vtkSMTransferFunction2DProxy is the proxy used for "TransferFunction2D". More...
#include <vtkSMTransferFunction2DProxy.h>
| virtual bool | RescaleTransferFunction (const double range[4], bool extend=false) |
| Rescale the control boxes for the 2D transfer function to match the new range. More... | |
| virtual bool | RescaleTransferFunction (double rangeXMin, double rangeXMax, double rangeYMin, double rangeYMax, bool extend=false) |
Public Member Functions inherited from vtkSMProxy | |
| Retrieve an annotation with a given key. More... | |
| Remove a given annotation based on its key to the proxy. More... | |
| Remove all proxy annotations. More... | |
| Return true if a given annotation exists. More... | |
| Return the number of available annotations. More... | |
| Return the nth key of the available annotations. More... | |
| Return the property with the given name. More... | |
| Return a property of the given name from self or one of the sub-proxies. More... | |
| Given a property pointer, returns the name that was used to add it to the proxy. More... | |
| Update the VTK object on the server by pushing the values of all modified properties (un-modified properties are ignored). More... | |
| Recreate the VTK object for this proxy. More... | |
| Convenience method equivalent to UpdateProperty(name, 1). More... | |
| virtual bool | GetNeedsUpdate () |
| Returns if the underlying VTK object needs to be updated or not. More... | |
| Returns a new (initialized) iterator of the properties. More... | |
| Returns the number of consumers. More... | |
| Returns the consumer of given index. More... | |
| Returns the corresponding property of the consumer of given index. More... | |
| Returns the number of proxies this proxy depends on (uses or is connected to through the pipeline). More... | |
| Returns a proxy this proxy depends on, given index. More... | |
| Returns the property holding a producer proxy given an index. More... | |
| Updates all property information by calling UpdateInformation() and populating the values. More... | |
| Similar to UpdatePropertyInformation() but updates only the given property. More... | |
| Marks all properties as modified. More... | |
| Use this method to set all properties on this proxy to their default values. More... | |
| Use this method to set all properties on this proxy to their default domains. More... | |
| Use this method to set all properties on this proxy to their default domain or values. More... | |
| Calls MarkDirty() and invokes ModifiedEvent. More... | |
| bool | IsDeprecated () |
| Returns true if the proxy has a deprecation tag. More... | |
| Given a source proxy, makes this proxy point to the same server-side object (with a new id). More... | |
| Dirty means this algorithm will execute during next update. More... | |
| Returns the client side object associated with the VTKObjectID (if any). More... | |
| Saves the state of the proxy. More... | |
| The iterator is use to filter the property available on the given proxy. More... | |
| Loads the proxy state from the XML element. More... | |
| This method call UpdateVTKObjects on the current pipeline by starting at the sources. More... | |
| bool | GetIsSubProxy () |
| A proxy instance can be a sub-proxy for some other proxy. More... | |
| If this instance is a sub-proxy, this method will return the proxy of which this instance is an immediate sub-proxy. More... | |
| Call GetParentProxy() recursively till a proxy that is not a subproxy of any other proxy is found. More... | |
| This method return the full object state that can be used to create that object from scratch. More... | |
| This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set. More... | |
| Returns the number of property groups that the proxy contains. More... | |
| Return the property names that have values different from the otherProxy argument. More... | |
| Update the value of one property (pushed to the server) if it is modified. More... | |
| Returns the type of object managed by the proxy. More... | |
| the type of object created by the proxy. More... | |
| Copies values of all the properties and sub-proxies from src. More... | |
| Returns if the VTK objects for this proxy have been created. More... | |
| Gathers information about this proxy. More... | |
| Log name is a name for this proxy that will be used when logging status messages. More... | |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| static vtkSMTransferFunction2DProxy * | New () |
| Instantiate the class. More... | |
| static bool | RescaleTransferFunction (vtkSMProxy *proxy, double rangeXMin, double rangeXMax, double rangeYMin, double rangeYMax, bool extend=false) |
| Safely call RescaleTransferFunction() after casting the proxy to appropriate type. More... | |
| static bool | RescaleTransferFunction (vtkSMProxy *proxy, const double range[4], bool extend=false) |
Static Public Member Functions inherited from vtkSMProxy | |
| static vtkSMProxy * | New () |
| static vtkSMProxy * | SafeDownCast (vtkObject *o) |
Static Public Attributes | |
| static const int | BOX_PROPERTY_SIZE = 8 |
| Expected tuple size of the boxes property of the proxy. More... | |
| vtkSMTransferFunction2DProxy ()=default | |
| ~vtkSMTransferFunction2DProxy () override=default | |
Protected Member Functions inherited from vtkSMProxy | |
| vtkSMProxy () | |
| ~vtkSMProxy () override | |
| virtual void | ExecuteStream (const vtkClientServerStream &msg, bool ignore_errors=false, vtkTypeUInt32 location=0) |
| Invoke that takes a vtkClientServerStream as the argument. More... | |
| Add a property with the given key (name). More... | |
MarkConsumersAsDirty calls this method on each consumer, instead of directly calling MarkDirty on the consumer. More... | |
| This method is called by vtkSMRepresentationProxy whenever the time request for the pipeline may have potentially changed. More... | |
| Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s) More... | |
| Cleanup code. More... | |
| Note on property modified flags: The modified flag of each property associated with a proxy is stored in the proxy object instead of in the property itself. More... | |
| Add a sub-proxy. More... | |
| Remove a sub-proxy. More... | |
| Returns a sub-proxy. More... | |
| Returns the name used to store sub-proxy. More... | |
| Returns the number of sub-proxies. More... | |
| Called by a proxy property, this adds the property,proxy pair to the list of consumers. More... | |
| Remove the property,proxy pair from the list of consumers. More... | |
| Remove all consumers. More... | |
| Called by an proxy/input property to add property, proxy pair to the list of producers. More... | |
| Remove the property,proxy pair from the list of producers. More... | |
| This method is called after the algorithm(s) (if any) associated with this proxy execute. More... | |
This is called by PostUpdateData to only update state for this proxy without iterative over producers. More... | |
| If a proxy need to ensure a plugin is loaded, make sure it is. More... | |
| This method simply iterates over subproxies and calls UpdatePipelineInformation() on them. More... | |
| Links properties such that when inputProperty's checked or unchecked values are changed, the outputProperty's corresponding values are also changed. More... | |
| Parses the XML to create a new property group. More... | |
| Adds a property groups. More... | |
| Expose a subproxy property from the base proxy. More... | |
| Handle events fired by subproxies. More... | |
| Called to update the property information on the property. More... | |
| vtkSMProxy tracks state of properties on this proxy in an internal State object. More... | |
Internal method used by SetLogName More... | |
| Indicates if any properties are modified. More... | |
| Set the "EnsurePluginLoaded" XML element that is used in LoadPluginIfEnsured. More... | |
| vtkSMProxy (const vtkSMProxy &)=delete | |
| Get the last result. More... | |
| Creates a new property and initializes it by calling ReadXMLAttributes() with the right XML element. More... | |
| Read attributes from an XML element. More... | |
| SIClassName identifies the classname for the helper on the server side. More... | |
| vtkSMRemoteObject () | |
| Destructor. More... | |
| vtkSMSessionObject () | |
| vtkSMObject () | |
Protected Attributes | |
| vtkSmartPointer< vtkImageData > | Histogram2DCache |
| Cache for the 2D histogram image. More... | |
Protected Attributes inherited from vtkSMProxy | |
| bool | NeedsUpdate |
| char * | VTKClassName |
| char * | XMLGroup |
| char * | XMLName |
| char * | XMLLabel |
| char * | XMLSubProxyName |
| int | ObjectsCreated |
| int | DoNotUpdateImmediately |
| int | DoNotModifyProperty |
| int | InUpdateVTKObjects |
| Avoids calls to UpdateVTKObjects in UpdateVTKObjects. More... | |
| bool | PropertiesModified |
| Flag used to help speed up UpdateVTKObjects and ArePropertiesModified calls. More... | |
| vtkPVXMLElement * | XMLElement |
| vtkSMDocumentation * | Documentation |
| vtkPVXMLElement * | Hints = nullptr |
| vtkPVXMLElement * | Deprecated = nullptr |
| vtkPVXMLElement * | EnsurePluginLoaded = nullptr |
| vtkSMMessage * | State |
| int | InMarkModified |
| vtkWeakPointer< vtkSMProxy > | ParentProxy |
| vtkSMProxyInternals * | Internals |
| vtkSMProxyObserver * | SubProxyObserver |
| char * | SIClassName |
Protected Attributes inherited from vtkSMRemoteObject | |
| vtkTypeUInt32 | GlobalID |
| vtkTypeUInt32 | Location |
| bool | Prototype |
| bool | ClientOnlyLocationFlag |
| typedef vtkSMProxy | Superclass |
| Standard methods for the VTK class. More... | |
| static vtkSMTransferFunction2DProxy * | SafeDownCast (vtkObject *o) |
| static bool | RescaleTransferFunctionToDataRange (vtkSMProxy *proxy, bool extend=false) |
| Locates all representations that are currently using this transfer function and then rescales the transfer function scalar range to exactly match the combined valid scalar ranges obtained from them all. More... | |
| virtual bool | RescaleTransferFunctionToDataRange (bool extend=false) |
| static bool | ComputeDataRange (vtkSMProxy *proxy, double range[4]) |
| Helper method used by RescaleTransferFunctionToDataRange() to compute range from all visible representations using the transfer function. More... | |
| virtual bool | ComputeDataRange (double range[4]) |
| static vtkSmartPointer< vtkImageData > | ComputeDataHistogram2D (vtkSMProxy *proxy, int numberOfBins) |
| Helper method used to compute a 2D histogram image with provided number of bins based on the data from all the visible representations using the transfer function. More... | |
| virtual vtkSmartPointer< vtkImageData > | ComputeDataHistogram2D (int numberOfBins) |
| static vtkImageData * | GetHistogram2DCache (vtkSMProxy *proxy) |
| Helper method used to recover the last histogram computed by ComputeDataHistogram2D Returns the histogram as a vtkImageData if available, nullptr otherwise. More... | |
| virtual vtkImageData * | GetHistogram2DCache () |
| static bool | GetRange (vtkSMProxy *proxy, double range[4]) |
| Returns current transfer function data range. More... | |
| virtual bool | GetRange (double range[4]) |
Public Types inherited from vtkSMProxy | |
| enum | ResetPropertiesMode { DEFAULT = 0, ONLY_XML = 1, ONLY_DOMAIN = 2 } |
| enum | { COPY_PROXY_PROPERTY_VALUES_BY_REFERENCE = 0, COPY_PROXY_PROPERTY_VALUES_BY_CLONING } |
| Flags used for the proxyPropertyCopyFlag argument to the Copy method. More... | |
vtkSMTransferFunction2DProxy provides the utility API to update 2D transfer function range, control boxes, etc.
Definition at line 24 of file vtkSMTransferFunction2DProxy.h.
Definition at line 36 of file vtkSMTransferFunction2DProxy.h.
protecteddefault |
overrideprotecteddefault |
inlinevirtual |
Returns true if rescale was successful. If extend is true (false by default), the transfer function range will only be extended as needed to fit the data range.
Definition at line 46 of file vtkSMTransferFunction2DProxy.h.
inlinestatic |
Definition at line 60 of file vtkSMTransferFunction2DProxy.h.
inlinestatic |
Definition at line 74 of file vtkSMTransferFunction2DProxy.h.
Returns true if a valid range was determined.
inlinestatic |
Definition at line 88 of file vtkSMTransferFunction2DProxy.h.
If successful, returns the histogram as a vtkImageData of type double. If not, returns nullptr.
inlinestatic |
Definition at line 103 of file vtkSMTransferFunction2DProxy.h.
inlinevirtual |
Definition at line 115 of file vtkSMTransferFunction2DProxy.h.
inlinestatic |
Definition at line 116 of file vtkSMTransferFunction2DProxy.h.
Returns false is a valid range could not be determined.
inlinestatic |
Definition at line 129 of file vtkSMTransferFunction2DProxy.h.
Internal use only.
Definition at line 140 of file vtkSMTransferFunction2DProxy.h.
Definition at line 150 of file vtkSMTransferFunction2DProxy.h.
1.8.13 on Sat Oct 10 2026
