#include <netcdf_dispatch.h>
Public Attributes | |
| int | model |
| int | dispatch_version |
| int(* | create )(const char *path, int cmode, size_t initialsz, int basepe, size_t *chunksizehintp, void *parameters, const struct NC_Dispatch *table, int ncid) |
| int(* | open )(const char *path, int mode, int basepe, size_t *chunksizehintp, void *parameters, const struct NC_Dispatch *table, int ncid) |
| int(* | redef )(int) |
| int(* | _enddef )(int, size_t, size_t, size_t, size_t) |
| int(* | sync )(int) |
| int(* | abort )(int) |
| int(* | close )(int, void *) |
| int(* | set_fill )(int, int, int *) |
| int(* | inq_format )(int, int *) |
| int(* | inq_format_extended )(int, int *, int *) |
| int(* | inq )(int, int *, int *, int *, int *) |
| int(* | inq_type )(int, nc_type, char *, size_t *) |
| int(* | def_dim )(int, const char *, size_t, int *) |
| int(* | inq_dimid )(int, const char *, int *) |
| int(* | inq_dim )(int, int, char *, size_t *) |
| int(* | inq_unlimdim )(int ncid, int *unlimdimidp) |
| int(* | rename_dim )(int, int, const char *) |
| int(* | inq_att )(int, int, const char *, nc_type *, size_t *) |
| int(* | inq_attid )(int, int, const char *, int *) |
| int(* | inq_attname )(int, int, int, char *) |
| int(* | rename_att )(int, int, const char *, const char *) |
| int(* | del_att )(int, int, const char *) |
| int(* | get_att )(int, int, const char *, void *, nc_type) |
| int(* | put_att )(int, int, const char *, nc_type, size_t, const void *, nc_type) |
| int(* | def_var )(int, const char *, nc_type, int, const int *, int *) |
| int(* | inq_varid )(int, const char *, int *) |
| int(* | rename_var )(int, int, const char *) |
| int(* | get_vara )(int, int, const size_t *, const size_t *, void *, nc_type) |
| int(* | put_vara )(int, int, const size_t *, const size_t *, const void *, nc_type) |
| int(* | get_vars )(int, int, const size_t *, const size_t *, const ptrdiff_t *, void *, nc_type) |
| int(* | put_vars )(int, int, const size_t *, const size_t *, const ptrdiff_t *, const void *, nc_type) |
| int(* | get_varm )(int, int, const size_t *, const size_t *, const ptrdiff_t *, const ptrdiff_t *, void *, nc_type) |
| int(* | put_varm )(int, int, const size_t *, const size_t *, const ptrdiff_t *, const ptrdiff_t *, const void *, nc_type) |
| int(* | inq_var_all )(int ncid, int varid, char *name, nc_type *xtypep, int *ndimsp, int *dimidsp, int *nattsp, int *shufflep, int *deflatep, int *deflate_levelp, int *fletcher32p, int *contiguousp, size_t *chunksizesp, int *no_fill, void *fill_valuep, int *endiannessp, unsigned int *idp, size_t *nparamsp, unsigned int *params) |
| int(* | var_par_access )(int, int, int) |
| int(* | def_var_fill )(int, int, int, const void *) |
| int(* | show_metadata )(int) |
| int(* | inq_unlimdims )(int, int *, int *) |
| int(* | inq_ncid )(int, const char *, int *) |
| int(* | inq_grps )(int, int *, int *) |
| int(* | inq_grpname )(int, char *) |
| int(* | inq_grpname_full )(int, size_t *, char *) |
| int(* | inq_grp_parent )(int, int *) |
| int(* | inq_grp_full_ncid )(int, const char *, int *) |
| int(* | inq_varids )(int, int *nvars, int *) |
| int(* | inq_dimids )(int, int *ndims, int *, int) |
| int(* | inq_typeids )(int, int *ntypes, int *) |
| int(* | inq_type_equal )(int, nc_type, int, nc_type, int *) |
| int(* | def_grp )(int, const char *, int *) |
| int(* | rename_grp )(int, const char *) |
| int(* | inq_user_type )(int, nc_type, char *, size_t *, nc_type *, size_t *, int *) |
| int(* | inq_typeid )(int, const char *, nc_type *) |
| int(* | def_compound )(int, size_t, const char *, nc_type *) |
| int(* | insert_compound )(int, nc_type, const char *, size_t, nc_type) |
| int(* | insert_array_compound )(int, nc_type, const char *, size_t, nc_type, int, const int *) |
| int(* | inq_compound_field )(int, nc_type, int, char *, size_t *, nc_type *, int *, int *) |
| int(* | inq_compound_fieldindex )(int, nc_type, const char *, int *) |
| int(* | def_vlen )(int, const char *, nc_type base_typeid, nc_type *) |
| int(* | put_vlen_element )(int, int, void *, size_t, const void *) |
| int(* | get_vlen_element )(int, int, const void *, size_t *, void *) |
| int(* | def_enum )(int, nc_type, const char *, nc_type *) |
| int(* | insert_enum )(int, nc_type, const char *, const void *) |
| int(* | inq_enum_member )(int, nc_type, int, char *, void *) |
| int(* | inq_enum_ident )(int, nc_type, long long, char *) |
| int(* | def_opaque )(int, size_t, const char *, nc_type *) |
| int(* | def_var_deflate )(int, int, int, int, int) |
| int(* | def_var_fletcher32 )(int, int, int) |
| int(* | def_var_chunking )(int, int, int, const size_t *) |
| int(* | def_var_endian )(int, int, int) |
| int(* | def_var_filter )(int, int, unsigned int, size_t, const unsigned int *) |
| int(* | set_var_chunk_cache )(int, int, size_t, size_t, float) |
| int(* | get_var_chunk_cache )(int ncid, int varid, size_t *sizep, size_t *nelemsp, float *preemptionp) |
| int(* | inq_var_filter_ids )(int ncid, int varid, size_t *nfilters, unsigned int *filterids) |
| int(* | inq_var_filter_info )(int ncid, int varid, unsigned int id, size_t *nparams, unsigned int *params) |
| int(* | def_var_quantize )(int ncid, int varid, int quantize_mode, int nsd) |
| int(* | inq_var_quantize )(int ncid, int varid, int *quantize_modep, int *nsdp) |
| int(* | inq_filter_avail )(int ncid, unsigned id) |
Definition at line 34 of file netcdf_dispatch.h.
| int NC_Dispatch::model |
Definition at line 36 of file netcdf_dispatch.h.
| int NC_Dispatch::dispatch_version |
Definition at line 37 of file netcdf_dispatch.h.
| int(* NC_Dispatch::create) (const char *path, int cmode, size_t initialsz, int basepe, size_t *chunksizehintp, void *parameters, const struct NC_Dispatch *table, int ncid) |
Definition at line 39 of file netcdf_dispatch.h.
| int(* NC_Dispatch::open) (const char *path, int mode, int basepe, size_t *chunksizehintp, void *parameters, const struct NC_Dispatch *table, int ncid) |
Definition at line 42 of file netcdf_dispatch.h.
Definition at line 45 of file netcdf_dispatch.h.
Definition at line 46 of file netcdf_dispatch.h.
Definition at line 47 of file netcdf_dispatch.h.
Definition at line 48 of file netcdf_dispatch.h.
Definition at line 49 of file netcdf_dispatch.h.
Definition at line 51 of file netcdf_dispatch.h.
Definition at line 52 of file netcdf_dispatch.h.
Definition at line 54 of file netcdf_dispatch.h.
Definition at line 55 of file netcdf_dispatch.h.
Definition at line 57 of file netcdf_dispatch.h.
Definition at line 58 of file netcdf_dispatch.h.
Definition at line 59 of file netcdf_dispatch.h.
Definition at line 60 of file netcdf_dispatch.h.
Definition at line 61 of file netcdf_dispatch.h.
Definition at line 63 of file netcdf_dispatch.h.
Definition at line 64 of file netcdf_dispatch.h.
Definition at line 65 of file netcdf_dispatch.h.
Definition at line 66 of file netcdf_dispatch.h.
Definition at line 67 of file netcdf_dispatch.h.
Definition at line 68 of file netcdf_dispatch.h.
Definition at line 69 of file netcdf_dispatch.h.
Definition at line 72 of file netcdf_dispatch.h.
Definition at line 73 of file netcdf_dispatch.h.
Definition at line 74 of file netcdf_dispatch.h.
Definition at line 76 of file netcdf_dispatch.h.
Definition at line 77 of file netcdf_dispatch.h.
| int(* NC_Dispatch::get_vars) (int, int, const size_t *, const size_t *, const ptrdiff_t *, void *, nc_type) |
Definition at line 80 of file netcdf_dispatch.h.
| int(* NC_Dispatch::put_vars) (int, int, const size_t *, const size_t *, const ptrdiff_t *, const void *, nc_type) |
Definition at line 82 of file netcdf_dispatch.h.
| int(* NC_Dispatch::get_varm) (int, int, const size_t *, const size_t *, const ptrdiff_t *, const ptrdiff_t *, void *, nc_type) |
Definition at line 85 of file netcdf_dispatch.h.
| int(* NC_Dispatch::put_varm) (int, int, const size_t *, const size_t *, const ptrdiff_t *, const ptrdiff_t *, const void *, nc_type) |
Definition at line 87 of file netcdf_dispatch.h.
| int(* NC_Dispatch::inq_var_all) (int ncid, int varid, char *name, nc_type *xtypep, int *ndimsp, int *dimidsp, int *nattsp, int *shufflep, int *deflatep, int *deflate_levelp, int *fletcher32p, int *contiguousp, size_t *chunksizesp, int *no_fill, void *fill_valuep, int *endiannessp, unsigned int *idp, size_t *nparamsp, unsigned int *params) |
Definition at line 90 of file netcdf_dispatch.h.
Definition at line 99 of file netcdf_dispatch.h.
Definition at line 107 of file netcdf_dispatch.h.
Definition at line 108 of file netcdf_dispatch.h.
Definition at line 109 of file netcdf_dispatch.h.
Definition at line 111 of file netcdf_dispatch.h.
Definition at line 112 of file netcdf_dispatch.h.
Definition at line 113 of file netcdf_dispatch.h.
Definition at line 114 of file netcdf_dispatch.h.
Definition at line 115 of file netcdf_dispatch.h.
Definition at line 116 of file netcdf_dispatch.h.
Definition at line 117 of file netcdf_dispatch.h.
Definition at line 118 of file netcdf_dispatch.h.
Definition at line 119 of file netcdf_dispatch.h.
Definition at line 120 of file netcdf_dispatch.h.
Definition at line 121 of file netcdf_dispatch.h.
Definition at line 122 of file netcdf_dispatch.h.
Definition at line 124 of file netcdf_dispatch.h.
Definition at line 125 of file netcdf_dispatch.h.
| int(* NC_Dispatch::insert_array_compound) (int, nc_type, const char *, size_t, nc_type, int, const int *) |
Definition at line 126 of file netcdf_dispatch.h.
| int(* NC_Dispatch::inq_compound_field) (int, nc_type, int, char *, size_t *, nc_type *, int *, int *) |
Definition at line 128 of file netcdf_dispatch.h.
Definition at line 130 of file netcdf_dispatch.h.
Definition at line 131 of file netcdf_dispatch.h.
Definition at line 132 of file netcdf_dispatch.h.
Definition at line 133 of file netcdf_dispatch.h.
Definition at line 134 of file netcdf_dispatch.h.
Definition at line 135 of file netcdf_dispatch.h.
Definition at line 136 of file netcdf_dispatch.h.
Definition at line 137 of file netcdf_dispatch.h.
Definition at line 138 of file netcdf_dispatch.h.
Definition at line 139 of file netcdf_dispatch.h.
Definition at line 140 of file netcdf_dispatch.h.
Definition at line 141 of file netcdf_dispatch.h.
Definition at line 142 of file netcdf_dispatch.h.
Definition at line 143 of file netcdf_dispatch.h.
Definition at line 144 of file netcdf_dispatch.h.
| int(* NC_Dispatch::get_var_chunk_cache) (int ncid, int varid, size_t *sizep, size_t *nelemsp, float *preemptionp) |
Definition at line 145 of file netcdf_dispatch.h.
| int(* NC_Dispatch::inq_var_filter_ids) (int ncid, int varid, size_t *nfilters, unsigned int *filterids) |
Definition at line 148 of file netcdf_dispatch.h.
| int(* NC_Dispatch::inq_var_filter_info) (int ncid, int varid, unsigned int id, size_t *nparams, unsigned int *params) |
Definition at line 149 of file netcdf_dispatch.h.
Definition at line 151 of file netcdf_dispatch.h.
Definition at line 152 of file netcdf_dispatch.h.
Definition at line 154 of file netcdf_dispatch.h.
1.8.13 on Sat Aug 29 2026
