vtkSMVRControlLocationStyleProxy Class Reference
an interaction style to control the position of a point with a tracker More...
#include <vtkSMVRControlLocationStyleProxy.h>
Inheritance diagram for vtkSMVRControlLocationStyleProxy:
Collaboration diagram for vtkSMVRControlLocationStyleProxy:
enum  { INTERACTOR_STYLE_REQUEST_CONFIGURE = vtkCommand::UserEvent + 7370, INTERACTOR_STYLE_NAVIGATION = vtkCommand::UserEvent + 7371 }
typedef vtkSMProxy Superclass
typedef std::map< std::string, std::stringStringMap
typedef std::map< std::string, StringMapStringMapMap
int GetControlledPropertySize () override
bool Update () override
void SetDeferredUpdate (bool deferred)
bool GetDeferredUpdate ()
virtual vtkSMProxyGetControlledProxy ()
virtual void SetIsInternal (bool)
virtual bool GetIsInternal ()
virtual void IsInternalOn ()
virtual void IsInternalOff ()
int GetNumberOfButtonRoles ()
unsigned int GetChannelIndexForValuatorRole (const std::string &role)
void ClearAllRoles ()
virtual vtkPVXMLElementSaveConfiguration ()
 Save state to xml. More...
vtkMatrix4x4GetNavigationMatrix (vtkSMRenderViewProxy *proxy=nullptr)
void UpdateMatrixProperty (vtkSMProxy *proxy, const char *propertyName, vtkMatrix4x4 *matrix)
void SetValuatorLookupTable (std::shared_ptr< StringMapMap >)
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
vtkSMProxyGetParentProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMVRControlLocationStyleProxyNew ()
static vtkSMVRControlLocationStyleProxySafeDownCast (vtkObject *o)
static vtkSMVRInteractorStyleProxyNew ()
static vtkSMVRInteractorStyleProxySafeDownCast (vtkObject *o)
static vtkSMRenderViewProxyGetActiveViewProxy ()
static vtkCameraGetActiveCamera ()
static void SetNavigationMatrix (vtkMatrix4x4 *, vtkSMRenderViewProxy *proxy=nullptr)
static std::vector< doubleGetNavigationScale (vtkSMRenderViewProxy *proxy=nullptr)
static void SetNavigationScale (const std::vector< double > &scale, vtkSMRenderViewProxy *proxy=nullptr)
static vtkSMProxyNew ()
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMVRControlLocationStyleProxy ()
 ~vtkSMVRControlLocationStyleProxy () override=default
void HandleButton (const vtkVREvent &event) override
void HandleTracker (const vtkVREvent &event) override
void SaveProxyProperties (vtkPVXMLElement *xml) override
 Save/Load "DeferredUpdate" property with custom XML label. More...
bool LoadProxyProperties (vtkPVXMLElement *xml, vtkSMProxyLocator *locator) override
virtual void HandleValuator (const vtkVREvent &event)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
static std::vector< std::stringTokenize (std::string input)
vtkSMProxyControlledProxy
char * ControlledPropertyName
StringMap Valuators
StringMap Buttons
StringMap Trackers
bool IsInternal
std::shared_ptr< StringMapMapvaluatorLookupTable
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElementXMLElement
vtkSMMessageState
int InMarkModified
vtkSMProxyInternalsInternals
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMVRControlLocationStyleProxy is an interaction style that uses only the position of the tracker to control the position of a 3D point.
Definition at line 21 of file vtkSMVRControlLocationStyleProxy.h.
Definition at line 26 of file vtkSMVRControlLocationStyleProxy.h.
◆ vtkSMVRControlLocationStyleProxy()
vtkSMVRControlLocationStyleProxy::vtkSMVRControlLocationStyleProxy ( )
◆ ~vtkSMVRControlLocationStyleProxy()
vtkSMVRControlLocationStyleProxy::~vtkSMVRControlLocationStyleProxy ( )
overrideprotecteddefault
static vtkSMVRControlLocationStyleProxy* vtkSMVRControlLocationStyleProxy::New ( )
virtual const char* vtkSMVRControlLocationStyleProxy::GetClassName ( )
static int vtkSMVRControlLocationStyleProxy::IsTypeOf ( const char *  type)
virtual int vtkSMVRControlLocationStyleProxy::IsA ( const char *  type)
static vtkSMVRControlLocationStyleProxy* vtkSMVRControlLocationStyleProxy::SafeDownCast ( vtkObject o)
void vtkSMVRControlLocationStyleProxy::PrintSelf ( ostream &  os,
◆ GetControlledPropertySize()
int vtkSMVRControlLocationStyleProxy::GetControlledPropertySize ( )
inlineoverridevirtual
Definition at line 29 of file vtkSMVRControlLocationStyleProxy.h.
◆ Update()
bool vtkSMVRControlLocationStyleProxy::Update ( )
Typically processing intensive operations go here. The method should not be called from within the handler and is reserved to be called from an external interaction style manager.
◆ SetDeferredUpdate()
void vtkSMVRControlLocationStyleProxy::SetDeferredUpdate ( bool  deferred)
◆ GetDeferredUpdate()
bool vtkSMVRControlLocationStyleProxy::GetDeferredUpdate ( )
◆ SaveProxyProperties()
void vtkSMVRControlLocationStyleProxy::SaveProxyProperties ( vtkPVXMLElement xml)
overrideprotectedvirtual
◆ LoadProxyProperties()
bool vtkSMVRControlLocationStyleProxy::LoadProxyProperties ( vtkPVXMLElement xml,
vtkSMProxyLocator locator
◆ HandleButton()
void vtkSMVRControlLocationStyleProxy::HandleButton ( const vtkVREvent event)
◆ HandleTracker()
void vtkSMVRControlLocationStyleProxy::HandleTracker ( const vtkVREvent event)
