| int | GetControlledPropertySize () override |
| bool | Update () override |
| | Update() called to update all the remote vtkObjects and perhaps even to render. More...
| void | SetDeferredUpdate (bool deferred) |
| bool | GetDeferredUpdate () |
| virtual void | SetControlledProxy (vtkSMProxy *) |
| virtual vtkSMProxy * | GetControlledProxy () |
| virtual void | SetControlledPropertyName (const char *) |
| virtual char * | GetControlledPropertyName () |
| virtual void | IsInternalOn () |
| virtual void | IsInternalOff () |
| virtual bool | HandleEvent (const vtkVREvent &event) |
| void | GetValuatorRoles (vtkStringList *) |
| void | GetButtonRoles (vtkStringList *) |
| void | GetTrackerRoles (vtkStringList *) |
| int | GetNumberOfValuatorRoles () |
| int | GetNumberOfButtonRoles () |
| int | GetNumberOfTrackerRoles () |
| std::string | GetButtonRole (const std::string &name) |
| std::string | GetTrackerRole (const std::string &name) |
| unsigned int | GetChannelIndexForValuatorRole (const std::string &role) |
| void | AddValuatorRole (const std::string &role) |
| void | AddButtonRole (const std::string &role) |
| void | AddTrackerRole (const std::string &role) |
| void | ClearAllRoles () |
| bool | SetValuatorName (const std::string &role, const std::string &name) |
| std::string | GetValuatorName (const std::string &role) |
| bool | SetButtonName (const std::string &role, const std::string &name) |
| std::string | GetButtonName (const std::string &role) |
| bool | SetTrackerName (const std::string &role, const std::string &name) |
| std::string | GetTrackerName (const std::string &role) |
| virtual bool | Configure (vtkPVXMLElement *child, vtkSMProxyLocator *) |
| | Load state for the style from XML. More...
| virtual vtkPVXMLElement * | SaveConfiguration () |
| | Save state to xml. More...
| vtkMatrix4x4 * | GetNavigationMatrix (vtkSMRenderViewProxy *proxy=nullptr) |
| void | UpdateMatrixProperty (vtkSMProxy *proxy, const char *propertyName, vtkMatrix4x4 *matrix) |
| void | SetValuatorLookupTable (std::shared_ptr< StringMapMap >) |
| virtual bool | GetNeedsUpdate () |
| | Returns if the underlying VTK object needs to be updated or not. More...
| bool | IsDeprecated () |
| | Returns true if the proxy has a deprecation tag. More...
| bool | GetIsSubProxy () |
| | Return the property names that have values different from the otherProxy argument. More...
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMVRControlOrientationStyleProxy () |
| | ~vtkSMVRControlOrientationStyleProxy () override=default |
| void | HandleButton (const vtkVREvent &event) override |
| void | HandleTracker (const vtkVREvent &event) override |
| void | SaveProxyProperties (vtkPVXMLElement *xml) override |
| | Save/Load "DeferredUpdate" property with custom XML label. More...
| bool | LoadProxyProperties (vtkPVXMLElement *xml, vtkSMProxyLocator *locator) override |
| | vtkSMVRInteractorStyleProxy () |
| virtual | ~vtkSMVRInteractorStyleProxy () |
| virtual void | HandleValuator (const vtkVREvent &event) |
| void | MapKeysToStringList (const StringMap &source, vtkStringList *target) |
| bool | SetValueInMap (StringMap &map_, const std::string &key, const std::string &value) |
| std::string | GetValueInMap (const StringMap &map_, const std::string &key) |
| std::string | GetKeyInMap (const StringMap &map_, const std::string &value) |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| virtual void | ExecuteStream (const vtkClientServerStream &msg, bool ignore_errors=false, vtkTypeUInt32 location=0) |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | This is called by PostUpdateData to only update state for this proxy without iterative over producers. More...
| | If a proxy need to ensure a plugin is loaded, make sure it is. More...
| | Set the "EnsurePluginLoaded" XML element that is used in LoadPluginIfEnsured. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
