vtkSMVRTravelTrackballExoSplitStyleProxy Class Reference
an interaction style to control translation and rotation with a stylus More...
#include <vtkSMVRTravelTrackballExoSplitStyleProxy.h>
Inheritance diagram for vtkSMVRTravelTrackballExoSplitStyleProxy:
Collaboration diagram for vtkSMVRTravelTrackballExoSplitStyleProxy:
enum  { INTERACTOR_STYLE_REQUEST_CONFIGURE = vtkCommand::UserEvent + 7370, INTERACTOR_STYLE_NAVIGATION = vtkCommand::UserEvent + 7371 }
typedef vtkSMProxy Superclass
typedef std::map< std::string, std::stringStringMap
typedef std::map< std::string, StringMapStringMapMap
int GetControlledPropertySize () override
bool Update () override
virtual vtkSMProxyGetControlledProxy ()
virtual void SetIsInternal (bool)
virtual bool GetIsInternal ()
virtual void IsInternalOn ()
virtual void IsInternalOff ()
int GetNumberOfButtonRoles ()
unsigned int GetChannelIndexForValuatorRole (const std::string &role)
void ClearAllRoles ()
virtual vtkPVXMLElementSaveConfiguration ()
 Save state to xml. More...
vtkMatrix4x4GetNavigationMatrix (vtkSMRenderViewProxy *proxy=nullptr)
void UpdateMatrixProperty (vtkSMProxy *proxy, const char *propertyName, vtkMatrix4x4 *matrix)
void SetValuatorLookupTable (std::shared_ptr< StringMapMap >)
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
vtkSMProxyGetParentProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMVRTravelTrackballExoSplitStyleProxyNew ()
static vtkSMVRTravelTrackballExoSplitStyleProxySafeDownCast (vtkObject *o)
static vtkSMVRInteractorStyleProxyNew ()
static vtkSMVRInteractorStyleProxySafeDownCast (vtkObject *o)
static vtkSMRenderViewProxyGetActiveViewProxy ()
static vtkCameraGetActiveCamera ()
static void SetNavigationMatrix (vtkMatrix4x4 *, vtkSMRenderViewProxy *proxy=nullptr)
static std::vector< doubleGetNavigationScale (vtkSMRenderViewProxy *proxy=nullptr)
static void SetNavigationScale (const std::vector< double > &scale, vtkSMRenderViewProxy *proxy=nullptr)
static vtkSMProxyNew ()
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMVRTravelTrackballExoSplitStyleProxy ()
 ~vtkSMVRTravelTrackballExoSplitStyleProxy () override=default
void HandleButton (const vtkVREvent &event) override
void HandleTracker (const vtkVREvent &event) override
virtual void HandleValuator (const vtkVREvent &event)
virtual void SaveProxyProperties (vtkPVXMLElement *xml)
 Load/Save custom properties from the interactor style in the .pvvr file Can be overriden to use a custom mechanism to load/save properties. More...
virtual bool LoadProxyProperties (vtkPVXMLElement *xml, vtkSMProxyLocator *locator)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
static std::vector< std::stringTokenize (std::string input)
vtkSMProxyControlledProxy
char * ControlledPropertyName
StringMap Valuators
StringMap Buttons
StringMap Trackers
bool IsInternal
std::shared_ptr< StringMapMapvaluatorLookupTable
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElementXMLElement
vtkSMMessageState
int InMarkModified
vtkSMProxyInternalsInternals
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMVRTravelTrackballExoSplitStyleProxy is an interaction style that uses the position of the stylus in screen space (for example the stylus of the zSpace) to modify a 4x4 matrix. Only the location of the stylus is used, the rotation has no effect. Only works with RenderView proxy.
Definition at line 24 of file vtkSMVRTravelTrackballExoSplitStyleProxy.h.
Definition at line 29 of file vtkSMVRTravelTrackballExoSplitStyleProxy.h.
◆ vtkSMVRTravelTrackballExoSplitStyleProxy()
vtkSMVRTravelTrackballExoSplitStyleProxy::vtkSMVRTravelTrackballExoSplitStyleProxy ( )
◆ ~vtkSMVRTravelTrackballExoSplitStyleProxy()
vtkSMVRTravelTrackballExoSplitStyleProxy::~vtkSMVRTravelTrackballExoSplitStyleProxy ( )
overrideprotecteddefault
static vtkSMVRTravelTrackballExoSplitStyleProxy* vtkSMVRTravelTrackballExoSplitStyleProxy::New ( )
virtual const char* vtkSMVRTravelTrackballExoSplitStyleProxy::GetClassName ( )
static int vtkSMVRTravelTrackballExoSplitStyleProxy::IsTypeOf ( const char *  type)
virtual int vtkSMVRTravelTrackballExoSplitStyleProxy::IsA ( const char *  type)
static vtkSMVRTravelTrackballExoSplitStyleProxy* vtkSMVRTravelTrackballExoSplitStyleProxy::SafeDownCast ( vtkObject o)
void vtkSMVRTravelTrackballExoSplitStyleProxy::PrintSelf ( ostream &  os,
◆ GetControlledPropertySize()
int vtkSMVRTravelTrackballExoSplitStyleProxy::GetControlledPropertySize ( )
inlineoverridevirtual
Definition at line 31 of file vtkSMVRTravelTrackballExoSplitStyleProxy.h.
◆ Update()
bool vtkSMVRTravelTrackballExoSplitStyleProxy::Update ( )
Typically processing intensive operations go here. The method should not be called from within the handler and is reserved to be called from an external interaction style manager.
◆ HandleButton()
void vtkSMVRTravelTrackballExoSplitStyleProxy::HandleButton ( const vtkVREvent event)
overrideprotectedvirtual
◆ HandleTracker()
void vtkSMVRTravelTrackballExoSplitStyleProxy::HandleTracker ( const vtkVREvent event)
