| void | Start () |
| | Start a new animation with the current set of inputs. More...
| void | WriteTime (double time) |
| | Write the current time step. More...
| void | Finish () |
| | Finish an animation by writing the collection file. More...
| void | AddRepresentation (vtkAlgorithm *, const char *groupname) |
| | Add/Remove representations. More...
| void | RemoveAllRepresentations () |
| const char * | GetDefaultFileExtension () override |
| | Get the default file extension for files written by this writer. More...
| | Add an input of this algorithm. More...
| int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| virtual int | GetPiece () |
| | Get/Set the piece number to write. More...
| virtual void | SetPiece (int) |
| virtual int | GetNumberOfPieces () |
| | Get/Set the number of pieces into which the inputs are split. More...
| virtual void | SetNumberOfPieces (int) |
| virtual int | GetGhostLevel () |
| | Get/Set the number of ghost levels to be written for unstructured data. More...
| virtual void | SetGhostLevel (int) |
| virtual void | SetWriteAllTimeSteps (int) |
| | When WriteAllTimeSteps is turned ON, the writer is executed once for each timestep available from its input. More...
| virtual int | GetWriteAllTimeSteps () |
| virtual void | WriteAllTimeStepsOn () |
| virtual void | WriteAllTimeStepsOff () |
| virtual int | GetWriteCollectionFile () |
| | Get/Set whether this instance will write the main collection file. More...
| virtual void | SetWriteCollectionFile (int flag) |
| vtkXMLWriter * | NewInstance () const |
| int | Write () |
| virtual void | SetByteOrder (int) |
| virtual int | GetByteOrder () |
| void | SetByteOrderToBigEndian () |
| void | SetByteOrderToLittleEndian () |
| virtual void | SetHeaderType (int) |
| virtual int | GetHeaderType () |
| void | SetHeaderTypeToUInt32 () |
| void | SetHeaderTypeToUInt64 () |
| virtual void | SetIdType (int) |
| virtual int | GetIdType () |
| void | SetIdTypeToInt32 () |
| void | SetIdTypeToInt64 () |
| virtual void | SetFileName (const char *) |
| virtual char * | GetFileName () |
| virtual void | SetWriteToOutputString (int) |
| virtual int | GetWriteToOutputString () |
| virtual void | WriteToOutputStringOn () |
| virtual void | WriteToOutputStringOff () |
| std::string | GetOutputString () |
| virtual void | SetCompressor (vtkDataCompressor *) |
| virtual vtkDataCompressor * | GetCompressor () |
| void | SetCompressorType (int compressorType) |
| void | SetCompressorTypeToNone () |
| void | SetCompressorTypeToZLib () |
| virtual void | SetBlockSize (size_t blockSize) |
| virtual size_t | GetBlockSize () |
| virtual void | SetDataMode (int) |
| virtual int | GetDataMode () |
| void | SetDataModeToAscii () |
| void | SetDataModeToBinary () |
| void | SetDataModeToAppended () |
| virtual void | SetEncodeAppendedData (int) |
| virtual int | GetEncodeAppendedData () |
| virtual void | EncodeAppendedDataOn () |
| virtual void | EncodeAppendedDataOff () |
| virtual int | GetNumberOfTimeSteps () |
| virtual void | SetNumberOfTimeSteps (int) |
| void | Start () |
| void | Stop () |
| void | WriteNextTime (double time) |
| void | Start () |
| void | Stop () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkXMLPVAnimationWriter () |
| | ~vtkXMLPVAnimationWriter () override |
| int | WriteInternal () override |
| void | AddFileName (const char *fileName) |
| void | DeleteFileNames () |
| void | DeleteFiles () |
| void | AddInputInternal (const char *group) |
| | vtkXMLPVDWriter () |
| | ~vtkXMLPVDWriter () override |
| int | WriteData () override |
| const char * | GetDataSetName () override |
| void | CreateWriters () |
| vtkXMLWriterBase * | GetWriter (int index) |
| void | SplitFileName () |
| const char * | GetFilePrefix () |
| const char * | GetFilePath () |
| void | AppendEntry (const char *entry) |
| void | DeleteAllEntries () |
| int | WriteCollectionFileIfRequested () |
| void | MakeDirectory (const char *name) |
| void | RemoveADirectory (const char *name) |
| virtual void | ProgressCallback (vtkAlgorithm *w) |
| void | ReportReferences (vtkGarbageCollector *) override |
| | vtkXMLWriter () |
| | ~vtkXMLWriter () |
| virtual void | SetDataStream (vtkOutputStream *) |
| virtual vtkOutputStream * | GetDataStream () |
| virtual int | GetDataSetMajorVersion () |
| virtual int | GetDataSetMinorVersion () |
| vtkDataSet * | GetInputAsDataSet () |
| virtual int | StartFile () |
| virtual void | WriteFileAttributes () |
| virtual int | EndFile () |
| void | DeleteAFile () |
| void | DeleteAFile (const char *name) |
| virtual int | WritePrimaryElement (ostream &os, vtkIndent indent) |
| virtual void | WritePrimaryElementAttributes (ostream &os, vtkIndent indent) |
| void | StartAppendedData () |
| void | EndAppendedData () |
| vtkTypeInt64 | ReserveAttributeSpace (const char *attr, size_t length=20) |
| vtkTypeInt64 | GetAppendedDataOffset () |
| void | WriteAppendedDataOffset (vtkTypeInt64 streamPos, vtkTypeInt64 &lastoffset, const char *attr=0) |
| void | ForwardAppendedDataOffset (vtkTypeInt64 streamPos, vtkTypeInt64 offset, const char *attr=0) |
| void | ForwardAppendedDataDouble (vtkTypeInt64 streamPos, double value, const char *attr) |
| int | WriteScalarAttribute (const char *name, int data) |
| int | WriteScalarAttribute (const char *name, float data) |
| int | WriteScalarAttribute (const char *name, double data) |
| int | WriteVectorAttribute (const char *name, int length, int *data) |
| int | WriteVectorAttribute (const char *name, int length, float *data) |
| int | WriteVectorAttribute (const char *name, int length, double *data) |
| int | WriteDataModeAttribute (const char *name) |
| int | WriteWordTypeAttribute (const char *name, int dataType) |
| int | WriteStringAttribute (const char *name, const char *value) |
| bool | WriteInformation (vtkInformation *info, vtkIndent indent) |
| void | WriteArrayHeader (vtkAbstractArray *a, vtkIndent indent, const char *alternateName, int writeNumTuples, int timestep) |
| virtual void | WriteArrayFooter (ostream &os, vtkIndent indent, vtkAbstractArray *a, int shortFormat) |
| virtual void | WriteArrayInline (vtkAbstractArray *a, vtkIndent indent, const char *alternateName=0, int writeNumTuples=0) |
| virtual void | WriteInlineData (vtkAbstractArray *a, vtkIndent indent) |
| void | WriteArrayAppended (vtkAbstractArray *a, vtkIndent indent, OffsetsManager &offs, const char *alternateName=0, int writeNumTuples=0, int timestep=0) |
| int | WriteAsciiData (vtkAbstractArray *a, vtkIndent indent) |
| int | WriteBinaryData (vtkAbstractArray *a) |
| int | WriteBinaryDataInternal (vtkAbstractArray *a) |
| void | WriteArrayAppendedData (vtkAbstractArray *a, vtkTypeInt64 pos, vtkTypeInt64 &lastoffset) |
| void | WriteFieldData (vtkIndent indent) |
| void | WriteFieldDataInline (vtkFieldData *fd, vtkIndent indent) |
| void | WritePointDataInline (vtkPointData *pd, vtkIndent indent) |
| void | WriteCellDataInline (vtkCellData *cd, vtkIndent indent) |
| void | WriteFieldDataAppended (vtkFieldData *fd, vtkIndent indent, OffsetsManagerGroup *fdManager) |
| void | WriteFieldDataAppendedData (vtkFieldData *fd, int timestep, OffsetsManagerGroup *fdManager) |
| void | WritePointDataAppended (vtkPointData *pd, vtkIndent indent, OffsetsManagerGroup *pdManager) |
| void | WritePointDataAppendedData (vtkPointData *pd, int timestep, OffsetsManagerGroup *pdManager) |
| void | WriteCellDataAppended (vtkCellData *cd, vtkIndent indent, OffsetsManagerGroup *cdManager) |
| void | WriteCellDataAppendedData (vtkCellData *cd, int timestep, OffsetsManagerGroup *cdManager) |
| void | WriteAttributeIndices (vtkDataSetAttributes *dsa, char **names) |
| void | WritePointsAppended (vtkPoints *points, vtkIndent indent, OffsetsManager *manager) |
| void | WritePointsAppendedData (vtkPoints *points, int timestep, OffsetsManager *pdManager) |
| void | WritePointsInline (vtkPoints *points, vtkIndent indent) |
| void | WriteCoordinatesInline (vtkDataArray *xc, vtkDataArray *yc, vtkDataArray *zc, vtkIndent indent) |
| void | WriteCoordinatesAppended (vtkDataArray *xc, vtkDataArray *yc, vtkDataArray *zc, vtkIndent indent, OffsetsManagerGroup *coordManager) |
| void | WriteCoordinatesAppendedData (vtkDataArray *xc, vtkDataArray *yc, vtkDataArray *zc, int timestep, OffsetsManagerGroup *coordManager) |
| void | WritePPointData (vtkPointData *pd, vtkIndent indent) |
| void | WritePCellData (vtkCellData *cd, vtkIndent indent) |
| void | WritePPoints (vtkPoints *points, vtkIndent indent) |
| void | WritePArray (vtkAbstractArray *a, vtkIndent indent, const char *alternateName=0) |
| void | WritePCoordinates (vtkDataArray *xc, vtkDataArray *yc, vtkDataArray *zc, vtkIndent indent) |
| int | WriteBinaryDataBlock (unsigned char *in_data, size_t numWords, int wordType) |
| void | PerformByteSwap (void *data, size_t numWords, size_t wordSize) |
| int | CreateCompressionHeader (size_t size) |
| int | WriteCompressionBlock (unsigned char *data, size_t size) |
| int | WriteCompressionHeader () |
| size_t | GetWordTypeSize (int dataType) |
| const char * | GetWordTypeName (int dataType) |
| size_t | GetOutputWordTypeSize (int dataType) |
| char ** | CreateStringArray (int numStrings) |
| void | DestroyStringArray (int numStrings, char **strings) |
| virtual void | GetProgressRange (float range[2]) |
| virtual void | SetProgressRange (const float range[2], int curStep, int numSteps) |
| virtual void | SetProgressRange (const float range[2], int curStep, const float *fractions) |
| virtual void | SetProgressPartial (float fraction) |
| virtual void | UpdateProgressDiscrete (float progress) |
| int | OpenStream () |
| int | OpenFile () |
| int | OpenString () |
| void | CloseStream () |
| void | CloseFile () |
| void | CloseString () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
