vtkSMVRDebugStyleProxy Class Reference
an interaction style to dump out debug information More...
#include <vtkSMVRDebugStyleProxy.h>
Inheritance diagram for vtkSMVRDebugStyleProxy:
Collaboration diagram for vtkSMVRDebugStyleProxy:
enum  { INTERACTOR_STYLE_REQUEST_CONFIGURE = vtkCommand::UserEvent + 7370, INTERACTOR_STYLE_NAVIGATION = vtkCommand::UserEvent + 7371 }
typedef vtkSMProxy Superclass
typedef std::map< std::string, std::string > StringMap
typedef std::map< std::string, StringMap > StringMapMap
bool Update () override
virtual int GetControlledPropertySize ()
virtual vtkSMProxy * GetControlledProxy ()
virtual void SetIsInternal (bool)
virtual bool GetIsInternal ()
virtual void IsInternalOn ()
virtual void IsInternalOff ()
int GetNumberOfButtonRoles ()
unsigned int GetChannelIndexForValuatorRole (const std::string &role)
void ClearAllRoles ()
virtual vtkPVXMLElement * SaveConfiguration ()
 Save state to xml. More...
vtkMatrix4x4 * GetNavigationMatrix (vtkSMRenderViewProxy *proxy=nullptr)
void UpdateMatrixProperty (vtkSMProxy *proxy, const char *propertyName, vtkMatrix4x4 *matrix)
void SetValuatorLookupTable (std::shared_ptr< StringMapMap >)
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMVRDebugStyleProxy * New ()
static vtkSMVRDebugStyleProxy * SafeDownCast (vtkObject *o)
static vtkSMVRInteractorStyleProxy * New ()
static vtkSMVRInteractorStyleProxy * SafeDownCast (vtkObject *o)
static vtkSMRenderViewProxy * GetActiveViewProxy ()
static vtkCamera * GetActiveCamera ()
static void SetNavigationMatrix (vtkMatrix4x4 *, vtkSMRenderViewProxy *proxy=nullptr)
static std::vector< double > GetNavigationScale (vtkSMRenderViewProxy *proxy=nullptr)
static void SetNavigationScale (const std::vector< double > &scale, vtkSMRenderViewProxy *proxy=nullptr)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMVRDebugStyleProxy ()
 ~vtkSMVRDebugStyleProxy () override=default
void HandleButton (const vtkVREvent &event) override
void HandleValuator (const vtkVREvent &event) override
void HandleTracker (const vtkVREvent &event) override
virtual void SaveProxyProperties (vtkPVXMLElement *xml)
 Load/Save custom properties from the interactor style in the .pvvr file Can be overriden to use a custom mechanism to load/save properties. More...
virtual bool LoadProxyProperties (vtkPVXMLElement *xml, vtkSMProxyLocator *locator)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
static std::vector< std::string > Tokenize (std::string input)
vtkSMProxy * ControlledProxy
char * ControlledPropertyName
StringMap Valuators
StringMap Buttons
StringMap Trackers
bool IsInternal
std::shared_ptr< StringMapMap > valuatorLookupTable
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMVRDebugStyleProxy is an interaction style that binds some button, valuator, and tracker roles, for no other purpose than to dump event information to the terminal.
Definition at line 26 of file vtkSMVRDebugStyleProxy.h.
Definition at line 31 of file vtkSMVRDebugStyleProxy.h.
◆ vtkSMVRDebugStyleProxy()
vtkSMVRDebugStyleProxy::vtkSMVRDebugStyleProxy ( )
◆ ~vtkSMVRDebugStyleProxy()
vtkSMVRDebugStyleProxy::~vtkSMVRDebugStyleProxy ( )
overrideprotecteddefault
static vtkSMVRDebugStyleProxy* vtkSMVRDebugStyleProxy::New ( )
virtual const char* vtkSMVRDebugStyleProxy::GetClassName ( )
static int vtkSMVRDebugStyleProxy::IsTypeOf ( const char *  type)
virtual int vtkSMVRDebugStyleProxy::IsA ( const char *  type)
static vtkSMVRDebugStyleProxy* vtkSMVRDebugStyleProxy::SafeDownCast ( vtkObject *  o)
void vtkSMVRDebugStyleProxy::PrintSelf ( ostream &  os,
◆ Update()
bool vtkSMVRDebugStyleProxy::Update ( )
Typically processing intensive operations go here. The method should not be called from within the handler and is reserved to be called from an external interaction style manager.
◆ HandleButton()
void vtkSMVRDebugStyleProxy::HandleButton ( const vtkVREvent &  event)
overrideprotectedvirtual
◆ HandleValuator()
void vtkSMVRDebugStyleProxy::HandleValuator ( const vtkVREvent &  event)
◆ HandleTracker()
void vtkSMVRDebugStyleProxy::HandleTracker ( const vtkVREvent &  event)
