| unsigned int | GetNumberOfLinkedObjects () override |
| | Get the number of properties that are involved in this link. More...
| vtkSMProxy * | GetLinkedProxy (int index) override |
| | Get a proxy involved in this link. More...
| int | GetLinkedObjectDirection (int index) override |
| | Get the direction of a Selection involved in this link (see vtkSMLink::UpdateDirections) More...
| void | RemoveAllLinks () override |
| | Remove all links. More...
| | This method is used to initialize the object to the given protobuf state. More...
| virtual void | SetConvertToIndices (bool) |
| | Set/Get the convert to indices flag. More...
| virtual bool | GetConvertToIndices () |
| void | AddLinkedSelection (vtkSMProxy *proxy, int updateDir) |
| | Add a selection to the link. More...
| void | RemoveLinkedSelection (vtkSMProxy *proxy) |
| | This method returns the full object state that can be used to create the object from scratch. More...
| virtual void | SetPropagateUpdateVTKObjects (int) |
| | This flag determines if UpdateVTKObjects calls are to be propagated. More...
| virtual int | GetPropagateUpdateVTKObjects () |
| virtual void | PropagateUpdateVTKObjectsOn () |
| virtual void | PropagateUpdateVTKObjectsOff () |
| virtual void | SetEnabled (bool) |
| | Get/Set if the link is enabled. More...
| virtual bool | GetEnabled () |
| bool | HasGlobalID () |
| virtual void | EnableLocalPushOnly () |
| virtual void | DisableLocalPushOnly () |
| virtual void | SetLocation (vtkTypeUInt32) |
| virtual void | PrototypeOn () |
| virtual void | PrototypeOff () |
| bool | IsPrototype () |
| virtual void | SetPrototype (bool) |
| | vtkSMSelectionLink () |
| | ~vtkSMSelectionLink () override |
| int | LoadXMLState (vtkPVXMLElement *linkElement, vtkSMProxyLocator *locator) override |
| | Load the link state. More...
| void | SaveXMLState (const char *linkname, vtkPVXMLElement *parent) override |
| | Save the state of the link. More...
| void | UpdateVTKObjects (vtkSMProxy *vtkNotUsed(caller)) override |
| | Not implemented. More...
| void | PropertyModified (vtkSMProxy *vtkNotUsed(caller), const char *vtkNotUsed(pname)) override |
| void | UpdateProperty (vtkSMProxy *vtkNotUsed(caller), const char *vtkNotUsed(pname)) override |
| virtual void | SelectionModified (vtkSMSourceProxy *caller, unsigned int portIndex) |
| | This method find the caller in the link and update selection output accordingly. More...
| void | UpdateState () override |
| | Update the internal protobuf state. More...
| | vtkSMLink () |
| | ~vtkSMLink () override |
| void | PushStateToSession () |
| | When the state has changed we call that method so the state can be shared if any collaboration is involved. More...
| virtual void | UpdateVTKObjects (vtkSMProxy *proxy)=0 |
| | Called when an input proxy is updated (UpdateVTKObjects). More...
| virtual void | PropertyModified (vtkSMProxy *proxy, const char *pname)=0 |
| | Called when a property of an input proxy is modified. More...
| virtual void | UpdateProperty (vtkSMProxy *caller, const char *pname)=0 |
| | Called when a property is pushed. More...
| void | ObserveProxyUpdates (vtkSMProxy *proxy) |
| | Subclasses call this method to observer events on a INPUT proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
Creates a link between two properties.
Can create M->N links. At the time when the link is created every output Selection is synchronized with the first input Selection.
Definition at line 21 of file vtkSMSelectionLink.h.
