Classes | Public Types | Public Member Functions | Public Attributes | Protected Types | Protected Member Functions | Static Protected Member Functions | Protected Attributes | List of all members
vtkXYChartRepresentation::vtkInternals Class Reference
#include <vtkXYChartRepresentationInternals.h>
Collaboration diagram for vtkXYChartRepresentation::vtkInternals:
struct  PlotInfo
class  PlotsMap
struct  TableInfo
typedef vtkXYChartRepresentation::MapOfTables MapOfTables
 vtkInternals ()
virtual ~vtkInternals ()=default
void HideAllPlots ()
 Hide all plots. More...
void RemoveAllPlots (vtkChartXY *chartXY)
 Destroy all vtkPlot instances. More...
virtual std::vector< std::string > GetSeriesRoles (const std::string &vtkNotUsed(tableName), const std::string &vtkNotUsed(columnName))
 Subclasses can override this method to assign a role for a specific data array in the input dataset. More...
virtual vtkPlot * NewPlot (vtkXYChartRepresentation *self, const std::string &tableName, const std::string &columnName, const std::string &role, unsigned int block=0)
 Add new plot. More...
virtual int GetInputArrayIndex (const std::string &vtkNotUsed(tableName), const std::string &vtkNotUsed(columnName), const std::string &vtkNotUsed(role))
virtual void UpdatePlots (vtkXYChartRepresentation *self, const MapOfTables &tables)
 Update i.e. More...
virtual void UpdatePlotProperties (vtkXYChartRepresentation *self)
 Update properties for plots in the chart. More...
virtual bool Export (vtkXYChartRepresentation *self, vtkAbstractChartExporter *exporter)
 Export visible plots to a CSV file. More...
Public Attributes
std::map< std::string, bool > SeriesVisibilities
std::map< std::string, int > SeriesOrder
std::map< std::string, int > LineThicknesses
std::map< std::string, int > LineStyles
std::map< std::string, vtkColor3d > Colors
std::map< std::string, double > Opacities
std::map< std::string, int > AxisCorners
std::map< std::string, int > MarkerStyles
std::map< std::string, double > MarkerSizes
std::map< std::string, std::string > Labels
std::map< std::string, bool > UseColorMapping
std::map< std::string, vtkScalarsToColors * > Lut
bool PreviousUseIndexForXAxis
std::string PreviousXAxisSeriesName
Protected Types
typedef std::map< std::string, PlotInfo > PlotsMapItem
template<class T >
T GetSeriesParameter (vtkXYChartRepresentation *self, const std::string &tableName, const std::string &columnName, const std::string &vtkNotUsed(role), const std::map< std::string, T > &parameter_map, const T default_value=T()) const
 Makes is easy to obtain a value for a series parameter, is set, else the default. More...
virtual bool UpdateSinglePlotProperties (vtkXYChartRepresentation *self, const std::string &tableName, const std::string &columnName, const std::string &role, vtkPlot *plot)
 Returns false for in-visible plots. More...
static const char * IndexColumnName ()
 Name of the index column added by AddIndexColumn(). More...
static vtkSmartPointer< vtkTable > AddIndexColumn (vtkTable *table)
 Returns a shallow copy of the table with an additional column, named IndexColumnName(), holding the row indices. More...
PlotsMap SeriesPlots
Definition at line 28 of file vtkXYChartRepresentationInternals.h.
◆ PlotsMapItem
Definition at line 46 of file vtkXYChartRepresentationInternals.h.
◆ MapOfTables
Definition at line 192 of file vtkXYChartRepresentationInternals.h.
◆ vtkInternals()
vtkXYChartRepresentation::vtkInternals::vtkInternals ( )
inline
Definition at line 215 of file vtkXYChartRepresentationInternals.h.
◆ ~vtkInternals()
virtual vtkXYChartRepresentation::vtkInternals::~vtkInternals ( )
virtualdefault
◆ GetSeriesParameter()
template<class T >
T vtkXYChartRepresentation::vtkInternals::GetSeriesParameter ( vtkXYChartRepresentation *  self,
const std::string &  tableName,
const std::string &  columnName,
const std::string &  vtkNotUsedrole,
const std::map< std::string, T > &  parameter_map,
const T  default_value = T()
) const
inlineprotected
This class supports two mechanisms for addresses series in a collection (multiblock) of tables: (1) using a name that combines the table name and the column name (using vtkChartRepresentation::GetDefaultSeriesLabel), or (2) using the column name alone. (1) is always checked before (2).
Definition at line 163 of file vtkXYChartRepresentationInternals.h.
◆ HideAllPlots()
void vtkXYChartRepresentation::vtkInternals::HideAllPlots ( )
inline
Hide all plots.
Definition at line 226 of file vtkXYChartRepresentationInternals.h.
◆ RemoveAllPlots()
void vtkXYChartRepresentation::vtkInternals::RemoveAllPlots ( vtkChartXY *  chartXY)
inline
Definition at line 232 of file vtkXYChartRepresentationInternals.h.
◆ GetSeriesRoles()
virtual std::vector<std::string> vtkXYChartRepresentation::vtkInternals::GetSeriesRoles ( const std::string &  vtkNotUsedtableName,
const std::string &  vtkNotUsedcolumnName
inlinevirtual
This is useful when multiple plots are to be created for a single series.
Definition at line 240 of file vtkXYChartRepresentationInternals.h.
◆ NewPlot()
virtual vtkPlot* vtkXYChartRepresentation::vtkInternals::NewPlot ( vtkXYChartRepresentation *  self,
const std::string &  role,
unsigned int  block = 0
inlinevirtual
Add new plot.
Definition at line 250 of file vtkXYChartRepresentationInternals.h.
◆ GetInputArrayIndex()
virtual int vtkXYChartRepresentation::vtkInternals::GetInputArrayIndex ( const std::string &  vtkNotUsedtableName,
const std::string &  vtkNotUsedcolumnName,
inlinevirtual
Definition at line 265 of file vtkXYChartRepresentationInternals.h.
◆ UpdatePlots()
virtual void vtkXYChartRepresentation::vtkInternals::UpdatePlots ( vtkXYChartRepresentation *  self,
const MapOfTables &  tables
inlinevirtual
Update i.e.
add/remove plots based on the data in the tables.
Definition at line 275 of file vtkXYChartRepresentationInternals.h.
◆ UpdatePlotProperties()
virtual void vtkXYChartRepresentation::vtkInternals::UpdatePlotProperties ( vtkXYChartRepresentation *  self)
inlinevirtual
Definition at line 371 of file vtkXYChartRepresentationInternals.h.
◆ Export()
virtual bool vtkXYChartRepresentation::vtkInternals::Export ( vtkXYChartRepresentation *  self,
vtkAbstractChartExporter *  exporter
inlinevirtual
Definition at line 420 of file vtkXYChartRepresentationInternals.h.
◆ IndexColumnName()
static const char* vtkXYChartRepresentation::vtkInternals::IndexColumnName ( )
inlinestaticprotected
Definition at line 459 of file vtkXYChartRepresentationInternals.h.
◆ AddIndexColumn()
static vtkSmartPointer<vtkTable> vtkXYChartRepresentation::vtkInternals::AddIndexColumn ( vtkTable *  table)
Definition at line 466 of file vtkXYChartRepresentationInternals.h.
◆ UpdateSinglePlotProperties()
virtual bool vtkXYChartRepresentation::vtkInternals::UpdateSinglePlotProperties ( vtkXYChartRepresentation *  self,
vtkPlot *  plot
inlineprotectedvirtual
Definition at line 487 of file vtkXYChartRepresentationInternals.h.
◆ SeriesPlots
PlotsMap vtkXYChartRepresentation::vtkInternals::SeriesPlots
Definition at line 151 of file vtkXYChartRepresentationInternals.h.
◆ SeriesVisibilities
std::map<std::string, bool> vtkXYChartRepresentation::vtkInternals::SeriesVisibilities
Definition at line 196 of file vtkXYChartRepresentationInternals.h.
◆ SeriesOrder
std::map<std::string, int> vtkXYChartRepresentation::vtkInternals::SeriesOrder
Definition at line 197 of file vtkXYChartRepresentationInternals.h.
◆ LineThicknesses
std::map<std::string, int> vtkXYChartRepresentation::vtkInternals::LineThicknesses
Definition at line 198 of file vtkXYChartRepresentationInternals.h.
◆ LineStyles
std::map<std::string, int> vtkXYChartRepresentation::vtkInternals::LineStyles
Definition at line 199 of file vtkXYChartRepresentationInternals.h.
◆ Colors
std::map<std::string, vtkColor3d> vtkXYChartRepresentation::vtkInternals::Colors
Definition at line 200 of file vtkXYChartRepresentationInternals.h.
◆ Opacities
std::map<std::string, double> vtkXYChartRepresentation::vtkInternals::Opacities
Definition at line 201 of file vtkXYChartRepresentationInternals.h.
◆ AxisCorners
std::map<std::string, int> vtkXYChartRepresentation::vtkInternals::AxisCorners
Definition at line 202 of file vtkXYChartRepresentationInternals.h.
◆ MarkerStyles
std::map<std::string, int> vtkXYChartRepresentation::vtkInternals::MarkerStyles
Definition at line 203 of file vtkXYChartRepresentationInternals.h.
◆ MarkerSizes
std::map<std::string, double> vtkXYChartRepresentation::vtkInternals::MarkerSizes
Definition at line 204 of file vtkXYChartRepresentationInternals.h.
◆ Labels
std::map<std::string, std::string> vtkXYChartRepresentation::vtkInternals::Labels
Definition at line 205 of file vtkXYChartRepresentationInternals.h.
◆ UseColorMapping
std::map<std::string, bool> vtkXYChartRepresentation::vtkInternals::UseColorMapping
Definition at line 206 of file vtkXYChartRepresentationInternals.h.
◆ Lut
std::map<std::string, vtkScalarsToColors*> vtkXYChartRepresentation::vtkInternals::Lut
Definition at line 207 of file vtkXYChartRepresentationInternals.h.
◆ PreviousUseIndexForXAxis
bool vtkXYChartRepresentation::vtkInternals::PreviousUseIndexForXAxis
Definition at line 212 of file vtkXYChartRepresentationInternals.h.
◆ PreviousXAxisSeriesName
std::string vtkXYChartRepresentation::vtkInternals::PreviousXAxisSeriesName
Definition at line 213 of file vtkXYChartRepresentationInternals.h.
