vtkSMVRTravelGrabExoSplitStyleProxy Class Reference
an interaction style to control a matrix More...
#include <vtkSMVRTravelGrabExoSplitStyleProxy.h>
Inheritance diagram for vtkSMVRTravelGrabExoSplitStyleProxy:
Collaboration diagram for vtkSMVRTravelGrabExoSplitStyleProxy:
enum  { INTERACTOR_STYLE_REQUEST_CONFIGURE = vtkCommand::UserEvent + 7370, INTERACTOR_STYLE_NAVIGATION = vtkCommand::UserEvent + 7371 }
typedef vtkSMProxy Superclass
typedef std::map< std::string, std::stringStringMap
typedef std::map< std::string, StringMapStringMapMap
int GetControlledPropertySize () override
bool Update () override
virtual vtkSMProxyGetControlledProxy ()
virtual void SetIsInternal (bool)
virtual bool GetIsInternal ()
virtual void IsInternalOn ()
virtual void IsInternalOff ()
int GetNumberOfButtonRoles ()
unsigned int GetChannelIndexForValuatorRole (const std::string &role)
void ClearAllRoles ()
virtual vtkPVXMLElementSaveConfiguration ()
 Save state to xml. More...
vtkMatrix4x4GetNavigationMatrix (vtkSMRenderViewProxy *proxy=nullptr)
void UpdateMatrixProperty (vtkSMProxy *proxy, const char *propertyName, vtkMatrix4x4 *matrix)
void SetValuatorLookupTable (std::shared_ptr< StringMapMap >)
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
vtkSMProxyGetParentProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMVRTravelGrabExoSplitStyleProxyNew ()
static vtkSMVRTravelGrabExoSplitStyleProxySafeDownCast (vtkObject *o)
static vtkSMVRInteractorStyleProxyNew ()
static vtkSMVRInteractorStyleProxySafeDownCast (vtkObject *o)
static vtkSMRenderViewProxyGetActiveViewProxy ()
static vtkCameraGetActiveCamera ()
static void SetNavigationMatrix (vtkMatrix4x4 *, vtkSMRenderViewProxy *proxy=nullptr)
static std::vector< doubleGetNavigationScale (vtkSMRenderViewProxy *proxy=nullptr)
static void SetNavigationScale (const std::vector< double > &scale, vtkSMRenderViewProxy *proxy=nullptr)
static vtkSMProxyNew ()
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMVRTravelGrabExoSplitStyleProxy ()
 ~vtkSMVRTravelGrabExoSplitStyleProxy () override=default
void HandleButton (const vtkVREvent &event) override
void HandleTracker (const vtkVREvent &event) override
virtual void HandleValuator (const vtkVREvent &event)
virtual void SaveProxyProperties (vtkPVXMLElement *xml)
 Load/Save custom properties from the interactor style in the .pvvr file Can be overriden to use a custom mechanism to load/save properties. More...
virtual bool LoadProxyProperties (vtkPVXMLElement *xml, vtkSMProxyLocator *locator)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
static std::vector< std::stringTokenize (std::string input)
vtkSMProxyControlledProxy
char * ControlledPropertyName
StringMap Valuators
StringMap Buttons
StringMap Trackers
bool IsInternal
std::shared_ptr< StringMapMapvaluatorLookupTable
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElementXMLElement
vtkSMMessageState
int InMarkModified
vtkSMProxyInternalsInternals
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMVRTravelGrabExoSplitStyleProxy is an interaction style that uses two buttons, along with tracker position and orientation, to control a 4x4 matrix property (mostly only the ModelTransformMatrix of a vtkSMRenderViewProxy), The world/scene appears to orbit about the world origin, hence the name contains "Exo" rather than "Ego".
Definition at line 28 of file vtkSMVRTravelGrabExoSplitStyleProxy.h.
Definition at line 33 of file vtkSMVRTravelGrabExoSplitStyleProxy.h.
◆ vtkSMVRTravelGrabExoSplitStyleProxy()
vtkSMVRTravelGrabExoSplitStyleProxy::vtkSMVRTravelGrabExoSplitStyleProxy ( )
◆ ~vtkSMVRTravelGrabExoSplitStyleProxy()
vtkSMVRTravelGrabExoSplitStyleProxy::~vtkSMVRTravelGrabExoSplitStyleProxy ( )
overrideprotecteddefault
static vtkSMVRTravelGrabExoSplitStyleProxy* vtkSMVRTravelGrabExoSplitStyleProxy::New ( )
virtual const char* vtkSMVRTravelGrabExoSplitStyleProxy::GetClassName ( )
static int vtkSMVRTravelGrabExoSplitStyleProxy::IsTypeOf ( const char *  type)
virtual int vtkSMVRTravelGrabExoSplitStyleProxy::IsA ( const char *  type)
static vtkSMVRTravelGrabExoSplitStyleProxy* vtkSMVRTravelGrabExoSplitStyleProxy::SafeDownCast ( vtkObject o)
void vtkSMVRTravelGrabExoSplitStyleProxy::PrintSelf ( ostream &  os,
◆ GetControlledPropertySize()
int vtkSMVRTravelGrabExoSplitStyleProxy::GetControlledPropertySize ( )
inlineoverridevirtual
Definition at line 35 of file vtkSMVRTravelGrabExoSplitStyleProxy.h.
◆ Update()
bool vtkSMVRTravelGrabExoSplitStyleProxy::Update ( )
Typically processing intensive operations go here. The method should not be called from within the handler and is reserved to be called from an external interaction style manager.
◆ HandleButton()
void vtkSMVRTravelGrabExoSplitStyleProxy::HandleButton ( const vtkVREvent event)
overrideprotectedvirtual
◆ HandleTracker()
void vtkSMVRTravelGrabExoSplitStyleProxy::HandleTracker ( const vtkVREvent event)
