| vtkMTimeType | GetMTime () override |
| | Override GetMTime because we rely on internal filters that have their own MTime. More...
| void | SetCutNormal (int cutIndex, double normal[3]) |
| | Set a Slice Normal for a given cutter. More...
| void | SetCutOrigin (int cutIndex, double origin[3]) |
| | Set a slice Origin for a given cutter. More...
| void | SetCutValue (int cutIndex, int index, double value) |
| | Set a slice value for a given cutter. More...
| void | SetNumberOfSlice (int cutIndex, int size) |
| | Set number of slices for a given cutter. More...
| void | SetToDefaultSettings () |
| | Default settings: More...
| void | SetCutOrigins (double origin[3]) |
| | Set slice Origin for all cutter. More...
| void | SetCutOrigins (double x, double y, double z) |
| void | EnableProbe (int enable) |
| | Enable to probe the dataset at the given cut origin. More...
| bool | GetProbedPointData (const char *arrayName, double &value) |
| | Return true if any data is available and provide the value as argument. More...
| vtkPolyDataAlgorithm * | NewInstance () const |
| vtkPolyData * | GetPolyDataInput (int port) |
| vtkPolyData * | GetOutput () |
| vtkPolyData * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkThreeSliceFilter () |
| | ~vtkThreeSliceFilter () override |
| void | Process (vtkDataSet *input, vtkPolyData *outputs[4], unsigned int compositeIndex) |
| | vtkPolyDataAlgorithm () |
| | ~vtkPolyDataAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Cut vtkDataSet along 3 planes.
vtkThreeSliceFilter is a filter that slice the input data using 3 plane cut. Each axis cut could embed several slices by providing several values. As output you will find 4 output ports. The output ports are defined as follow:
- 0: Merge of all the cutter output
- 1: Output of the first internal vtkCutter filter
- 2: Output of the second internal vtkCutter filter
- 3: Output of the third internal vtkCutter filter
Definition at line 34 of file vtkThreeSliceFilter.h.
