| virtual void | SetFileName (const char *) |
| | The NetCDF file to open. More...
| virtual char * | GetFileName () |
| virtual void | SetStride (int, int, int) |
| | Enable subsampling in i,j and k dimensions for the topologically structured input data. More...
| virtual void | SetStride (int [3]) |
| virtual int * | GetStride () |
| virtual void | GetStride (int &, int &, int &) |
| virtual void | GetStride (int [3]) |
| virtual void | SetVOI (int, int, int, int, int, int) |
| | Set the VOI of for the topologically structured input data. More...
| virtual void | SetVOI (int [6]) |
| virtual int * | GetVOI () |
| virtual void | GetVOI (int &, int &, int &, int &, int &, int &) |
| virtual void | GetVOI (int [6]) |
| virtual int | GetNumberOfVariableArrays () |
| | Variable array selection. More...
| virtual const char * | GetVariableArrayName (int idx) |
| virtual int | GetVariableArrayStatus (const char *name) |
| virtual void | SetVariableArrayStatus (const char *name, int status) |
| virtual void | SetRadius (double) |
| | Set the outer radius of the Earth. More...
| virtual double | GetRadius () |
| virtual int | GetVectorGrid () |
| | Determine whether or not the input data is being interpolated at the U/vector points or T/scalar points. More...
| virtual void | SetVerticalVelocity (bool) |
| | Specify whether or not to compute the vertical velocity component from the horizontal velocity components. More...
| virtual bool | GetVerticalVelocity () |
| vtkUnstructuredGridAlgorithm * | NewInstance () const |
| vtkUnstructuredGrid * | GetUnstructuredGridInput (int port) |
| vtkUnstructuredGrid * | GetOutput () |
| vtkUnstructuredGrid * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkUnstructuredPOPReader () |
| | ~vtkUnstructuredPOPReader () override |
| bool | Transform (vtkUnstructuredGrid *grid, size_t *start, size_t *count, int *wholeExtent, int *subExtent, int numberOfGhostLevels, int wrapped, int piece, int numberOfPieces) |
| | Transform the grid from a topologically structured grid to a sphere shaped grid and do any vector transformations on field data that is needed. More...
| int | ProcessGrid (vtkUnstructuredGrid *grid, int piece, int numberOfPieces, int numberOfGhostLevels) |
| | Given the meta data about the grid partitioning, read in the data from the file and create the unstructured grid. More...
| bool | ReadMetaData (int wholeExtent[6]) |
| | Reads the meta data from the NetCDF file for information like what variables exist and the dimensions of the grids and variables. More...
| int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| void | LoadPointData (vtkUnstructuredGrid *grid, int netCDFFD, int varidp, size_t *start, size_t *count, ptrdiff_t *rStride, const char *arrayName) |
| | Adds a point data field given by varidp in the NetCDF file to the grid's point data. More...
| void | ComputeVerticalVelocity (vtkUnstructuredGrid *grid, int *wholeExtent, int *subExtent, int numberOfGhostLevels, int latlonFileId) |
| | Compute the vertical velocity component and add it into the velocity field. More...
| void | CommunicateParallelVerticalVelocity (int *wholeExtent, int *subExtent, int numberOfGhostLevels, VTKPointIterator &pointIterator, double *w) |
| | If the reader is being run in parallel, do the necessary communication to finish the vertical velocity integration on each process. More...
| int | GetPointOwnerPiece (int iIndex, int jIndex, int kKindex, int numberOfPieces, int numberOfGhostLevels, int *wholeExtent) |
| | Given ijk indices with respect to WholeExtent, return the process that is considered owning this point. More...
| void | GetPiecesNeedingPoint (int iIndex, int jIndex, int kKindex, int numberOfPieces, int numberOfGhostLevels, int *wholeExtent, vtkIdList *pieceIds) |
| | Given ijk indices, fill pieceIds with the pieces which contain need this point for computing the vertical velocity. More...
| bool | GetExtentInformation (int piece, int numberOfPieces, int numberOfGhostLevels, int *wholeExtent, int *subExtent) |
| | Given piece, numberOfPieces, numberOfGhostLevels, and wholeExtent, this method fills in subExtent. More...
| bool | BuildGhostInformation (vtkUnstructuredGrid *grid, int numberOfGhostLevels, int *wholeExtent, int *subExtent, int wrapped, int piece, int numberOfPieces) |
| | Build up the requested ghost information. More...
| | vtkUnstructuredGridAlgorithm () |
| | ~vtkUnstructuredGridAlgorithm () |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
read NetCDF files
vtkUnstructuredPOPReader reads NetCDF POP files into a spherical shaped grid. The input file has topologically structured data. The striding and VOI are done with respect to the topologically structured ordering. Additionally, the z coordinates of the output grid are negated so that the first slice/plane has the highest z-value and the last slice/plane has the lowest z-value. Note that depth_t is used for the z location of the points. For VOI and striding, striding is done first and then the VOI is done. For example, if stride was [1, 2, 3] for a [3600, 2400, 42] grid then the wholeExtent would be [0, 3600, 0, 1200, 0, 14] and then a VOI of [10, 300, 0, 1400, 2 8] would result in a whole extent of [10, 300, 0, 1200, 2, 8] with the first point being [10, 0, 6] in the [3600, 2400, 42] original grid. The reader also requires a GRID.nc file in the same directory as the main file. This is used to map from tripolar logical coordinates to lat-lon coordinates.
Definition at line 38 of file vtkUnstructuredPOPReader.h.
