| int | Undo () override |
| | Undo the operation encapsulated by this element. More...
| int | Redo () override |
| | Redo the operation encaspsulated by this element. More...
| virtual void | SetProxyLocator (vtkSMProxyLocator *) |
| | Set ProxyLocator to use if any. More...
| virtual void | SetUndoRedoState (const vtkSMMessage *before, const vtkSMMessage *after) |
| | Set the state of the UndoElement. More...
| virtual vtkTypeUInt32 | GetGlobalId () |
| virtual bool | Merge (vtkUndoElement *vtkNotUsed(new_element)) |
| | Called on the older element in the UndoSet to merge with the element being added if both the elements are mergeable. More...
| virtual void | SetUndoSetWorkingContext (vtkCollection *workCTX) |
| virtual bool | GetMergeable () |
| | Returns if this undo element can be merged with other undo elements. More...
vtkSMRemoteObject undo element.
This class keeps the before and after state of the RemoteObject in the vtkSMMessage form. It works with any proxy and RemoteObject. It is a very generic undoElement.
Definition at line 22 of file vtkSMRemoteObjectUpdateUndoElement.h.
