| std::string | DefaultComponentName (int componentNumber, int componentCount) |
| Return default component name for provided number and count. More... | |
| void | DeMangleArrayName (const std::string &mangledName, vtkDataSet *dataSet, std::string &demangledName, std::string &demangledComponentName) |
| Demangles a mangled string containing an array name and a component name. More... | |
| bool | ExtractComponent (vtkDataSetAttributes *dsa, const char *requested_name, const char *demangled_name, const char *demangled_component_name) |
| Extract a specific component for demangled name. More... | |
| void | CellDataToPointData (vtkDataSet *output, const char *name) |
| Convert a name cell data to point data and add to output. More... | |
| void | PointDataToCellData (vtkDataSet *output, const char *name) |
| Convert a name point data to cell data and add to output. More... | |
| bool | DoAnyNeededConversions (vtkDataSet *output, const char *requested_name, int fieldAssociation, const char *demangled_name, const char *demangled_component_name, bool checkOnly) |
| Do the conversion for the requested name and field association, on the provided output. More... | |
| bool | DoAnyNeededConversions (vtkInformation *info, vtkInformationInformationVectorKey *key, vtkDataSet *dataset, bool checkOnly) |
| Do the conversion for the requested info, on the provided output. More... | |
| bool | DoAnyNeededConversions (vtkInformation *info, vtkInformationInformationVectorKey *key, vtkDataObject *output, bool checkOnly=false) |
| Do the conversions for the requested info, on the provided output. More... | |
| std::string vtkPVPostFilterPrivateTools::DefaultComponentName | ( | int | componentNumber, |
| int | componentCount | ||
| void vtkPVPostFilterPrivateTools::DeMangleArrayName | ( | const std::string & | mangledName, |
| vtkDataSet * | dataSet, | ||
| std::string & | demangledName, | ||
| std::string & | demangledComponentName | ||
| bool vtkPVPostFilterPrivateTools::ExtractComponent | ( | vtkDataSetAttributes * | dsa, |
| const char * | requested_name, | ||
| const char * | demangled_name, | ||
| const char * | demangled_component_name | ||
| void vtkPVPostFilterPrivateTools::CellDataToPointData | ( | vtkDataSet * | output, |
| const char * | name | ||
| void vtkPVPostFilterPrivateTools::PointDataToCellData | ( | vtkDataSet * | output, |
| bool vtkPVPostFilterPrivateTools::DoAnyNeededConversions | ( | vtkDataSet * | output, |
| int | fieldAssociation, | ||
| const char * | demangled_component_name, | ||
| bool | checkOnly | ||
If checkOnly is true, only check if conversions would occur. Return true if conversion occurs, false otherwise.
| bool vtkPVPostFilterPrivateTools::DoAnyNeededConversions | ( | vtkInformation * | info, |
| vtkInformationInformationVectorKey * | key, | ||
| vtkDataSet * | dataset, | ||
| vtkDataObject * | output, | ||
| bool | checkOnly = false |
If output is composite, process all, if not, process as a dataset. If checkOnly is true, only check if conversions would occur. Return true if conversion occurs, false otherwise.
