 ReadPartitionedCGNS.xml
1266 ReadCGNSBCDataset.xml
1267 ReadIOHDFFileSeries.xml
1268 ReadIOHDFWithCache.xml
1269 ReadFLUENTCFFFormat.xml
1270 RectilinearFractal.xml
1272 ReloadExodusFile.xml
1276 RenderViewContextMenu.xml
1277 ResetToVisibleRange.xml
1280 SaveLargeScreenshot.xml
1282 SelectColorMapFromComboBox.xml
1284 SelectionLinkParallelCoordinatesView.xml
1285 SeparateOpacityArray.xml
1286 SliceRepresentation.xml
1287 SteeringDataGenerator.xml
1288 TemporalSmoothing.xml
1289 TestCleanGridPointDataStrategies.xml
1290 TestColorMapModificationRendersAllViews.xml
1292 TestHTGSelection.xml
1293 TestHTGThreshold.xml
1295 TestSkyboxRotation.xml
1296 TextSourceBorder.xml
1298 ThresholdComponentModes.xml
1299 TransferFunctionResetOnVisibilityChange.xml
1300 UnstructuredVolumeRenderingVectorComponent.xml
1301 UpdateTransferFunctionRanges.xml
1307 # Image data delivery to render server not supported. 1308 set(SeparateOpacityArray_DISABLE_CRS TRUE)
1311 # Workaround to avoid testing failures on high-res Retina displays on Macs 1312 list(APPEND TESTS_WITH_INLINE_COMPARES
1313 ColorLegendScaledScreenshot.xml
1317 list(APPEND TESTS_WITH_BASELINES
1318 AMRAxisAlignedSlice.xml
1319 AMRRectGridOutline.xml
1320 AMRRectGridSurface.xml
1321 AMRUniformGridOutline.xml
1322 AMRUniformGridSurface.xml
1323 AnnotateGlobalData.xml
1325 AxisAlignedCutterAMR.xml
1326 AxisAlignedCutterHTG.xml
1328 BoxWidgetVisibleBlock.xml
1329 CameraOrientationWidget.xml
1330 ChartsClearSelection.xml
1331 CleanToGridRemovePoints.xml
1333 ConstantShadingPerObject.xml
1334 CONVERGECFDCGNSReader.xml
1336 EmptyInitialCompositeReader.xml
# Issue #21293 1337 FeatureEdgesFilterHTG.xml
1338 FeatureEdgesRepresentationHTG.xml
1340 IOSSMergeExodusEntityBlocks.xml
1342 IntegrateVariablesPDC.xml
1344 MergeVectorComponents.xml
1345 MissingPartialArraysColoredByNaN.xml
1346 MoleculeScalarBar.xml
1349 NOAMRRectGridSurface.xml
1350 NOAMRUniformGridSurface.xml
1351 PartialFieldDataMultiBlock.xml
1352 ParticleTracerGlyph.xml
1355 PNGReaderDataOrigin.xml
1356 PointAndCellIdsHTG.xml
1357 PointDataSetInterpolator.xml
1359 PVCellCentersHyperTreeGrid.xml
1361 RemoveGhostInformationHTG.xml
1364 SaveLoadScreenShotWithEmbedState.xml
1365 SelectionBlocksThrough.xml
1366 SelectionByArray.xml
1368 SeriesPresetRegexp.xml
1369 ShowMultiPieceFieldData.xml
1371 TemporalParticleKeepDeadTrails.xml
1372 TestHiddenLineRemoval.xml
1373 TestOpenFOAMWeighByCell.xml
1374 TestParallelProjectionAnnotations.xml
1375 TestResampleHTG2Dims.xml
1376 TestResampleHyperTreeGridWithSphere.xml
1377 TransferFunction2D.xml
1378 UnlinkCameraView.xml
1379 VolumeOfRevolution.xml
1380 ZoomClosestOffsetRatio.xml
1384 PCANormalEstimation.xml
1387 # PointDataSetInterpolator does not support distributed processing
1388 set(PointDataSetInterpolator_DISABLE_CS TRUE)
1389 set(PointDataSetInterpolator_DISABLE_CRS TRUE)
1391 if (NOT INTEL_MACOS)
1392 list(APPEND TESTS_WITH_INLINE_COMPARES
1395 list(APPEND TESTS_WITH_BASELINES
1396 IOSSCellGridHCurl.xml
1397 IOSSCellGridHDiv.xml
1398 TransferFunction2DYScalars.xml
1402 if(PARAVIEW_ENABLE_VISITBRIDGE)
1403 list(APPEND TESTS_WITH_BASELINES
1404 VisItBridgeChombo.xml
1405 VisItBridgeChomboFileSeries.xml
1406 VisItBridgeLAMMPSDump.xml
1407 VisItBridgeLAMMPSDump2.xml
1408 VisItBridgeLAMMPSDumpMultiTime.xml
1409 VisItBridgeLAMMPSDumpTimeSeries.xml
1412 VisItBridgeMoleculeColoring.xml
1414 VisItBridgePFLOTRAN.xml
1415 # disabling this test for now, not sure why it fails 1416 # even with 5.7 binarie 1417 #VisItBridgePixie.xml 1418 VisItBridgeSamrai.xml
1419 TruchasReaderWithVisItBridge.xml)
1420 list(APPEND TESTS_WITH_INLINE_COMPARES
1421 CONVERGECFDReaderWithVisItBridge.xml
1424 # A number of VisIt readers support reading of .pdb and 1425 # of .h5 files, so when the VisItBridge is enabled, 1426 # the test must take extra steps to select the correct reader. 1428 # When the VisItBridge is not enabled, there is no need to select 1430 list(APPEND TESTS_WITH_BASELINES
1431 MoleculeColoring.xml
1434 list(APPEND TESTS_WITH_INLINE_COMPARES
1435 CONVERGECFDReader.xml)
1438 if(PARAVIEW_ENABLE_RAYTRACING)
1439 list(APPEND TESTS_WITH_BASELINES
1443 if(PARAVIEW_ENABLE_OPENTURNS)
1444 list(APPEND TESTS_WITH_BASELINES
1445 HistogramKernelSmoothing.xml)
1446 list(APPEND TESTS_WITH_BASELINES
1447 PlotMatrixViewDensityMaps.xml)
1450 # hits OSX bug with FileDialog so exclude test on APPLE 1452 list (APPEND TESTS_WITH_INLINE_COMPARES
1453 HistogramSelection.xml)
1456 # TODO: Port to the new API. 1458 # These tests are too complex to run in parallel. 1459 set (CATALYST_SIMULATION CatalystWaveletDriver.py)
1460 set (INSITU_SCRIPT CatalystWaveletCoprocessing)
1462 set (
"${test_name}_FORCE_SERIAL" TRUE)
1463 add_pv_test(
"pv" "_DISABLE_C" 1465 --script-ignore-output-errors --script $<TARGET_FILE:ParaView::pvbatch> --sym
1466 ${CMAKE_CURRENT_SOURCE_DIR}/${CATALYST_SIMULATION}
1467 ${INSITU_SCRIPT}
"${duration}" 1469 --client ${CLIENT_EXECUTABLE}
1471 ${command_line_connect_command}
1473 --test-directory=${PARAVIEW_TEST_DIR}
1474 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
1475 TEST_SCRIPTS ${test_name}.xml
1476 EXTRA_LABELS
"catalyst")
1478 add_pv_test(pvcs
"_DISABLE_CS" 1480 --script-np 5 --script-ignore-output-errors
1481 --script $<TARGET_FILE:ParaView::pvbatch> --sym
1482 ${CMAKE_CURRENT_SOURCE_DIR}/${CATALYST_SIMULATION}
1483 ${INSITU_SCRIPT}
"${duration}" 1485 --server $<TARGET_FILE:ParaView::pvserver>
1488 --client ${CLIENT_EXECUTABLE}
1490 ${command_line_connect_command}
1492 --test-directory=${PARAVIEW_TEST_DIR}
1493 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
1494 TEST_SCRIPTS ${test_name}.xml
1495 EXTRA_LABELS
"catalyst")
1499 if (PARAVIEW_ENABLE_XDMF2 AND NOT PARAVIEW_ENABLE_XDMF3)
1500 # Xdmf2 is optional. 1501 # And when both Xdmf2 and Xdmf3 are enabled, the SelectReader dialog 1502 # confuses these tests. So, we'll disable them for now. 1503 # We need a better mechanism to handle such cases in the testing framework. 1504 list(APPEND TESTS_WITH_BASELINES
1507 XdmfReadImageData.xml
1508 XdmfReadImageDataCollection.xml
1509 XdmfReadRectilinearGrid.xml
1510 XdmfReadRectilinearGridCollection.xml
1511 XdmfReadStructuredGrid.xml
1512 XdmfReadStructuredGridCollection.xml
1513 XdmfGridAttributes.xml
1518 list(APPEND TESTS_WITH_BASELINES
1519 4AxesContextView.xml
1520 AccentuatedFilename.xml
1521 AdaptiveResampleToImage.xml
1522 AMRArraySelection.xml
1525 AMReXParticlesReader.xml
1526 AxisAlignedSliceBackwardCompat.xml
1527 AxisAlignedTransform.xml
1529 AnimationCameraExportImport.xml
1530 AnimationFollowPath.xml
1531 AnimationSetTimeCursor.xml
1532 AnimationUseCamera.xml
1536 ConvertToMolecule.xml
1538 CopyPasteFilters.xml
1539 CopyPasteProperties.xml
1545 CTHAMRMaterialInterfaceFilter.xml
1546 CTHDerivedDensity2DCylinder.xml
1547 AddActiveValuesFromVisibleObjects.xml
1548 AnimatePipelineTime.xml
1549 AngularPeriodicFilter.xml
1550 3DWidgetInCustomFilter.xml
1555 CameraWidgetViewLink.xml
1556 CameraWidgetViewLinkState.xml
1557 CategoriesWithNaN.xml
1559 # Disabled due to #20508
1560 # ChangeGlyphRepVisibility.xml
1561 ChangingTimestepsInStateFiles.xml
1562 ChartAxisRangeAndLabels.xml
1565 ClipExactBoxNonInverted.xml
1567 ColorAnnotationsVisibilitiesAndOpacities.xml
1568 ColorEditorControls.xml
1569 ColorEditorVolumeControls.xml
1570 ColorLegendMinMaxLabels.xml
1571 ColorLegendBackground.xml
1572 ColorOpacityTableEditing.xml
1573 ColorOpacityEditorFreehandDrawing.xml
1574 ColorOpacityEditorRangeHandles.xml
1575 CombineFrustumSelections.xml
1576 CategoricalAutomaticAnnotations.xml
1577 CategoricalColors.xml
1578 CategoricalOpacities.xml
1579 ColorByCellDataStringArray.xml
1580 ComparativeVisPanel.xml
1581 ComparativeViewOverlay.xml
1582 # disabling overlay test
for now. It has issues with Time 0.
1583 # ComparativeOverlay.xml
1584 CompositeSurfaceSelection.xml
1585 ComputeConnectedSurfaceProperties.xml
1587 CustomSourceProbe.xml
1588 CustomViewpoints.xml
1590 DisableResetDisplayEmptyViews.xml
1591 DualSphereAnimation.xml
1595 EnSightTensorInversion.xml
1596 EnSightTensorInversionBin.xml
1597 ExodusGlobalDataWithRestarts.xml
1598 ExodusSingleTimeStep.xml
1600 ExportLinePlotToCSV.xml
1601 ExportLinePlotToTSV.xml
1602 ExportSceneSpreadSheetView2.xml
1603 ExportX3dPOVVRML.xml
1606 ExtractComponentFilter.xml
1608 ExtractTimeSteps.xml
1611 FeatureEdgesNonlinearCells.xml
1614 FileDialogOpenFile.xml
1618 FollowHiddenData.xml
1621 GenerateTimeSteps.xml
1622 GenerateTimeStepsData.xml
1623 GhostCellsGeneratorImageSerial.xml
1624 Glyph3DCullingAndLOD.xml
1625 Glyph3DRepresentation.xml
1626 GlyphUseCellCenters.xml
1627 GlyphWithEmptyCells.xml
1628 GroupDataSetOutputType.xml
1629 glTFImporterNestedRings.xml
1630 glTFImporterWaterBottle.xml
1631 glTFReaderAnimatedMorphing.xml
1632 glTFReaderMultipleAnimations.xml
1633 glTFReaderMultipleScenes.xml
1634 glTFReaderToggleDeformation.xml
1635 glTFReaderTriangle.xml
1638 HorizontalColorLegendTitle.xml
1639 IgnoreLogAxisWarning.xml
1640 ImageDataToUniformGrid.xml
1641 ImageVolumeRendering.xml
1642 InteractiveSelection.xml
1643 InteractiveViewLinkOffscreen.xml
1644 InteractiveViewLinkOnscreen.xml
1645 InteractiveViewLinkState.xml
1648 LinearCellExtrusion.xml
1650 LinkRepresentationProperties.xml
1651 LoadPartiallyUpdatedStateFiles.xml
1652 LoadSaveStateAnimation.xml
1654 LoadStateChooseDirectory.xml
1655 LoadStateChooseFiles.xml
1656 LoadStateTextSourceRepresentation.xml
1657 LoadStateUseExisting.xml
1658 LoadSaveStateVolume.xml
1659 ManyTypesXMLWriterReader.xml
1660 MatchBoundariesIgnoringCellOrder.xml
1661 MergePointBlocks.xml
1665 # MultiBlockAttributes1.xml
1666 MultiBlockInspector.xml
1667 MultiBlockInspectorAssembly.xml
1668 MultiBlockInspectorAssemblyExtractBlocks.xml
1669 MultiBlockInspectorAssemblyWithoutSelectOnClickSetting.xml
1670 MultiBlockInspectorExtractBlocks.xml
1671 MultiBlockSingleBlock.xml
1672 MultiBlockVolumeRendering.xml
1673 MultiBlockInspectorWithoutSelectOnClickSetting.xml
1674 MultiSliceMultiBlock.xml
1675 MultiSliceWavelet.xml
1677 NumberOfComponentsDomain.xml
1678 NonConvexPolygon.xml
1679 OctreeImageFilters.xml
1680 OMETIFFChannelCalculator.xml
1682 OrderedGroupDatasets.xml
1683 OrthographicView.xml
1684 OutOfRangeColors.xml
1686 PlotDataOverTime-NonDistributed.xml
1688 # PlotEdges.xml see paraview/paraview#20659
1689 PlotGlobalVariablesOverTime.xml
1690 PlotOverTimeAutoApply.xml
1691 PolygonCellSelection.xml
1692 PolygonPointSelection.xml
1694 PointGaussianMultiBlockDataSet.xml
1695 PointGaussianNoScaleTransferFunction.xml
1696 PointGaussianScaleOpacityArray.xml
1697 PointInterpolator.xml
1698 PointsMatchingTransform.xml
1699 PointVolumeInterpolator.xml
1701 PolarAxesRasterizedText.xml
1702 PolarAxesRemoteRendering.xml
1704 PolyLineAndSplineSources.xml
1705 PropertyConversion.xml
1706 PropertyConversion1.xml
1707 PropertyConversion2.xml
1708 PropertyConversion3.xml
1709 PropertyConversion4.xml
1711 QuadraticGhostCells.xml
1712 ReadXMLPolyDataFileSeries.xml
1714 RecentFilesHardFilename.xml
1715 RectilinearVolumeRendering.xml
1716 RedistributeDataSetFilter.xml
1717 RepresentationSelector.xml
1718 ResampleWithDataset.xml
1719 RescaleToTemporal.xml
1721 RotateAroundOriginTransform.xml
1723 RotationalExtrusionFilter.xml
1724 # SaveAnimationGeometry.xml # see #20236
1728 SaveMultiBlockCSV.xml
1732 SelectedProxyPanelVisibility.xml
1734 SelectionModifiersCells.xml
1735 SelectionModifiersPoints.xml
1736 SelectionModifiersBlocks.xml
1737 SetCustomBasicPresets.xml
1738 ShaderReplacements.xml
1740 SimpleInteraction.xml
1742 SliceAlongPolyline.xml
1743 SliceAlongSpline.xml
1744 SolidColorSource.xml
1745 SpherePointSource.xml
1750 SpyPlotHistoryReader.xml
1751 SelectionLinkBasic.xml
1752 SelectionLinkConverted.xml
1753 SelectionLinkHistogram.xml
1754 SelectionLinkInitial.xml
1755 SelectionLinkMultiple.xml
1756 SelectionLinkRemove.xml
1757 SelectionLinkReaction.xml
1758 SelectionLinkReactionNonConverted.xml
1759 SeparatedColorMap.xml
1760 SeparatedColorMapOpacity.xml
1762 SliceWithPlaneMultiBlock.xml
1763 SortLineChartData.xml
1764 ScrollAreaNativeWidget.xml
1768 StreamTracerSurface.xml
1769 StreamTracerUpdates.xml
1772 TemporalInterpolator.xml
1773 TemporalShiftScale.xml
1774 TestAnnotateSelectionFilter.xml
1775 TestBoundaryMeshQuality.xml
1776 TestGroupDataFromTimeSeries.xml
1777 TestSelectionOnMultipiece.xml
1778 TimeStepProgressBar.xml
1794 UnstructuredOutline.xml
1795 UniformInverseTransformSamplingGlyph.xml
1796 VectorComponentHistogram.xml
1797 VolumeIsosurfaceBlendMode.xml
1798 VolumeRenderingWithContour.xml
1799 VolumeReprTwoIndepComp.xml
1800 VolumeSliceBlendMode.xml
1801 VariableSelector.xml
1802 VariableSelector1.xml
1803 ViewSettingsDialog.xml
1806 RandomAttributes.xml
1808 YoungsMaterialInterface.xml
1811 if (TARGET VTK::IOParallelLSDyna)
1812 if (NOT TARGET VTK::IOPDAL)
1813 list(APPEND TESTS_WITH_BASELINES
1816 list(APPEND TESTS_WITH_BASELINES
1820 if (TARGET VTK::IOFides)
1821 if (PARAVIEW_ENABLE_ADIOS2)
1822 list(APPEND TESTS_WITH_INLINE_COMPARES
1823 FidesReaderADIOS2.xml
1824 FidesWriterADIOS2.xml
1827 list(APPEND TESTS_WITH_INLINE_COMPARES
1834 if (TARGET VTK::IOOMF)
1835 list(APPEND TESTS_WITH_INLINE_COMPARES
1840 if (TARGET VTK::IOPDAL)
1841 ExternalData_Expand_Arguments(ParaViewData _
1842 "DATA{${paraview_test_data_directory_input}/Data/ReadOffset.las}")
1843 list(APPEND TESTS_WITHOUT_BASELINES
1848 if(VTK_USE_LARGE_DATA)
1849 ExternalData_Expand_Arguments(ParaViewData _
1850 "DATA{${paraview_test_data_directory_input}/Data/bake/bake.e}")
1851 list(APPEND TESTS_WITH_BASELINES
1852 RestoreBlockColorDefaultTransferFunction.xml
1856 if (NOT PARAVIEW_USE_MPI)
1857 list(APPEND TESTS_WITH_BASELINES
1862 if (TARGET VTK::IOHDF)
1863 # VTKHDFWriter does not support writing external partitions/compositte with MPI yet 1864 # See issue https://gitlab.kitware.com/vtk/vtk/-/issues/19857 1866 TEST_SCRIPTS VTKHDFWriter.xml
1870 if (TARGET VTK::IOUSD)
1871 list(APPEND TESTS_WITHOUT_BASELINES
1876 # The color dialog is different on MacOS X which makes this test fail. 1878 list(APPEND TESTS_WITH_BASELINES
1879 BackgroundLights.xml
1883 list(APPEND TESTS_WITH_BASELINES
1884 # This test makes use of
"Point Gaussian" representation, only available with OpenGL2
1885 BackgroundColorCheck.xml
1887 PlotMatrixViewArraySelection.xml
1888 PlotMatrixViewParameters.xml
1890 # Composite Glyph Trees are only implemented in OpenGL2
1891 CompositeGlyphTree.xml
1894 #------------------------------------------------------------------------------ 1895 # Add streaming tests. 1896 # We need to locate smooth.flash since it's not included in the default testing 1898 find_file(smooth_flash NAMES smooth.flash
1899 DOC
"Path to smooth.flash data file." 1901 mark_as_advanced(smooth_flash)
1902 if (EXISTS
"${smooth_flash}")
1903 # we configure the file since we need to point to smooth_flash. 1904 configure_file(
"AMRStreaming.xml.in" 1905 "${CMAKE_CURRENT_BINARY_DIR}/AMRStreaming.xml" @ONLY)
1906 configure_file(
"AMRVolumeRendering.xml.in" 1907 "${CMAKE_CURRENT_BINARY_DIR}/AMRVolumeRendering.xml" @ONLY)
1909 set (streaming_tests
1910 ${CMAKE_CURRENT_BINARY_DIR}/AMRStreaming.xml)
1912 # AMRVolumeRendering is a non-streaming test.
1913 list(APPEND TESTS_WITH_BASELINES
1914 ${CMAKE_CURRENT_BINARY_DIR}/AMRVolumeRendering.xml)
1916 foreach (tname ${streaming_tests})
1917 add_pv_test(
"pv" "_DISABLE_C" 1918 COMMAND --client ${CLIENT_EXECUTABLE}
1922 --test-directory=${PARAVIEW_TEST_DIR}
1924 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
1925 TEST_SCRIPTS ${tname})
1927 add_pv_test(pvcs
"_DISABLE_CS" 1929 --server $<TARGET_FILE:ParaView::pvserver>
1932 --client ${CLIENT_EXECUTABLE}
1936 --test-directory=${PARAVIEW_TEST_DIR}
1937 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
1938 TEST_SCRIPTS ${tname})
1942 #------------------------------------------------------------------------------ 1944 # Add tests for OSPRay material editor 1945 if (paraview_use_materialeditor)
1946 list(APPEND TESTS_WITH_INLINE_COMPARES
1947 MaterialEditorCreateMaterials.xml
1948 MaterialEditorLoadMaterials.xml
1949 MaterialEditorSaveMaterials.xml
1950 MaterialEditorShaderBallScene.xml
1954 # Probe picking does not work in render server mode 1956 # Selection is not available in CRS mode 1957 set(BlockContextMenu_DISABLE_CRS TRUE)
1958 set(BlockLinkedSelection_DISABLE_CRS TRUE)
1959 set(MultipleColorOnSelection_DISABLE_CRS TRUE)
1960 set(MultiSliceWavelet_DISABLE_CRS TRUE)
1961 set(MultiSliceMultiBlock_DISABLE_CRS TRUE)
1962 set(PolygonCellSelection_DISABLE_CRS TRUE)
1963 set(PolygonPointSelection_DISABLE_CRS TRUE)
1964 set(NonlinearSubdivisionDisplay_DISABLE_CRS TRUE)
1965 set(InteractiveSelection_DISABLE_CRS TRUE)
1966 set(NonConvexPolygon_DISABLE_CRS TRUE)
1967 set(QuartilePlot_DISABLE_CRS TRUE)
1968 set(TestSelectionOnMultipiece_DISABLE_CRS TRUE)
1969 set(TestHTGSelection_DISABLE_CRS TRUE)
1970 set(SelectionByArray_DISABLE_CRS TRUE) # yes,
this test does a selection
1971 set(SelectionBlocks_DISABLE_CRS TRUE)
1972 set(SelectionEditor_DISABLE_CRS TRUE)
1973 set(SelectionModifiersCells_DISABLE_CRS TRUE)
1974 set(SelectionModifiersBlocks_DISABLE_CRS TRUE)
1975 set(SelectionModifiersPoints_DISABLE_CRS TRUE)
1976 set(SelectionLinkBasic_DISABLE_CRS TRUE)
1977 set(SelectionLinkInitial_DISABLE_CRS TRUE)
1978 set(SelectionLinkMultiple_DISABLE_CRS TRUE)
1979 set(SelectionLinkRemove_DISABLE_CRS TRUE)
1980 set(SelectionLinkReaction_DISABLE_CRS TRUE)
1981 set(SelectionLinkScripting_DISABLE_CRS TRUE)
1982 set(TestAnnotateSelectionFilter_DISABLE_CRS TRUE)
1983 set(ExpandSelection_DISABLE_CRS TRUE)
1984 set(ExportSelectionToCSV_DISABLE_CRS TRUE)
1985 set(BlockOpacities_DISABLE_CRS TRUE)
1986 set(SaveExodus_DISABLE_CRS TRUE) # yes,
1987 set(CombineFrustumSelections_DISABLE_CRS TRUE) # yes,
1988 set(RenderViewContextMenu_DISABLE_CRS TRUE)
1990 # BoxWidgetVisibleBlock and ZoomToData are not working as well in crs 1991 set(BoxWidgetVisibleBlock_DISABLE_CRS TRUE)
1992 set(ZoomToData_DISABLE_CRS TRUE)
1993 # These tests cannot be run using ctest -j since they are affected by focus 1995 set (AbortExit_FORCE_SERIAL TRUE) # since
this uses popup window
1996 set (AnimatePipelineTime_FORCE_SERIAL TRUE)
1997 set (AnimateProperty_FORCE_SERIAL TRUE) # since
1998 set (AnimationCache_FORCE_SERIAL TRUE) # since
1999 set (AnimationFollowPath_FORCE_SERIAL TRUE) # since
2000 set (BlockContextMenu_FORCE_SERIAL TRUE) # requires context menu
2001 set (CGNSReaderDataLocation_FORCE_SERIAL TRUE) # since
this uses popup-menu
2002 set (CTHAMRBaseline_FORCE_SERIAL TRUE) # since
2003 set (CTHAMRContour_FORCE_SERIAL TRUE) # since
2004 set (CTHAMRDualClip_FORCE_SERIAL TRUE) # since
2005 set (CTHAMRMaterialInterfaceFilter_FORCE_SERIAL TRUE) # since
2006 set (CTHDerivedDensity2DCylinder_FORCE_SERIAL TRUE) # since
2007 set (Calculator_FORCE_SERIAL TRUE) # since
2008 set (CalculatorInput_FORCE_SERIAL TRUE) # since
2009 set (CategoricalAutomaticAnnotations_FORCE_SERIAL TRUE) # Seems to works better in serial
2010 set (CategoricalColors_FORCE_SERIAL TRUE) # Uses
inline edit popups
2011 set (CategoricalOpacities_FORCE_SERIAL TRUE) # Seems to works better in serial
2012 set (ChartAxisRangeAndLabels_FORCE_SERIAL TRUE) # Uses
inline edit popups
2013 set (ColorAnnotationsVisibilitiesAndOpacities_FORCE_SERIAL TRUE) # since
2014 set (ColorOpacityTableEditing_FORCE_SERIAL TRUE) # since
2015 set (ComparativeViewOverlay_FORCE_SERIAL TRUE) # Seems to works better in serial
2016 set (ComputeArrayMagnitudeSetting_FORCE_SERIAL TRUE) # Seems to works better in serial
2017 set (ConfigurableCategories_FORCE_SERIAL TRUE) # since
2018 set (ColorAnnotationsVisibilitiesAndOpacities_FORCE_SERIAL TRUE) # since
this uses context menu
2019 set (Contour_FORCE_SERIAL TRUE) # since
2020 set (CSVPreview_FORCE_SERIAL TRUE) # since
2021 set (CustomViewpoints_FORCE_SERIAL TRUE)
2022 set (DefaultReadersSetting_FORCE_SERIAL TRUE) # since
2023 set (DelimitedTextReader_FORCE_SERIAL TRUE) # since
2024 set (DynamicFieldDataDomain_FORCE_SERIAL TRUE) # since
2025 set (EnSight_FORCE_SERIAL TRUE) # since
2026 set (ExodusModeShapes_FORCE_SERIAL TRUE)
2027 set (ExportFilteredColumnsSpreadsheet_FORCE_SERIAL TRUE) # since
2028 set (ExportLinePlotToCSV_FORCE_SERIAL TRUE) # since
2029 set (ExportSceneSpreadSheetView2_FORCE_SERIAL TRUE) # since
2030 set (ExportSelectionToCSV_FORCE_SERIAL TRUE) # since
2031 set (ExportSpreadsheetFormatting_FORCE_SERIAL TRUE) # since
2032 set (ExpressionChooser_FORCE_SERIAL TRUE) # since
2033 set (ExpressionsDialog_FORCE_SERIAL TRUE) # since
2034 set (ExpressionsExporter_FORCE_SERIAL TRUE) # since
2035 set (ExpressionsSettings_FORCE_SERIAL TRUE) # since
this uses combo-box popup-menu
2036 set (HistogramKernelSmoothing_FORCE_SERIAL TRUE) # since
2037 set (LoadSaveStateAnimation_FORCE_SERIAL TRUE)
2038 set (LoadSaveStateVolume_FORCE_SERIAL TRUE)
2039 set (LogColorMapToggle_FORCE_SERIAL TRUE) # since
this pops up output window
2040 set (LogColorMap_FORCE_SERIAL TRUE) # since
2041 set (MathTextColumn_FORCE_SERIAL TRUE) # since
2042 set (MoleculeToLines_FORCE_SERIAL TRUE) # since
2043 set (ParallelCoordinatesView_FORCE_SERIAL TRUE) # since
2044 set (PartialArrayInLineChart_FORCE_SERIAL TRUE) # since
2045 set (PickCenter_FORCE_SERIAL TRUE) # since
this involves picking
2046 set (Plot3DReader_FORCE_SERIAL TRUE) # since
2047 set (PlotDataOverTime-NonDistributed_FORCE_SERIAL TRUE) # since
2048 set (PlotMatrixViewArraySelection_FORCE_SERIAL TRUE) # since
2049 set (PlotMatrixViewDensityMaps_FORCE_SERIAL TRUE) # since
2050 set (PlotMatrixViewParameters_FORCE_SERIAL TRUE) # since
2051 set (PointChartView_FORCE_SERIAL TRUE) # since
2052 set (PolygonCellSelection_FORCE_SERIAL TRUE)
2053 set (PolygonPointSelection_FORCE_SERIAL TRUE)
2054 set (PropertyLink_FORCE_SERIAL TRUE)
2055 set (PropertyContextMenu_FORCE_SERIAL TRUE)
2056 set (ProxyCategoriesConfiguration_FORCE_SERIAL TRUE) # since
this uses popup-line edit
2057 set (ProxyCategoriesToolbar_FORCE_SERIAL TRUE)
2058 set (PythonCalculatorInput_FORCE_SERIAL TRUE) # since
2059 set (QuickLaunchCreateProxy_FORCE_SERIAL TRUE)
2060 set (QuickLaunchNavigation_FORCE_SERIAL TRUE)
2061 set (QuickLaunchRequest_FORCE_SERIAL TRUE)
2062 set (ReadPartitionedCGNS_FORCE_SERIAL TRUE) # since
2063 set (RecentFiles_FORCE_SERIAL TRUE) # use
key events
2064 set (RecentFilesHardFilename_FORCE_SERIAL TRUE) # use
key events
2065 set (SPTimeseries_FORCE_SERIAL TRUE) # since
2066 set (SaveColorMap_FORCE_SERIAL TRUE) # Uses
inline edit popups
2067 set (SaveCSV_FORCE_SERIAL TRUE) # since
2068 set (SaveMultiBlockCSV_FORCE_SERIAL TRUE) # since
2069 set (SaveTSV_FORCE_SERIAL TRUE) # since
2070 set (SaveTXT_FORCE_SERIAL TRUE) # since
2071 set (SelectionLinkHistogram_FORCE_SERIAL TRUE) # since
2072 set (SelectionLinkParallelCoordinatesView_FORCE_SERIAL TRUE) # since
2073 set (SeriesPresetRegexp_FORCE_SERIAL TRUE) # since
2074 set (SeriesPreset_FORCE_SERIAL TRUE) # since
2075 set (SettingsOverrideDomain_FORCE_SERIAL TRUE) # since
2076 set (ShaderReplacements_FORCE_SERIAL TRUE)
2077 set (SimpleInteraction_FORCE_SERIAL TRUE) # since
2078 set (StringInLineChartView_FORCE_SERIAL TRUE) # since
2079 set (TableHistogram_FORCE_SERIAL TRUE) # since
2080 set (TestHTGHoverOnCell_FORCE_SERIAL TRUE) # since
this uses QTooltip and QShortcut
2081 set (TestIsoVolume_FORCE_SERIAL TRUE) # since
2082 set (TestPythonView_FORCE_SERIAL TRUE) # Seems to work better in serial.
2083 set (TextSourceBorder_FORCE_SERIAL TRUE) # Seems to work better in serial
2084 set (ThresholdTable_FORCE_SERIAL TRUE) # since
2085 set (TimeKeeper_FORCE_SERIAL TRUE) # since
2086 set (TooltipCopy_FORCE_SERIAL TRUE) # since
2087 set (TooltipHideInfo_FORCE_SERIAL TRUE) # since
2088 set (TraceExportAndSaveData_FORCE_SERIAL TRUE) # since
2089 set (TraceMultiViews_FORCE_SERIAL TRUE) # Seems to works better in serial
2090 set (XYBarChart_FORCE_SERIAL TRUE) # since
2091 set (glTFReaderAnimatedMorphing_FORCE_SERIAL TRUE) # since
2092 set (glTFReaderToggleDeformation_FORCE_SERIAL TRUE) # since
2095 # On macOS, global menu access can interfere with widget paths. 2096 set (MultiBlockInspectorMultiBlock_FORCE_SERIAL TRUE)
2097 # Context menu access
2098 set (FileDialogOpenInteractClose_FORCE_SERIAL TRUE)
2101 # those tests load and remove macros. Serial avoid side effects 2102 set(MacroEditor_FORCE_SERIAL TRUE)
2103 set(IconBrowser_FORCE_SERIAL TRUE)
2104 set(PythonResetSessionMacro_FORCE_SERIAL TRUE)
2106 # We don
't support volume rendering of image data in data server & render server mode 2107 set(AdaptiveResampleToImage_DISABLE_CRS TRUE) 2108 set(LoadSaveStateVolume_DISABLE_CRS TRUE) 2109 set(SeparatedColorMapOpacity_DISABLE_CRS TRUE) 2110 set(VolumeReprTwoIndepComp_DISABLE_CRS TRUE) 2111 set(VolumeCrop_DISABLE_CRS TRUE) 2112 set(VolumeSliceBlendMode_DISABLE_CRS TRUE) 2113 set(VolumeIsosurfaceBlendMode_DISABLE_CRS TRUE) 2114 set(PointVolumeInterpolator_DISABLE_CRS TRUE) 2116 # Distributed AMR rendering is broken 2117 # https://gitlab.kitware.com/paraview/paraview/-/issues/23096 2118 set(AMRRectGridSurface_DISABLE_CS TRUE) 2119 set(AMRRectGridSurface_DISABLE_CRS TRUE) 2120 set(AMRUniformGridSurface_DISABLE_CS TRUE) 2121 set(AMRUniformGridSurface_DISABLE_CRS TRUE) 2123 # Set properties for CTH tests 2124 set(CTHAMRContour_DISABLE_CS TRUE) 2125 set(CTHAMRContour_DISABLE_CRS TRUE) 2126 set(CTHAMRDualClip_DISABLE_CS TRUE) 2127 set(CTHAMRDualClip_DISABLE_CRS TRUE) 2128 set(CTHAMRClip_DISABLE_CS TRUE) 2129 set(CTHAMRClip_DISABLE_CRS TRUE) 2130 set(CTHAMRMaterialInterfaceFilter_DISABLE_CS TRUE) 2131 set(CTHAMRMaterialInterfaceFilter_DISABLE_CRS TRUE) 2133 # Since the test uses surface-selection, it cannot work in render-server mode. 2134 set(XYChart_DISABLE_CRS TRUE) 2135 # this uses charts: nb of points changes in client server, so graphs differs 2136 set(LinkViews_DISABLE_CS TRUE) 2137 set(LinkViews_DISABLE_CRS TRUE) 2139 # Test needs to load a plugin, the test only records that for the 2141 set (SteeringDataGenerator_DISABLE_CS TRUE) 2142 set (SteeringDataGenerator_DISABLE_CRS TRUE) 2144 set (PlotOverTimeAutoApply_DISABLE_CRS TRUE) # since this uses surface selection. 2145 # The ExportLinePlotToTSV test uses the same image baseline as the ExportLinePlotToCSV test 2146 set (ExportLinePlotToTSV_BASELINE ExportLinePlotToCSV.png) 2148 # ExportSceneSpreadSheetView2 won't work in parallel CS because of ghost cells
2149 # than cannot be processed by TableToStructuredGrid.
2150 set(ExportSceneSpreadSheetView2_DISABLE_CS TRUE)
2151 set(ExportSceneSpreadSheetView2_DISABLE_CRS TRUE)
2153 # Cannot support CRS since we
do volume rendering of
image data 2155 set (RemoteRendering_DISABLE_CRS TRUE)
2156 set (VolumeRenderingWithContour_DISABLE_CRS TRUE)
2157 set (VolumeNoMapScalars_DISABLE_CRS TRUE)
2158 set (MultiBlockVolumeRendering_DISABLE_CRS TRUE)
2159 set (ColorOpacityEditorFreehandDrawing_DISABLE_CRS TRUE)
2161 # Composite Surface Selection is currently broken in everything but builtin 2162 SET (CompositeSurfaceSelection_DISABLE_CS TRUE)
2163 SET (CompositeSurfaceSelection_DISABLE_CRS TRUE)
2165 # Clip test has object picking which is not supported in client-render-server 2167 SET (Clip_DISABLE_CRS TRUE)
2169 # Image and rectilinear grid volume rendering not supported in CRS mode. 2170 set (ImageVolumeRendering_DISABLE_CRS TRUE)
2171 set (RectilinearVolumeRendering_DISABLE_CRS TRUE)
2173 # The SaveTXT and SaveTSV tests use the same image baseline as the SaveCSV test 2174 SET (SaveTSV_BASELINE SaveCSV.png)
2175 SET (SaveTXT_BASELINE SaveCSV.png)
2177 # Disable some testing configurations for these tests. 2179 ## Disable ClientRenderServer tests for FFTOverTime. This is done since 2180 ## selection is not supported in render server mode esp. when number of render 2181 ## server processes is not the same as the data server processes 2182 set (FFTOverTime_DISABLE_CRS TRUE)
2184 # ColorEditorVolumeControls does volume rendering of structured
data which required remote
2185 # rendering in client-serve
mode.
2186 SET (ColorEditorVolumeControls_DISABLE_CS TRUE)
2187 SET (ColorEditorVolumeControls_DISABLE_CRS TRUE)
2189 # ViewSettingsDialog, TextureUsages, LogoSourcesInChartViews and LogoSource use texture which are not supported in pvcrs mode. 2190 SET (ViewSettingsDialog_DISABLE_CRS TRUE)
2191 SET (TextureUsages_DISABLE_CRS TRUE)
2192 SET (LogoSourcesInChartViews_DISABLE_CRS TRUE)
2193 SET (LogoSource_DISABLE_CRS TRUE)
2195 # MultiBlockAttributes1 requires selection which doesn't work on pvcrs 2196 SET (MultiBlockAttributes1_DISABLE_CRS TRUE)
2198 # Due to issue #20657, the tangents are not sent in pvcrs mode 2199 # event using remote rendering 2200 # We can remove this when issue #20657 is resolved 2201 SET (AnisotropyPBR_DISABLE_CRS TRUE)
2203 ## Disable ClientRenderServer tests for TransferFunction2D. This is done since 2204 ## image data delivery is not supported in render server mode 2205 SET (TransferFunction2D_DISABLE_CRS TRUE)
2206 SET (TransferFunction2DYScalars_DISABLE_CRS TRUE)
2207 SET (TransferFunction2DYScalarsEditor_DISABLE_CRS TRUE)
2208 SET (TransferFunction2DYScalarsEditorA_DISABLE_CRS TRUE)
2209 SET (TransferFunction2DYScalarsEditorB_DISABLE_CRS TRUE)
2211 # Plugins are only built as shared libraries. 2213 SET (NiftiReaderWriterPlugin_DISABLE_C TRUE)
2215 # There should be a client server specific version of this test. 2216 SET (NiftiReaderWriterPlugin_DISABLE_CS TRUE)
2217 SET (NiftiReaderWriterPlugin_DISABLE_CRS TRUE)
2219 # Make these tests use reverse connection. 2220 SET (CutMulti_REVERSE_CONNECT TRUE)
2222 # Selection not supported in CRS and is needed for this test. 2223 set (ResetToVisibleRange_DISABLE_CRS TRUE)
2225 # Molecules are not supported in client-serve modes, currently.
2226 #set (Molecule_DISABLE_CS TRUE)
2227 #set (Molecule_DISABLE_CRS TRUE) 2228 #set (MoleculeColoring_DISABLE_CS TRUE) 2229 #set (MoleculeColoring_DISABLE_CRS TRUE) 2231 # some glTF tests are not working in CS currently 2232 # https://gitlab.kitware.com/paraview/paraview/-/issues/20572 2233 set (glTFReaderToggleDeformation_DISABLE_CS TRUE)
2234 set (glTFReaderToggleDeformation_DISABLE_CRS TRUE)
2235 set (glTFReaderMultipleScenes_DISABLE_CS TRUE)
2236 set (glTFReaderMultipleScenes_DISABLE_CRS TRUE)
2237 set (glTFReaderMultipleAnimations_DISABLE_CS TRUE)
2238 set (glTFReaderMultipleAnimations_DISABLE_CRS TRUE)
2240 # pvd writer/reader has issues creating directories or filenames with punctuation 2241 # https://gitlab.kitware.com/paraview/paraview/-/issues/22361 2243 set (RecentFilesHardFilename_DISABLE_CS TRUE)
2244 set (RecentFilesHardFilename_DISABLE_CRS TRUE)
2247 # tests involve pointCount checks, so not reliable in CS modes. 2248 set (PlotOverLine_3d_DISABLE_CS TRUE)
2249 set (PlotOverLine_3d_DISABLE_CRS TRUE)
2250 set (PlotOverLine_htg_DISABLE_CS TRUE)
2251 set (PlotOverLine_htg_DISABLE_CRS TRUE)
2252 set (PlotOverLine_surface_DISABLE_CS TRUE)
2253 set (PlotOverLine_surface_DISABLE_CRS TRUE)
2255 # CGNS BC and Surface patches not supported in parallel 2256 set(ReadCGNSBCDataset_DISABLE_CS TRUE)
2257 set(ReadCGNSBCDataset_DISABLE_CRS TRUE)
2258 set(CONVERGECFDCGNSReader_DISABLE_CS TRUE)
2259 set(CONVERGECFDCGNSReader_DISABLE_CRS TRUE)
2260 set(CGNSReaderSurfacePatches_DISABLE_CS TRUE)
2261 set(CGNSReaderSurfacePatches_DISABLE_CRS TRUE)
2263 # RegionIds is not implemented for Distributed context 2264 set (RegionIds_DISABLE_CS TRUE)
2265 set (RegionIds_DISABLE_CRS TRUE)
2267 # AxisAlignedTransform is not implemented for Distributed context yet : issue (https://gitlab.kitware.com/paraview/paraview/-/issues/22949) 2268 set (AxisAlignedTransform_DISABLE_CS TRUE)
2269 set (AxisAlignedTransform_DISABLE_CRS TRUE)
2271 # Add image method overrides for tests. 2273 # images with text need loose method 2274 set(4AxesContextView_METHOD LOOSE_VALID)
2275 set(BoxClipStateBackwardsCompatibility_METHOD LOOSE_VALID)
2276 set(ChartAxisRangeAndLabels_METHOD LOOSE_VALID)
2277 set(ChartLoadNoVariables_METHOD LOOSE_VALID)
2278 set(ColorOpacityEditorRangeHandles_METHOD LOOSE_VALID)
2279 set(ExodusModeShapes_METHOD LOOSE_VALID)
2280 set(ExportLinePlotToCSV_METHOD LOOSE_VALID)
2281 set(ExportLinePlotToTSV_METHOD LOOSE_VALID)
2282 set(FeatureEdgesHTGNoMask_METHOD LOOSE_VALID)
2283 set(HistogramSelection_METHOD LOOSE_VALID)
2284 set(LineChartSelection_METHOD LOOSE_VALID)
2285 set(OrthographicView_METHOD LOOSE_VALID)
2286 set(PlotGlobalVariablesOverTime_METHOD LOOSE_VALID)
2287 set(PointChartView_METHOD LOOSE_VALID)
2288 set(PolarAxesRasterizedText_METHOD LOOSE_VALID)
2289 set(PolarAxesRemoteRendering_METHOD LOOSE_VALID)
2290 set(Preview_METHOD LOOSE_VALID)
2291 set(ProgrammableAnnotation_METHOD LOOSE_VALID)
2292 set(ReloadExodusFile_METHOD LOOSE_VALID)
2293 set(ReloadAMReXGrid_METHOD LOOSE_VALID)
2294 set(SaveLargeScreenshot_METHOD LOOSE_VALID)
2295 set(SeriesPresetRegexp_METHOD LOOSE_VALID)
2296 set(SimpleInteraction_METHOD LOOSE_VALID)
2297 set(SortLineChartData_METHOD LOOSE_VALID)
2298 set(SpreadSheet2_METHOD LOOSE_VALID)
2299 set(TestParallelProjectionAnnotations_METHOD LOOSE_VALID)
2300 set(TileDisplaySplitView-1x1_METHOD LOOSE_VALID)
2301 set(TileDisplaySplitView-2x1_METHOD LOOSE_VALID)
2302 set(TileDisplaySplitView-2x2_METHOD LOOSE_VALID)
2303 set(TileDisplaySplitView-3x1_METHOD LOOSE_VALID)
2304 set(TransferFunction2DEditor_METHOD LOOSE_VALID)
2305 set(TransferFunction2DYScalars_METHOD LOOSE_VALID)
2306 set(XYChart_METHOD LOOSE_VALID)
2307 set(XYHistogram_METHOD LOOSE_VALID)
2309 set(TESTS_WITH_MULTI_SERVERS_3
2310 TestMultiServer3.xml
2313 # ResampleToHyperTreeGrid only works in client
mode 2315 TEST_SCRIPTS ResampleToHyperTreeGrid.xml ResampleImageToHyperTreeGrid.xml
2318 # RandomAttributes generate different results depending on the data 2319 # distribution so we enable it on client mode only for now 2320 # See https://gitlab.kitware.com/paraview/paraview/-/issues/22596 2322 TEST_SCRIPTS RandomAttributesHTG.xml
2325 # FDS Reader has issues in client-server mode. 2326 # See https://gitlab.kitware.com/paraview/paraview/-/issues/22687 2328 TEST_SCRIPTS TestFDSReader.xml
2331 # TODO: remote rendering tests and reverse connect tests. 2334 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2335 TEST_SCRIPTS ${TESTS_WITH_MULTI_SERVERS_3})
2338 TEST_SCRIPTS TileDisplaySplitView.xml)
2340 TEST_SCRIPTS LinkCameraFromView.xml)
2341 if (PARAVIEW_USE_MPI)
2343 TEST_SCRIPTS TileDisplaySplitView.xml)
2345 TEST_SCRIPTS TileDisplaySplitView.xml)
2347 TEST_SCRIPTS TileDisplaySplitView.xml)
2351 TEST_SCRIPTS TestCAVE.xml TestCAVEVolumeRendering.xml)
2354 TEST_SCRIPTS TestCAVE.xml)
2357 TEST_SCRIPTS TestCAVE2DAnnotations.xml)
2360 TEST_SCRIPTS TestIndependentViewers.xml)
2362 #------------------------------------------------------------------ 2363 # Add tests that test command line arguments (among other things). 2364 #------------------------------------------------------------------ 2365 if (TARGET ParaView::paraview)
2366 # The state file need to point to the correct data file. We do that by 2367 # configuring the state file. 2369 ARGS
"--state=${CMAKE_CURRENT_SOURCE_DIR}/exodusStateFile.3.14.1.pvsm" 2370 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2371 TEST_SCRIPTS LoadExodusStateFile.xml
2373 PARAVIEW_DATA_ROOT=${paraview_test_data_directory_output}
2377 ARGS
"--state=${CMAKE_CURRENT_SOURCE_DIR}/boxClip.5.6.pvsm" 2378 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2379 TEST_SCRIPTS BoxClipStateBackwardsCompatibility.xml)
2382 ARGS
"--data=${paraview_test_data_directory_output}/Testing/Data/FileSeries/blow..vtk" 2383 TEST_SCRIPTS CheckDataArgumentsWithFileSeries.xml
2387 ARGS
" ${paraview_test_data_directory_output}/Testing/Data/FileSeries/blow..vtk" 2388 TEST_SCRIPTS CheckPositionalArgumentsWithFileSeries.xml
2391 if (PARAVIEW_USE_PYTHON)
2392 # Test whether or not we can load a Python state file with the --state 2393 # command line option as well as loading a Python state file that was 2394 # generated with PV 5.4.1. Loading the 5.4.1 Python state file checks 2395 # on backwards compatibility. 2397 ARGS
"--state=${CMAKE_CURRENT_SOURCE_DIR}/Calculator54State.py" 2398 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2399 TEST_SCRIPTS Calculator54State.xml)
2402 #---------------------------------------------------------------------- 2403 # Add test to test stereo rendering modes. 2405 CLIENT_ARGS --stereo --stereo-
type=Interlaced
2406 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2407 TEST_SCRIPTS StereoInterlaced.xml)
2409 CLIENT_ARGS --stereo --stereo-
type=Interlaced
2410 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2411 TEST_SCRIPTS StereoInterlaced.xml)
2413 CLIENT_ARGS --stereo --stereo-
type=Interlaced
2414 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2415 TEST_SCRIPTS StereoInterlaced.xml)
2417 CLIENT_ARGS --stereo --stereo-
type=SplitViewportHorizontal
2418 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2419 TEST_SCRIPTS StereoSplitViewportHorizontal.xml)
2421 CLIENT_ARGS --stereo --stereo-
2422 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2423 TEST_SCRIPTS StereoSplitViewportHorizontal.xml)
2425 CLIENT_ARGS --stereo --stereo-
2426 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2427 TEST_SCRIPTS StereoSplitViewportHorizontal.xml)
2430 #---------------------------------------------------------------------- 2431 # Very small texture size limits on mesa cause error messages for some tests that 2432 # include coloring by cell data. Let's skip those. 2433 set(texture_buffer_exceeding_hardware_tests
2435 CONVERGECFDReaderWithVisItBridge
2436 TestGroupDataFromTimeSeries
2440 foreach(test_name IN LISTS texture_buffer_exceeding_hardware_tests)
2441 foreach(prefix IN ITEMS pv pvcs pvcrs)
2442 if (TEST
"${prefix}.${test_name}")
2443 set_property(TEST
"${prefix}.${test_name}" APPEND PROPERTY
2444 SKIP_REGULAR_EXPRESSION
"Attempt to use a texture buffer exceeding your hardware")
2449 # Server Connection specific tests 2451 if(NOT WIN32) # On windows, QtTesting is not able to press the connection dialog buttons
2453 SMTESTING_ALLOW_ERRORS
2455 TEST_SCRIPTS ServerConnectTimeout.xml)
2459 "${CMAKE_CURRENT_SOURCE_DIR}/configuredServer.pvsc.in" 2460 "${CMAKE_CURRENT_BINARY_DIR}/configuredServer.pvsc" @ONLY)
2463 "${CMAKE_CURRENT_SOURCE_DIR}/ServerConnectConfigured.xml.in" 2464 "${CMAKE_CURRENT_BINARY_DIR}/ServerConnectConfigured.xml" @ONLY)
2468 TEST_SCRIPTS ${CMAKE_CURRENT_BINARY_DIR}/ServerConnectConfigured.xml)
2470 if (PARAVIEW_PLUGIN_ENABLE_ArrowGlyph)
2472 "${CMAKE_CURRENT_SOURCE_DIR}/ServerConnectPluginLoad.xml.in" 2473 "${CMAKE_CURRENT_BINARY_DIR}/ServerConnectPluginLoad.xml" @ONLY)
2477 TEST_SCRIPTS ${CMAKE_CURRENT_BINARY_DIR}/ServerConnectPluginLoad.xml)
2480 # PropertyPanelVisibilitiesOverride test requires a configuration file. 2481 # Use a custom TEST_DIRECTORY for that: this overrides user config dir when testing 2482 # (see pqCoreUtilities::getParaViewUserDirectory). Copy config in it. 2483 set (PropertyPanelVisibilitiesOverrideDir
"${CMAKE_CURRENT_BINARY_DIR}/PropertyPanelVisibilitiesOverride")
2484 file (MAKE_DIRECTORY ${PropertyPanelVisibilitiesOverrideDir})
2486 "${CMAKE_CURRENT_SOURCE_DIR}/PropertyPanelVisibilities.json.in" 2487 "${PropertyPanelVisibilitiesOverrideDir}/PropertyPanelVisibilities.json" @ONLY)
2489 TEST_SCRIPTS ${CMAKE_CURRENT_SOURCE_DIR}/PropertyPanelVisibilitiesOverride.xml
2490 TEST_DIRECTORY ${PropertyPanelVisibilitiesOverrideDir}
2493 # Adds a test to check the `--plugins` works with `xml` plugins too.
2494 paraview_add_client_tests(
2495 ARGS --plugins=ReaderNamePlugin
"--plugin-search-paths=${paraview_test_data_directory_output}/Testing/Data" 2496 TEST_SCRIPTS PluginCommandLine.xml)
2499 # Regression test for paraview/paraview#21133 (custom shortcuts not 2500 # loaded on startup). Runs ParaView once with a settings file that 2501 # already has a custom shortcut configured and verifies it is restored. 2502 # Relies on QSettings(IniFormat, UserScope) honoring $HOME, which is only 2503 # true on macOS/Linux. Because the Ctrl+L shortcut is platform-dependent, 2504 # we test only on macOS which renders the shortcut as ⌘L in the UI. 2505 add_test(
NAME pv.CustomShortcutsPersistence
2506 COMMAND ${CMAKE_COMMAND}
2507 -DPARAVIEW_EXECUTABLE:FILEPATH=$<TARGET_FILE:ParaView::paraview>
2508 -DTEST_SCRIPT:FILEPATH=${CMAKE_CURRENT_SOURCE_DIR}/CustomShortcutsPersistence.xml
2509 -DINI_FIXTURE:FILEPATH=${CMAKE_CURRENT_SOURCE_DIR}/CustomShortcutsPersistence.ini
2510 -DTEMPORARY_DIR:PATH=${CMAKE_BINARY_DIR}/Testing/Temporary
2511 -P ${CMAKE_CURRENT_SOURCE_DIR}/CustomShortcutsPersistenceDriver.cmake
2513 set_tests_properties(pv.CustomShortcutsPersistence PROPERTIES
function paraview_add_client_tests()
function paraview_add_tile_display_tests(width, height)
macro ADD_CATALYST_LIVE_TEST(test_name, duration, command_line_connect_command)
function paraview_add_client_server_tests()
function paraview_add_cave_tests(num_ranks, config)
function paraview_add_multi_server_tests(count)
#define BUILD_SHARED_LIBS
function paraview_add_client_server_render_tests()
