Creates a link between two properties. More...
#include <vtkSMPropertyLink.h>
| typedef vtkSMLink | Superclass |
Public Types inherited from vtkSMLink | |
| enum | UpdateDirections { NONE = 0, INPUT = 1, OUTPUT = 2 } |
| vtkSMProxy * | GetLinkedProxy (int index) override |
| Get a proxy involved in this link. More... | |
| const char * | GetLinkedPropertyName (int index) |
| Get a property involved in this link. More... | |
| void | RemoveAllLinks () override |
| Remove all links. More... | |
| This method is used to initialize the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalIDs set. More... | |
| void | AddLinkedProperty (vtkSMProxy *proxy, const char *propertyname, int updateDir) |
| Add a property to the link. More... | |
| void | RemoveLinkedProperty (vtkSMProxy *proxy, const char *propertyname) |
| unsigned int | GetNumberOfLinkedObjects () override |
| Get the number of properties that are involved in this link. More... | |
| unsigned int | GetNumberOfLinkedProperties () |
| int | GetLinkedObjectDirection (int index) override |
| Get the direction of a property involved in this link (see vtkSMLink::UpdateDirections) More... | |
| int | GetLinkedPropertyDirection (int index) |
Public Member Functions inherited from vtkSMLink | |
| This method returns the full object state that can be used to create the object from scratch. More... | |
| virtual void | SetPropagateUpdateVTKObjects (int) |
| This flag determines if UpdateVTKObjects calls are to be propagated. More... | |
| virtual int | GetPropagateUpdateVTKObjects () |
| virtual void | PropagateUpdateVTKObjectsOn () |
| virtual void | PropagateUpdateVTKObjectsOff () |
| virtual void | SetEnabled (bool) |
| Get/Set if the link is enabled. More... | |
| virtual bool | GetEnabled () |
| bool | HasGlobalID () |
| virtual void | EnableLocalPushOnly () |
| virtual void | DisableLocalPushOnly () |
| virtual void | SetLocation (vtkTypeUInt32) |
| virtual void | PrototypeOn () |
| virtual void | PrototypeOff () |
| bool | IsPrototype () |
| virtual void | SetPrototype (bool) |
| static vtkSMPropertyLink * | New () |
| static vtkSMPropertyLink * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSMLink | |
| static vtkSMLink * | SafeDownCast (vtkObject *o) |
| vtkSMPropertyLink () | |
| ~vtkSMPropertyLink () override | |
| void | Synchronize () |
| Synchronize the value of all output properties with the input property. More... | |
| int | LoadXMLState (vtkPVXMLElement *linkElement, vtkSMProxyLocator *locator) override |
| Load the link state. More... | |
| void | SaveXMLState (const char *linkname, vtkPVXMLElement *parent) override |
| Save the state of the link. More... | |
| void | UpdateVTKObjects (vtkSMProxy *caller) override |
| Called when an input proxy is updated (UpdateVTKObjects). More... | |
| void | PropertyModified (vtkSMProxy *caller, const char *pname) override |
| Called when a property of an input proxy is modified. More... | |
| void | UpdateProperty (vtkSMProxy *caller, const char *pname) override |
| Called when a property is pushed. More... | |
| void | UpdateState () override |
| Update the internal protobuf state. More... | |
Protected Member Functions inherited from vtkSMLink | |
| vtkSMLink () | |
| ~vtkSMLink () override | |
| void | PushStateToSession () |
| When the state has changed we call that method so the state can be shared if any collaboration is involved. More... | |
| void | ObserveProxyUpdates (vtkSMProxy *proxy) |
| Subclasses call this method to observer events on a INPUT proxy. More... | |
| vtkSMRemoteObject () | |
| Destructor. More... | |
| vtkSMSessionObject () | |
| vtkSMObject () | |
Friends | |
| class | vtkSMPropertyLinkInternals |
| class | vtkSMPropertyLinkObserver |
Protected Attributes inherited from vtkSMLink | |
| vtkCommand * | Observer |
| int | PropagateUpdateVTKObjects |
| bool | Enabled |
| vtkSMMessage * | State |
Protected Attributes inherited from vtkSMRemoteObject | |
| vtkTypeUInt32 | GlobalID |
| vtkTypeUInt32 | Location |
| bool | Prototype |
| bool | ClientOnlyLocationFlag |
Can create M->N links. At the time when the link is created every output property is synchornized with the first input property.
Definition at line 21 of file vtkSMPropertyLink.h.
Definition at line 25 of file vtkSMPropertyLink.h.
Reimplemented from vtkSMLink.
| void vtkSMPropertyLink::AddLinkedProperty | ( | vtkSMProxy * | proxy, |
| const char * | propertyname, | ||
| int | updateDir | ||
updateDir determines whether a property of the proxy is read or written. When a property of an input proxy changes, it's value is pushed to all other output proxies in the link. A property can be set to be both input and output by adding 2 links, one to INPUT and the other to OUTPUT When a link is added, all output property values are synchronized with that of the input.
| void vtkSMPropertyLink::RemoveLinkedProperty | ( | vtkSMProxy * | proxy, |
| const char * | propertyname | ||
Implements vtkSMLink.
| unsigned int vtkSMPropertyLink::GetNumberOfLinkedProperties | ( | ) |
Remove all links.
This enables splitting the load process in 2 step to prevent invalid state when a property refers to a sub-proxy that does not exist yet.
overrideprotectedvirtual |
Argument is the input proxy.
caller:- the input proxy. pname:- name of the property being modified.
caller :- the input proxy. pname :- name of property that was pushed.
friend |
Definition at line 92 of file vtkSMPropertyLink.h.
friend |
Definition at line 93 of file vtkSMPropertyLink.h.
1.8.13 on Sat Oct 10 2026
