vtkUnstructuredGridVolumeRepresentation Class Reference
representation for showing vtkUnstructuredGrid datasets as volumes. More...
#include <vtkUnstructuredGridVolumeRepresentation.h>
Inheritance diagram for vtkUnstructuredGridVolumeRepresentation:
Collaboration diagram for vtkUnstructuredGridVolumeRepresentation:
typedef vtkVolumeRepresentation Superclass
- Public Types inherited from vtkVolumeRepresentation
enum  DesiredOutputPrecision
void AddVolumeMapper (const char *name, vtkAbstractVolumeMapper *)
 Register a volume mapper with the representation. More...
void SetSamplingDimensions (int dims[3])
void SetSamplingDimensions (int xdim, int ydim, int zdim)
virtual void SetActiveVolumeMapper (const char *)
 Set the active volume mapper to use. More...
vtkAbstractVolumeMapperGetActiveVolumeMapper ()
void SetActiveAssembly (const char *)
 Forwarded to vtkVolumeRepresentationPreprocessor. More...
void AddBlockSelector (const char *)
void RemoveAllBlockSelectors ()
virtual void SetUseDataPartitions (bool)
 Specify whether or not to redistribute the data. More...
virtual bool GetUseDataPartitions ()
- Public Member Functions inherited from vtkVolumeRepresentation
void SetVisibility (bool val) override
void SetOrientation (double, double, double)
void SetOrigin (double, double, double)
void SetPickable (int val)
void SetPosition (double, double, double)
void SetScale (double, double, double)
void SetInterpolationType (int val)
void SetColor (vtkColorTransferFunction *lut)
void SetScalarOpacity (vtkPiecewiseFunction *pwf)
void SetScalarOpacityUnitDistance (double val)
void SetMapScalars (bool)
void SetMultiComponentsMapping (bool)
void SetUseSeparateOpacityArray (bool)
void SelectOpacityArray (int, int, int, int, const char *name)
void SelectOpacityArrayComponent (int component)
vtkPVLODVolumeGetActor ()
 Provides access to the actor used by this representation. More...
virtual void MarkModified ()
virtual bool GetVisibility ()
virtual vtkDataObjectGetRenderedDataObject (int vtkNotUsed(port))
double GetCacheKey () const
vtkAlgorithmOutputGetInternalOutputPort () override
vtkAlgorithmOutputGetInternalOutputPort (int port) override
vtkAlgorithmOutputGetInternalOutputPort (int port, int conn) override
vtkViewGetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
const std::stringGetLogName () const
vtkDataRepresentationNewInstance () const
virtual vtkSelectionConvertSelection (vtkView *view, vtkSelection *selection)
vtkAlgorithmOutputGetInputConnection (int port=0, int index=0)
vtkAnnotationLinkGetAnnotationLink ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort ()
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort (int port)
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort (int port, int conn)
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort ()
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort (int port)
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort (int port, int conn)
virtual vtkStringArrayGetSelectionArrayNames ()
vtkPassInputTypeAlgorithmNewInstance () const
vtkPolyDataGetPolyDataOutput ()
vtkStructuredPointsGetStructuredPointsOutput ()
vtkImageDataGetImageDataOutput ()
vtkStructuredGridGetStructuredGridOutput ()
vtkUnstructuredGridGetUnstructuredGridOutput ()
vtkRectilinearGridGetRectilinearGridOutput ()
vtkTableGetTableOutput ()
vtkGraphGetGraphOutput ()
vtkDataObjectGetInput ()
vtkDataObjectGetOutput ()
vtkDataObjectGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkUnstructuredGridVolumeRepresentationNew ()
static vtkUnstructuredGridVolumeRepresentationSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkVolumeRepresentation
static vtkVolumeRepresentationSafeDownCast (vtkObject *o)
static vtkPVDataRepresentationSafeDownCast (vtkObject *o)
static vtkDataRepresentationNew ()
static vtkDataRepresentationSafeDownCast (vtkObjectBase *o)
static vtkPassInputTypeAlgorithmNew ()
static vtkPassInputTypeAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkUnstructuredGridVolumeRepresentation ()
 ~vtkUnstructuredGridVolumeRepresentation () override
virtual void UpdateMapperParameters ()
 Passes on parameters to the active volume mapper. More...
int ProcessViewRequestResampleToImage (vtkInformationRequestKey *request_type, vtkInformation *inInfo, vtkInformation *outInfo)
int RequestDataResampleToImage (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector)
- Protected Member Functions inherited from vtkVolumeRepresentation
 vtkVolumeRepresentation ()
 ~vtkVolumeRepresentation () override
bool AppendOpacityComponent (vtkDataSet *dataset)
 Appends a designated opacity component to a scalar array used for color/opacity mapping. More...
 vtkPVDataRepresentation ()
vtkExecutiveCreateDefaultExecutive () override
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
virtual vtkAnnotationLayersConvertAnnotations (vtkView *view, vtkAnnotationLayers *annotations)
vtkTrivialProducerGetInternalInput (int port, int conn)
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
vtkDataObjectGetInput (int port)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkNew< vtkVolumeRepresentationPreprocessorPreprocessor
vtkNew< vtkProjectedTetrahedraMapperDefaultMapper
vtkNew< vtkResampleToImageResampleToImageFilter
vtkNew< vtkGeometryFilterDispatcher > LODGeometryFilter
vtkNew< vtkPolyDataMapperLODMapper
bool UseDataPartitions = false
- Protected Attributes inherited from vtkVolumeRepresentation
vtkNew< vtkVolumePropertyProperty
vtkSmartPointer< vtkPVLODVolumeActor
vtkNew< vtkOutlineSourceOutlineSource
unsigned long DataSize = 0
double DataBounds [6]
bool MapScalars = true
bool MultiComponentsMapping = false
bool UseSeparateOpacityArray = false
std::string OpacityArrayName
int OpacityArrayFieldAssociation = -1
int OpacityArrayComponent = -1
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
vtkStringArraySelectionArrayNames
CommandObserver
vtkAnnotationLinkAnnotationLinkInternal
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkUnstructuredGridVolumeRepresentation is a representation for volume rendering vtkUnstructuredGrid datasets. It simply renders a translucent surface for LOD i.e. interactive rendering.
Definition at line 32 of file vtkUnstructuredGridVolumeRepresentation.h.
Definition at line 37 of file vtkUnstructuredGridVolumeRepresentation.h.
◆ vtkUnstructuredGridVolumeRepresentation()
vtkUnstructuredGridVolumeRepresentation::vtkUnstructuredGridVolumeRepresentation ( )
◆ ~vtkUnstructuredGridVolumeRepresentation()
vtkUnstructuredGridVolumeRepresentation::~vtkUnstructuredGridVolumeRepresentation ( )
static vtkUnstructuredGridVolumeRepresentation* vtkUnstructuredGridVolumeRepresentation::New ( )
virtual const char* vtkUnstructuredGridVolumeRepresentation::GetClassName ( )
Reimplemented from vtkVolumeRepresentation.
Reimplemented in vtkStructuredGridVolumeRepresentation.
static int vtkUnstructuredGridVolumeRepresentation::IsTypeOf ( const char *  type)
virtual int vtkUnstructuredGridVolumeRepresentation::IsA ( const char *  type)
static vtkUnstructuredGridVolumeRepresentation* vtkUnstructuredGridVolumeRepresentation::SafeDownCast ( vtkObject o)
void vtkUnstructuredGridVolumeRepresentation::PrintSelf ( ostream &  os,
◆ AddVolumeMapper()
void vtkUnstructuredGridVolumeRepresentation::AddVolumeMapper ( const char *  name,
◆ SetActiveVolumeMapper()
virtual void vtkUnstructuredGridVolumeRepresentation::SetActiveVolumeMapper ( const char *  )
◆ GetActiveVolumeMapper()
vtkAbstractVolumeMapper* vtkUnstructuredGridVolumeRepresentation::GetActiveVolumeMapper ( )
◆ ProcessViewRequest()
int vtkUnstructuredGridVolumeRepresentation::ProcessViewRequest ( vtkInformationRequestKey request_type,
vtkInformation inInfo,
vtkInformation outInfo
◆ SetActiveAssembly()
void vtkUnstructuredGridVolumeRepresentation::SetActiveAssembly ( const char *  )
Controls which blocks in a composite dataset are rendered.
◆ AddBlockSelector()
void vtkUnstructuredGridVolumeRepresentation::AddBlockSelector ( const char *  )
◆ RemoveAllBlockSelectors()
void vtkUnstructuredGridVolumeRepresentation::RemoveAllBlockSelectors ( )
◆ SetSamplingDimensions() [1/2]
void vtkUnstructuredGridVolumeRepresentation::SetSamplingDimensions ( int  dims[3])
inline
Definition at line 75 of file vtkUnstructuredGridVolumeRepresentation.h.
◆ SetSamplingDimensions() [2/2]
void vtkUnstructuredGridVolumeRepresentation::SetSamplingDimensions ( int  xdim,
int  ydim,
int  zdim
◆ SetUseDataPartitions()
virtual void vtkUnstructuredGridVolumeRepresentation::SetUseDataPartitions ( bool  )
The default is false since that is the only way in general to guarantee correct rendering. Can set to true if all rendered data sets are based on the same data partitioning in order to save on the data redistribution.
◆ GetUseDataPartitions()
virtual bool vtkUnstructuredGridVolumeRepresentation::GetUseDataPartitions ( )
◆ FillInputPortInformation()
int vtkUnstructuredGridVolumeRepresentation::FillInputPortInformation ( int  port,
vtkInformation info
overrideprotectedvirtual
Fill input port information.
◆ RequestData()
int vtkUnstructuredGridVolumeRepresentation::RequestData ( vtkInformation ,
vtkInformationVector **  ,
Overridden to invoke vtkCommand::UpdateDataEvent.
◆ AddToView()
bool vtkUnstructuredGridVolumeRepresentation::AddToView ( vtkView view)
◆ RemoveFromView()
bool vtkUnstructuredGridVolumeRepresentation::RemoveFromView ( vtkView view)
◆ UpdateMapperParameters()
virtual void vtkUnstructuredGridVolumeRepresentation::UpdateMapperParameters ( )
protectedvirtual
◆ ProcessViewRequestResampleToImage()
int vtkUnstructuredGridVolumeRepresentation::ProcessViewRequestResampleToImage ( vtkInformationRequestKey request_type,
◆ RequestDataResampleToImage()
int vtkUnstructuredGridVolumeRepresentation::RequestDataResampleToImage ( vtkInformation request,
vtkInformationVector outputVector
◆ Preprocessor
vtkNew<vtkVolumeRepresentationPreprocessor> vtkUnstructuredGridVolumeRepresentation::Preprocessor
Definition at line 127 of file vtkUnstructuredGridVolumeRepresentation.h.
◆ DefaultMapper
vtkNew<vtkProjectedTetrahedraMapper> vtkUnstructuredGridVolumeRepresentation::DefaultMapper
Definition at line 128 of file vtkUnstructuredGridVolumeRepresentation.h.
◆ ResampleToImageFilter
vtkNew<vtkResampleToImage> vtkUnstructuredGridVolumeRepresentation::ResampleToImageFilter
Definition at line 130 of file vtkUnstructuredGridVolumeRepresentation.h.
◆ LODGeometryFilter
vtkNew<vtkGeometryFilterDispatcher> vtkUnstructuredGridVolumeRepresentation::LODGeometryFilter
Definition at line 132 of file vtkUnstructuredGridVolumeRepresentation.h.
◆ LODMapper
vtkNew<vtkPolyDataMapper> vtkUnstructuredGridVolumeRepresentation::LODMapper
Definition at line 133 of file vtkUnstructuredGridVolumeRepresentation.h.
◆ UseDataPartitions
bool vtkUnstructuredGridVolumeRepresentation::UseDataPartitions = false
Definition at line 135 of file vtkUnstructuredGridVolumeRepresentation.h.
