pqPropertiesPanel.h
4 #ifndef pqPropertiesPanel_h
5 #define pqPropertiesPanel_h
6
7 #include "pqComponentsModule.h"
9 #include <QWidget>
10
12 class pqOutputPort;
13 class pqPipelineSource;
14 class pqPropertyWidget;
15 class pqProxy;
16 class pqView;
17 class vtkSMProperty;
18 class vtkSMProxy;
32 class PQCOMPONENTS_EXPORT pqPropertiesPanel : public QWidget
33 {
34  Q_OBJECT
35  Q_PROPERTY(int panelMode READ panelMode WRITE setPanelMode);
36  typedef QWidget Superclass;
37
38 public:
39  pqPropertiesPanel(QWidget* parent = nullptr);
40  ~pqPropertiesPanel() override;
41
45  pqView* view() const;
46
51  static int suggestedMargin() { return 0; }
52  static QMargins suggestedMargins() { return QMargins(0, 0, 0, 0); }
53  static int suggestedHorizontalSpacing() { return 4; }
54  static int suggestedVerticalSpacing() { return 4; }
55
56  enum
57  {
58  SOURCE_PROPERTIES = 0x01,
59  DISPLAY_PROPERTIES = 0x02,
60  VIEW_PROPERTIES = 0x04,
61  ALL_PROPERTIES = SOURCE_PROPERTIES | DISPLAY_PROPERTIES | VIEW_PROPERTIES
62  };
63
67  void setPanelMode(int val);
68  int panelMode() const { return this->PanelMode; }
69
73  bool canApply();
74
78  bool canReset();
79
80 public Q_SLOTS: // NOLINT(readability-redundant-access-specifiers)
87  void apply();
88
95  void reset();
96
103  void showHelp();
104
111  void propertiesRestoreDefaults();
112
119  void propertiesSaveAsDefaults();
120
127  void displayRestoreDefaults();
128
135  void displaySaveAsDefaults();
136
143  void viewRestoreDefaults();
144
151  void viewSaveAsDefaults();
152
157  void setView(pqView*);
158
164  void setPipelineProxy(pqProxy*);
165
170  void setRepresentation(pqDataRepresentation*);
171 Q_SIGNALS:
175  void applied();
176
180  void applied(pqProxy*);
181
185  void viewChanged(pqView*);
186
187  void modified();
188  void resetDone();
189
193  void helpRequested(const QString& groupname, const QString& proxyType);
194
198  void deleteRequested(pqProxy* source);
199
205  void applyEnableStateChanged();
206
207 private Q_SLOTS:
212  void deleteProxy();
213
217  void proxyDeleted(pqProxy*);
218
223  void updatePanel();
224
228  void updateDisplayPanel();
229
233  void renderActiveView();
234
238  void sourcePropertyChanged(bool change_finished = true);
239  void sourcePropertyChangeAvailable() { this->sourcePropertyChanged(false); }
240
244  void updateButtonState();
245
250  void updateButtonEnableState();
251
252  void copyProperties();
253  void pasteProperties();
254  void copyDisplay();
255  void pasteDisplay();
256  void copyView();
257  void pasteView();
258
259 protected:
260  void updatePropertiesPanel(pqProxy* source);
261  void updateDisplayPanel(pqDataRepresentation* repr);
262  void updateViewPanel(pqView* view);
263
264 private:
265  class pqInternals;
266  friend class pqInternals;
267
268  pqInternals* Internals;
269  int PanelMode;
270
271  Q_DISABLE_COPY(pqPropertiesPanel)
272 };
273
274 #endif
pqDataRepresentation is the superclass for a display for a pqPipelineSource i.e.
pqOutputPort is a server manager model item for an output port of any pqPipelineSource item...
Definition: pqOutputPort.h:29
pqPropertyWidget represents a widget created for each property of a proxy on the pqPropertiesPanel (f...
methods used to obtain the recommended spacing and margins to be used for widgets.
pqPropertiesPanel is the default panel used by paraview to edit source properties and display propert...
This is a PQ abstraction of a generic view module.
Definition: pqView.h:26
source
This class represents any registered Server Manager proxy.
Definition: pqProxy.h:28
Definition: vtkSMProxy.h:140
PQ representation for a vtkSMProxy that can be involved in a pipeline.
