| int | GetNumberOfAttributes () |
| | Get the number of distinct attribute values present in the file. More...
| const char * | GetAttributeName (int attribute) |
| | Get the name of an attribute. More...
| int | GetAttributeIndex (const char *name) |
| | Get the index of the attribute with the given name. More...
| int | GetNumberOfAttributeValues (int attribute) |
| | Get the number of distinct values for the given attribute. More...
| vtkXMLDataElement * | GetOutputXMLDataElement (int index) |
| | Get the vtkXMLDataElement representing the collection element corresponding to the output with the given index. More...
| virtual void | SetRestriction (const char *name, const char *value) |
| | Get/Set the required value for a particular named attribute. More...
| virtual const char * | GetRestriction (const char *name) |
| virtual void | SetRestrictionAsIndex (const char *name, int index) |
| | Get/set the required value for a particular named attribute. More...
| virtual int | GetRestrictionAsIndex (const char *name) |
| const char * | GetAttributeValue (int attribute, int index) |
| | Get one of the possible values for a given attribute. More...
| const char * | GetAttributeValue (const char *name, int index) |
| int | GetAttributeValueIndex (int attribute, const char *value) |
| | Get the index of the attribute value with the given name. More...
| int | GetAttributeValueIndex (const char *name, const char *value) |
| virtual void | SetForceOutputTypeToMultiBlock (int) |
| | If ForceOutputTypeToMultiBlock is set to 1, the output of this reader will always be a multi-block dataset, even if there is 1 simple output. More...
| virtual int | GetForceOutputTypeToMultiBlock () |
| virtual void | ForceOutputTypeToMultiBlockOn () |
| virtual void | ForceOutputTypeToMultiBlockOff () |
| vtkXMLReader * | NewInstance () const |
| virtual int | CanReadFile (const char *name) |
| virtual void | CopyOutputInformation (vtkInformation *vtkNotUsed(outInfo), int vtkNotUsed(port)) |
| virtual int | GetNumberOfTimeSteps () |
| virtual void | SetFileName (const char *) |
| virtual char * | GetFileName () |
| virtual void | SetReadFromInputString (int) |
| virtual int | GetReadFromInputString () |
| virtual void | ReadFromInputStringOn () |
| virtual void | ReadFromInputStringOff () |
| void | SetInputString (std::string s) |
| vtkDataSet * | GetOutputAsDataSet () |
| vtkDataSet * | GetOutputAsDataSet (int index) |
| virtual vtkDataArraySelection * | GetPointDataArraySelection () |
| virtual vtkDataArraySelection * | GetCellDataArraySelection () |
| int | GetNumberOfPointArrays () |
| int | GetNumberOfCellArrays () |
| const char * | GetPointArrayName (int index) |
| const char * | GetCellArrayName (int index) |
| int | GetPointArrayStatus (const char *name) |
| int | GetCellArrayStatus (const char *name) |
| void | SetPointArrayStatus (const char *name, int status) |
| void | SetCellArrayStatus (const char *name, int status) |
| virtual void | SetTimeStep (int) |
| virtual int | GetTimeStep () |
| virtual int * | GetTimeStepRange () |
| virtual void | GetTimeStepRange (int &, int &) |
| virtual void | GetTimeStepRange (int[2]) |
| virtual void | SetTimeStepRange (int, int) |
| void | SetTimeStepRange (int[2]) |
| vtkXMLDataParser * | GetXMLParser () |
| void | SetReaderErrorObserver (vtkCommand *) |
| virtual vtkCommand * | GetReaderErrorObserver () |
| void | SetParserErrorObserver (vtkCommand *) |
| virtual vtkCommand * | GetParserErrorObserver () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkXMLCollectionReader () |
| | ~vtkXMLCollectionReader () override |
| void | BuildRestrictedDataSets () |
| const char * | GetDataSetName () override |
| int | ReadPrimaryElement (vtkXMLDataElement *ePrimary) override |
| int | FillOutputPortInformation (int, vtkInformation *info) override |
| vtkDataObject * | SetupOutput (const std::string &filePath, int index) |
| vtkXMLReader * | SetupReader (const std::string &filePath, int index) |
| | Ensures that an appropriate reader is setup for the specified index. More...
| int | RequestDataObject (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| void | SetupEmptyOutput () override |
| void | ReadXMLData () override |
| void | ReadXMLDataImpl () |
| virtual void | InternalProgressCallback () |
| void | AddAttributeNameValue (const char *name, const char *value) |
| virtual void | SetRestrictionImpl (const char *name, const char *value, bool doModify) |
| void | ReadAFile (int index, int updatePiece, int updateNumPieces, int updateGhostLevels, vtkDataObject *actualOutput) |
| void | FillArraySelectionUsingReaders (const std::string &filePath) |
| | iterating over all readers (which corresponds to number of distinct datasets in the file, and not distinct timesteps), populate this->*ArraySelection objects. More...
| | vtkXMLReader () |
| | ~vtkXMLReader () |
| virtual int | ReadXMLInformation () |
| virtual int | CanReadFileVersion (int major, int minor) |
| virtual void | SetupOutputInformation (vtkInformation *vtkNotUsed(outInfo)) |
| virtual void | SetupOutputData () |
| virtual int | ReadVTKFile (vtkXMLDataElement *eVTKFile) |
| vtkAbstractArray * | CreateArray (vtkXMLDataElement *da) |
| int | CreateInformationKey (vtkXMLDataElement *eInfoKey, vtkInformation *info) |
| bool | ReadInformation (vtkXMLDataElement *infoRoot, vtkInformation *info) |
| virtual int | OpenStream () |
| virtual void | CloseStream () |
| virtual int | OpenVTKFile () |
| virtual void | CloseVTKFile () |
| virtual int | OpenVTKString () |
| virtual void | CloseVTKString () |
| virtual void | CreateXMLParser () |
| virtual void | DestroyXMLParser () |
| void | SetupCompressor (const char *type) |
| int | CanReadFileVersionString (const char *version) |
| virtual int | CanReadFileWithDataType (const char *dsname) |
| virtual int | GetFileMajorVersion () |
| virtual int | GetFileMinorVersion () |
| int | IntersectExtents (int *extent1, int *extent2, int *result) |
| int | Min (int a, int b) |
| int | Max (int a, int b) |
| void | ComputePointDimensions (int *extent, int *dimensions) |
| void | ComputePointIncrements (int *extent, vtkIdType *increments) |
| void | ComputeCellDimensions (int *extent, int *dimensions) |
| void | ComputeCellIncrements (int *extent, vtkIdType *increments) |
| vtkIdType | GetStartTuple (int *extent, vtkIdType *increments, int i, int j, int k) |
| void | ReadAttributeIndices (vtkXMLDataElement *eDSA, vtkDataSetAttributes *dsa) |
| char ** | CreateStringArray (int numStrings) |
| void | DestroyStringArray (int numStrings, char **strings) |
| void | SetDataArraySelections (vtkXMLDataElement *eDSA, vtkDataArraySelection *sel) |
| int | SetFieldDataInfo (vtkXMLDataElement *eDSA, int association, int numTuples, vtkInformationVector *(&infoVector)) |
| int | PointDataArrayIsEnabled (vtkXMLDataElement *ePDA) |
| int | CellDataArrayIsEnabled (vtkXMLDataElement *eCDA) |
| virtual void | SqueezeOutputArrays (vtkDataObject *) |
| virtual void | GetProgressRange (float *range) |
| virtual void | SetProgressRange (const float range[2], int curStep, int numSteps) |
| virtual void | SetProgressRange (const float range[2], int curStep, const float *fractions) |
| virtual void | UpdateProgressDiscrete (float progress) |
| virtual int | RequestData (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
| virtual int | RequestDataObject (vtkInformation *vtkNotUsed(request), vtkInformationVector **vtkNotUsed(inputVector), vtkInformationVector *vtkNotUsed(outputVector)) |
| void | SetNumberOfTimeSteps (int num) |
| vtkDataObject * | GetCurrentOutput () |
| vtkInformation * | GetCurrentOutputInformation () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| | vtkObject () |
| | vtkObjectBase () |
Read a file wrapping many other XML files.
vtkXMLCollectionReader will read a "Collection" VTKData XML file. This file format references an arbitrary number of other XML data sets. Each referenced data set has a list of associated attribute/value pairs. One may use the SetRestriction method to set requirements on attribute's values. Only those data sets in the file matching the restrictions will be read. Each matching data set becomes an output of this reader in the order in which they appear in the file.
Definition at line 25 of file vtkXMLCollectionReader.h.
