vtkSMProxyDefinitionManager is a remote-object that represents the vtkSIProxyDefinitionManager instance on all the processes. More...
#include <vtkSMProxyDefinitionManager.h>
| enum | Events { ProxyDefinitionsUpdated = vtkSIProxyDefinitionManager::ProxyDefinitionsUpdated, CompoundProxyDefinitionsUpdated = vtkSIProxyDefinitionManager::CompoundProxyDefinitionsUpdated } |
| enum | { ALL_DEFINITIONS = vtkSIProxyDefinitionManager::ALL_DEFINITIONS, CORE_DEFINITIONS = vtkSIProxyDefinitionManager::CORE_DEFINITIONS, CUSTOM_DEFINITIONS = vtkSIProxyDefinitionManager::CUSTOM_DEFINITIONS } |
| void | SynchronizeDefinitions () |
| Synchronizes the client-side definitions using the server-side definitions, if applicable. More... | |
| Overridden call SynchronizeDefinitions() when the session changes. More... | |
| vtkPVXMLElement * | GetCollapsedProxyDefinition (const char *group, const char *name, const char *subProxyName, bool throwError) |
| Returns the same thing as GetProxyDefinition in a flatten manner. More... | |
| bool | HasDefinition (const char *groupName, const char *proxyName) |
| Return true if the XML Definition was found. More... | |
| void | SaveCustomProxyDefinitions (vtkPVXMLElement *root) |
| Save registered custom proxy definitions. More... | |
| This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set. More... | |
| vtkPVXMLElement * | GetProxyDefinition (const char *group, const char *name, bool throwError) |
| Returns a registered proxy definition or return a nullptr otherwise. More... | |
| vtkPVXMLElement * | GetProxyDefinition (const char *group, const char *name) |
| VTK_NEWINSTANCE vtkPVProxyDefinitionIterator * | NewIterator () |
| Return a NEW instance of vtkPVProxyDefinitionIterator configured to get through all the definition available for the requested scope. More... | |
| VTK_NEWINSTANCE vtkPVProxyDefinitionIterator * | NewIterator (int scope) |
| vtkPVProxyDefinitionIterator * | NewSingleGroupIterator (const char *groupName) |
| Return a new configured iterator for traversing a set of proxy definition for only one GroupName. More... | |
| vtkPVProxyDefinitionIterator * | NewSingleGroupIterator (const char *groupName, int scope) |
| void | AddCustomProxyDefinition (const char *group, const char *name, vtkPVXMLElement *top) |
| Add/Remove/Clear custom proxy definitions. More... | |
| void | RemoveCustomProxyDefinition (const char *group, const char *name) |
| void | ClearCustomProxyDefinitions () |
| void | LoadCustomProxyDefinitions (vtkPVXMLElement *root) |
| Load custom proxy definitions and register them. More... | |
| void | LoadCustomProxyDefinitionsFromString (const char *xmlContent) |
| bool | LoadConfigurationXML (vtkPVXMLElement *root) |
| Loads server-manager configuration xml. More... | |
| bool | LoadConfigurationXMLFromString (const char *xmlContent) |
| bool | HasGlobalID () |
| virtual const vtkSMMessage * | GetFullState () |
| This method return the full object state that can be used to create that object from scratch. More... | |
| virtual void | EnableLocalPushOnly () |
| virtual void | DisableLocalPushOnly () |
| virtual void | SetLocation (vtkTypeUInt32) |
| virtual void | PrototypeOn () |
| virtual void | PrototypeOff () |
| bool | IsPrototype () |
| virtual void | SetPrototype (bool) |
| static vtkSMProxyDefinitionManager * | New () |
| static vtkSMProxyDefinitionManager * | SafeDownCast (vtkObject *o) |
| vtkSMProxyDefinitionManager () | |
| ~vtkSMProxyDefinitionManager () override | |
| vtkSMRemoteObject () | |
| Destructor. More... | |
| vtkSMSessionObject () | |
| vtkSMObject () | |
Protected Attributes | |
| vtkEventForwarderCommand * | Forwarder |
| vtkWeakPointer< vtkSIProxyDefinitionManager > | ProxyDefinitionManager |
Protected Attributes inherited from vtkSMRemoteObject | |
| vtkTypeUInt32 | GlobalID |
| vtkTypeUInt32 | Location |
| bool | Prototype |
| bool | ClientOnlyLocationFlag |
ParaView clients should use API on this class to add/update xml definitions to ensure that the xmls are processed/updated correctly on all the processes.
Definition at line 24 of file vtkSMProxyDefinitionManager.h.
Definition at line 28 of file vtkSMProxyDefinitionManager.h.
| Enumerator | |
| ProxyDefinitionsUpdated | |
| CompoundProxyDefinitionsUpdated | |
Definition at line 47 of file vtkSMProxyDefinitionManager.h.
| anonymous enum |
| Enumerator | |
| ALL_DEFINITIONS | |
| CORE_DEFINITIONS | |
| CUSTOM_DEFINITIONS | |
Definition at line 53 of file vtkSMProxyDefinitionManager.h.
Reimplemented from vtkSMRemoteObject.
| void vtkSMProxyDefinitionManager::SynchronizeDefinitions | ( | ) |
Call this method after any code that could result in changing of the XML definitions on the server e.g. loading of plugins.
Also ensures that the internal references to vtkSIProxyDefinitionManager are updated correctly.
Reimplemented from vtkSMSessionObject.
Moreover, error can be throw if the definition was not found if the flag throwError is true.
Definition at line 70 of file vtkSMProxyDefinitionManager.h.
Definition at line 76 of file vtkSMProxyDefinitionManager.h.
By flatten, we mean that the class hierarchy has been walked and merged into a single vtkPVXMLElement definition.
Definition at line 89 of file vtkSMProxyDefinitionManager.h.
Definition at line 100 of file vtkSMProxyDefinitionManager.h.
The caller must release the reference to the returned vtkPVXMLElement.
Definition at line 111 of file vtkSMProxyDefinitionManager.h.
Possible scope defined as enum inside vtkSIProxyDefinitionManager: ALL_DEFINITIONS=0 / CORE_DEFINITIONS=1 / CUSTOM_DEFINITIONS=2 Some extra restriction can be set directly on the iterator itself by setting a set of GroupName...
Definition at line 129 of file vtkSMProxyDefinitionManager.h.
Definition at line 134 of file vtkSMProxyDefinitionManager.h.
Definition at line 148 of file vtkSMProxyDefinitionManager.h.
Definition at line 154 of file vtkSMProxyDefinitionManager.h.
| void vtkSMProxyDefinitionManager::AddCustomProxyDefinition | ( | const char * | group, |
| const char * | name, | ||
| vtkPVXMLElement * | top | ||
| void vtkSMProxyDefinitionManager::RemoveCustomProxyDefinition | ( | const char * | group, |
| const char * | name | ||
| void vtkSMProxyDefinitionManager::ClearCustomProxyDefinitions | ( | ) |
| void vtkSMProxyDefinitionManager::LoadCustomProxyDefinitions | ( | vtkPVXMLElement * | root | ) |
| void vtkSMProxyDefinitionManager::LoadCustomProxyDefinitionsFromString | ( | const char * | xmlContent | ) |
| bool vtkSMProxyDefinitionManager::LoadConfigurationXML | ( | vtkPVXMLElement * | root | ) |
| bool vtkSMProxyDefinitionManager::LoadConfigurationXMLFromString | ( | const char * | xmlContent | ) |
This allow to split the load process in 2 step to prevent invalid state when property refere to a sub-proxy that does not exist yet.
Definition at line 204 of file vtkSMProxyDefinitionManager.h.
Definition at line 205 of file vtkSMProxyDefinitionManager.h.
1.8.13 on Sat Oct 10 2026
