vtkSMVRJoystickCameraStyleProxy Class Reference
interactor style with a controller with joysticks More...
#include <vtkSMVRJoystickCameraStyleProxy.h>
Inheritance diagram for vtkSMVRJoystickCameraStyleProxy:
Collaboration diagram for vtkSMVRJoystickCameraStyleProxy:
enum  Axis { X_AXIS = 0, Y_AXIS, Z_AXIS }
 Enum axis to retrieve the forward, the right and the up axis of the scene. More...
enum  { INTERACTOR_STYLE_REQUEST_CONFIGURE = vtkCommand::UserEvent + 7370, INTERACTOR_STYLE_NAVIGATION = vtkCommand::UserEvent + 7371 }
typedef vtkSMProxy Superclass
typedef std::map< std::string, std::stringStringMap
typedef std::map< std::string, StringMapStringMapMap
int GetControlledPropertySize () override
 Override this function to automatically set the controlled property. More...
bool Update () override
 Overridden to defer expensive calculations and update vtk objects. More...
void UpdateVTKObjects () override
 Overridden to support retrieving the move speed, the joystick sensitivity and the up axis from the UI. More...
virtual void SetLookRotationSensitivity (double)
 Set/Get the sensitivity when rotating the camera (0.01 by default). More...
virtual double GetLookRotationSensitivity ()
virtual void SetMoveJoystickSensitivity (double)
 Set/Get the joystick sensitivity value, used as exponent (2.0 by default). More...
virtual double GetMoveJoystickSensitivity ()
virtual void SetMoveCameraSensitivity (double)
 Set the sensitivity when moving the camera (0.1 by default). More...
virtual double GetMoveCameraSensitivity ()
virtual void SetInvertXAxis (bool)
 Set/Get the inversion of the rotation axis of the camera (false by default). More...
virtual bool GetInvertXAxis ()
virtual void SetInvertYAxis (bool)
virtual bool GetInvertYAxis ()
virtual void SetInvertFwdMovement (bool)
 Set/Get the inversion of the movements of the camera (false by default). More...
virtual bool GetInvertFwdMovement ()
virtual void SetInvertRightMovement (bool)
virtual bool GetInvertRightMovement ()
virtual void SetFastMovementMultiplier (double)
 Set the multiplier for the movement speed when the fast button movement is pressed (4.0 by default). More...
virtual double GetFastMovementMultiplier ()
virtual void SetUpAxis (Axis)
 Set/Get the up axis of the scene to define axis controlled by pitch and yaw (Y Axis by default). More...
virtual Axis GetUpAxis ()
virtual vtkSMProxyGetControlledProxy ()
virtual void SetIsInternal (bool)
virtual bool GetIsInternal ()
virtual void IsInternalOn ()
virtual void IsInternalOff ()
int GetNumberOfButtonRoles ()
unsigned int GetChannelIndexForValuatorRole (const std::string &role)
void ClearAllRoles ()
virtual vtkPVXMLElementSaveConfiguration ()
 Save state to xml. More...
vtkMatrix4x4GetNavigationMatrix (vtkSMRenderViewProxy *proxy=nullptr)
void UpdateMatrixProperty (vtkSMProxy *proxy, const char *propertyName, vtkMatrix4x4 *matrix)
void SetValuatorLookupTable (std::shared_ptr< StringMapMap >)
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
vtkSMProxyGetParentProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMVRJoystickCameraStyleProxyNew ()
static vtkSMVRJoystickCameraStyleProxySafeDownCast (vtkObject *o)
static vtkSMVRInteractorStyleProxyNew ()
static vtkSMVRInteractorStyleProxySafeDownCast (vtkObject *o)
static vtkSMRenderViewProxyGetActiveViewProxy ()
static vtkCameraGetActiveCamera ()
static void SetNavigationMatrix (vtkMatrix4x4 *, vtkSMRenderViewProxy *proxy=nullptr)
static std::vector< doubleGetNavigationScale (vtkSMRenderViewProxy *proxy=nullptr)
static void SetNavigationScale (const std::vector< double > &scale, vtkSMRenderViewProxy *proxy=nullptr)
static vtkSMProxyNew ()
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMVRJoystickCameraStyleProxy ()
 ~vtkSMVRJoystickCameraStyleProxy () override=default
void HandleButton (const vtkVREvent &event) override
void HandleValuator (const vtkVREvent &event) override
virtual void HandleTracker (const vtkVREvent &event)
virtual void SaveProxyProperties (vtkPVXMLElement *xml)
 Load/Save custom properties from the interactor style in the .pvvr file Can be overriden to use a custom mechanism to load/save properties. More...
virtual bool LoadProxyProperties (vtkPVXMLElement *xml, vtkSMProxyLocator *locator)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
static std::vector< std::stringTokenize (std::string input)
vtkSMProxyControlledProxy
char * ControlledPropertyName
StringMap Valuators
StringMap Buttons
StringMap Trackers
bool IsInternal
std::shared_ptr< StringMapMapvaluatorLookupTable
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElementXMLElement
vtkSMMessageState
int InMarkModified
vtkSMProxyInternalsInternals
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMVRJoystickCameraStyleProxy is an interaction style that binds a controller to enable movement of the camera with the joysticks. The input device must contains 2 joysticks with valuators going from -1 to 1 in X and Y to function correctly (a vrpn_Joylin or a vrpn_Joywin32 for example with VRPN). In the CAVE, this interaction style won't have any effect unless the off-axis projection is turned off in the CAVE configuration.
Definition at line 26 of file vtkSMVRJoystickCameraStyleProxy.h.
Definition at line 31 of file vtkSMVRJoystickCameraStyleProxy.h.
◆ Axis
Enumerator
X_AXIS
Y_AXIS
Z_AXIS
Definition at line 95 of file vtkSMVRJoystickCameraStyleProxy.h.
◆ vtkSMVRJoystickCameraStyleProxy()
vtkSMVRJoystickCameraStyleProxy::vtkSMVRJoystickCameraStyleProxy ( )
◆ ~vtkSMVRJoystickCameraStyleProxy()
vtkSMVRJoystickCameraStyleProxy::~vtkSMVRJoystickCameraStyleProxy ( )
overrideprotecteddefault
static vtkSMVRJoystickCameraStyleProxy* vtkSMVRJoystickCameraStyleProxy::New ( )
virtual const char* vtkSMVRJoystickCameraStyleProxy::GetClassName ( )
static int vtkSMVRJoystickCameraStyleProxy::IsTypeOf ( const char *  type)
virtual int vtkSMVRJoystickCameraStyleProxy::IsA ( const char *  type)
static vtkSMVRJoystickCameraStyleProxy* vtkSMVRJoystickCameraStyleProxy::SafeDownCast ( vtkObject o)
void vtkSMVRJoystickCameraStyleProxy::PrintSelf ( ostream &  os,
◆ GetControlledPropertySize()
int vtkSMVRJoystickCameraStyleProxy::GetControlledPropertySize ( )
inlineoverridevirtual
Definition at line 37 of file vtkSMVRJoystickCameraStyleProxy.h.
◆ SetLookRotationSensitivity()
virtual void vtkSMVRJoystickCameraStyleProxy::SetLookRotationSensitivity ( double  )
◆ GetLookRotationSensitivity()
virtual double vtkSMVRJoystickCameraStyleProxy::GetLookRotationSensitivity ( )
◆ SetMoveJoystickSensitivity()
virtual void vtkSMVRJoystickCameraStyleProxy::SetMoveJoystickSensitivity ( double  )
◆ GetMoveJoystickSensitivity()
virtual double vtkSMVRJoystickCameraStyleProxy::GetMoveJoystickSensitivity ( )
◆ SetMoveCameraSensitivity()
virtual void vtkSMVRJoystickCameraStyleProxy::SetMoveCameraSensitivity ( double  )
◆ GetMoveCameraSensitivity()
virtual double vtkSMVRJoystickCameraStyleProxy::GetMoveCameraSensitivity ( )
◆ SetInvertXAxis()
virtual void vtkSMVRJoystickCameraStyleProxy::SetInvertXAxis ( bool  )
◆ GetInvertXAxis()
virtual bool vtkSMVRJoystickCameraStyleProxy::GetInvertXAxis ( )
◆ SetInvertYAxis()
virtual void vtkSMVRJoystickCameraStyleProxy::SetInvertYAxis ( bool  )
◆ GetInvertYAxis()
virtual bool vtkSMVRJoystickCameraStyleProxy::GetInvertYAxis ( )
◆ SetInvertFwdMovement()
virtual void vtkSMVRJoystickCameraStyleProxy::SetInvertFwdMovement ( bool  )
◆ GetInvertFwdMovement()
virtual bool vtkSMVRJoystickCameraStyleProxy::GetInvertFwdMovement ( )
◆ SetInvertRightMovement()
virtual void vtkSMVRJoystickCameraStyleProxy::SetInvertRightMovement ( bool  )
◆ GetInvertRightMovement()
virtual bool vtkSMVRJoystickCameraStyleProxy::GetInvertRightMovement ( )
◆ SetFastMovementMultiplier()
virtual void vtkSMVRJoystickCameraStyleProxy::SetFastMovementMultiplier ( double  )
◆ GetFastMovementMultiplier()
virtual double vtkSMVRJoystickCameraStyleProxy::GetFastMovementMultiplier ( )
◆ SetUpAxis()
virtual void vtkSMVRJoystickCameraStyleProxy::SetUpAxis ( Axis  )
◆ GetUpAxis()
virtual Axis vtkSMVRJoystickCameraStyleProxy::GetUpAxis ( )
◆ Update()
bool vtkSMVRJoystickCameraStyleProxy::Update ( )
◆ UpdateVTKObjects()
void vtkSMVRJoystickCameraStyleProxy::UpdateVTKObjects ( )
◆ HandleButton()
void vtkSMVRJoystickCameraStyleProxy::HandleButton ( const vtkVREvent event)
overrideprotectedvirtual
◆ HandleValuator()
void vtkSMVRJoystickCameraStyleProxy::HandleValuator ( const vtkVREvent event)
