| vtkMTimeType | GetMTime () override |
| | Override GetMTime because we rely on internal filters that have their own MTime. More...
| virtual void | SetPassArraysEnabled (bool) |
| | Enable/disable the internal vtkPassSelectedArrays filter. More...
| virtual bool | GetPassArraysEnabled () |
| virtual void | PassArraysEnabledOn () |
| virtual void | PassArraysEnabledOff () |
| virtual void | SetExtractBlocksEnabled (bool) |
| | Enable/disable the internal vtkExtractBlockUsingDataAssembly filter. More...
| virtual bool | GetExtractBlocksEnabled () |
| virtual void | ExtractBlocksEnabledOn () |
| virtual void | ExtractBlocksEnabledOff () |
| vtkDataArraySelection * | GetPointDataArraySelection () |
| | Convenience methods that call GetArraySelection with corresponding association type. More...
| vtkDataArraySelection * | GetCellDataArraySelection () |
| vtkDataArraySelection * | GetFieldDataArraySelection () |
| vtkDataArraySelection * | GetVertexDataArraySelection () |
| vtkDataArraySelection * | GetEdgeDataArraySelection () |
| vtkDataArraySelection * | GetRowDataArraySelection () |
| bool | AddSelector (const char *selector) |
| | API to set selectors. More...
| void | ClearSelectors () |
| void | SetAssemblyName (const char *assemblyName) |
| | Get/Set the active assembly to use. More...
| const char * | GetAssemblyName () const |
| vtkCompositeDataSetAlgorithm * | NewInstance () const |
| vtkCompositeDataSet * | GetOutput () |
| vtkCompositeDataSet * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkSelectArraysExtractBlocks () |
| | ~vtkSelectArraysExtractBlocks () override |
| int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| | vtkCompositeDataSetAlgorithm () |
| | ~vtkCompositeDataSetAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Selects arrays and extracts blocks.
vtkSelectArraysExtractBlocks is a meta-filter combining the vtkPassSelectedArrays and vtkExtractBlockUsingDataAssembly filters. It is intended to be used as a pre-processing filter for certain composite writers. It adds the possibility to choose the blocks to write, in addition to the data arrays.
Definition at line 24 of file vtkSelectArraysExtractBlocks.h.
