| virtual void | SetExternalProxy (vtkSMSourceProxy *proxyFromAnotherServer, int port=0) |
| | Bind proxy with a given external proxy. More...
| virtual vtkSMSourceProxy * | GetExternalProxy () |
| | Return the proxy that is currently binded if any otherwise return nullptr;. More...
| void | MarkDirty (vtkSMProxy *modifiedProxy) override |
| | Marks the selection proxies dirty as well as chain to superclass. More...
| void | LoadState (const vtkSMMessage *message, vtkSMProxyLocator *locator) override |
| void | UpdatePipelineInformation () override |
| | Calls UpdateInformation() on all sources. More...
| virtual void | UpdatePipeline () |
| | Calls Update() on all sources. More...
| virtual void | UpdatePipeline (double time) |
| | Calls Update() on all sources with the given time request. More...
| virtual unsigned int | GetNumberOfOutputPorts () |
| | Return the number of output ports. More...
| virtual vtkSMOutputPort * | GetOutputPort (unsigned int idx) |
| | Return an output port. More...
| virtual vtkSMOutputPort * | GetOutputPort (const char *portname) |
| | Return an output port, given the name for the port. More...
| virtual unsigned int | GetOutputPortIndex (const char *portname) |
| | Returns the port index, given the name of an output port. More...
| virtual const char * | GetOutputPortName (unsigned int index) |
| | Returns the output port name given its index. More...
| virtual void | CreateOutputPorts () |
| | Creates the output port proxies for this filter. More...
| vtkPVDataInformation * | GetDataSetInformation (unsigned int outputIdx) |
| | Return the DataInformation of the source proxy. More...
| vtkPVDataInformation * | GetSubsetDataInformation (unsigned int outputIdx, unsigned int compositeIndex) |
| | A GetSubsetDataInformation overload that uses composite index. More...
| virtual void | CreateSelectionProxies () |
| | Creates extract selection proxies for each output port if not already created. More...
| void | SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort) |
| | Set/Get the selection input. More...
| void | CleanSelectionInputs (unsigned int portIndex) |
| | Clean all selection inputs for the given port. More...
| vtkSMSourceProxy * | GetSelectionOutput (unsigned int portIndex) |
| | Returns the source proxy which provides the selected data from the given output port. More...
| virtual int | GetProcessSupport () |
| | This returns information about whether the VTK algorithm supports multiple processes or not. More...
| virtual bool | GetMPIRequired () |
| | This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More...
| virtual bool | GetStreamReply () |
| | This returns information about whether this proxy will wait for a reply when executing a stream. More...
| unsigned int | GetNumberOfAlgorithmOutputPorts () |
| | Returns the number of output ports provided by the algorithm. More...
| virtual unsigned int | GetNumberOfAlgorithmRequiredInputPorts () |
| | Returns the number of non-optional input ports required by the algorithm. More...
| vtkTypeUInt32 | GetGlobalID () override |
| | Overridden to reserve additional IDs for use by "ExtractSelection" proxies. More...
| void | EnableAbortCheck () |
| | Enable AbortCheck on both remote and local progress handler for this proxy. More...
| void | ClearAbortFlags () |
| | Clear abort execute flags on remote vtk objects. More...
| void | RecreateVTKObjects () override |
| | Overidden to handle disabling abort check for the deleted objects Also calls superclass. More...
| virtual int | GetOutputPortsCreated () |
| | Returns if the output port proxies have been created. More...
| vtkSMDocumentation * | GetOutputPortDocumentation (unsigned int index) |
| | It is possible to provide some documentation for each output port in the configuration xml. More...
| vtkSMDocumentation * | GetOutputPortDocumentation (const char *portname) |
| vtkPVDataInformation * | GetDataInformation () |
| | DataInformation is used by the source proxy to obtain information on the output(s) from the server. More...
| vtkPVDataInformation * | GetDataInformation (unsigned int outputIdx) |
| vtkPVDataInformation * | GetSubsetDataInformation (unsigned int outputIdx, const char *selector, const char *assemblyName=nullptr) |
| | For composite datasets, GetDataInformation returns summary data information for all blocks combined. More...
| vtkPVDataInformation * | GetRankDataInformation (int rank) |
| | Get rank-specific data information. More...
| vtkPVDataInformation * | GetRankDataInformation (unsigned int outputIdx, int rank) |
| vtkSMSourceProxy * | GetSelectionInput (unsigned int portIndex) |
| | API to query selection input set using SetSelectionInput. More...
| unsigned int | GetSelectionInputPort (unsigned int portIndex) |
| vtkPVXMLElement * | SaveXMLState (vtkPVXMLElement *root, vtkSMPropertyIterator *iter) override |
| | Overridden to handle selections. More...
| int | LoadXMLState (vtkPVXMLElement *element, vtkSMProxyLocator *locator) override |
| unsigned int | GetSelectionId () |
| | Get/Set the ID and port of the proxy refered by this selection proxy. More...
| unsigned int | GetSelectionPort () |
| void | SetSelectionId (unsigned int id) |
| void | SetSelectionPort (unsigned int port) |
| virtual bool | GetNeedsUpdate () |
| | Returns if the underlying VTK object needs to be updated or not. More...
| bool | IsDeprecated () |
| | Returns true if the proxy has a deprecation tag. More...
| bool | GetIsSubProxy () |
| | Return the property names that have values different from the otherProxy argument. More...
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMMultiServerSourceProxy () |
| | ~vtkSMMultiServerSourceProxy () override |
| virtual void | UpdateState () |
| | vtkSMSourceProxy () |
| | ~vtkSMSourceProxy () override |
| void | ExecuteStream (const vtkClientServerStream &msg, bool ignoreErrors=false, vtkTypeUInt32 location=0) override |
| | Execute provided stream using the internal session with sendReply positioned to StreamReply value. More...
| virtual void | InvalidateDataInformation () |
| | Mark the data information as invalid. More...
| void | CreateVTKObjects () override |
| | Call superclass' and then assigns a new executive (vtkCompositeDataPipeline) More...
| virtual void | SetExecutiveName (const char *) |
| int | ReadXMLAttributes (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) override |
| void | PostUpdateData (bool) override |
| | Overwritten from superclass to invoke. More...
| void | SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override |
| | Overridden to pass the logname to the internal ExtractSelection proxies. More...
| void | SetOutputPort (unsigned int index, const char *name, vtkSMOutputPort *port, vtkSMDocumentation *doc) |
| | Method to set an output port at the given index. More...
| void | RemoveAllOutputPorts () |
| void | SetExtractSelectionProxy (unsigned int index, vtkSMSourceProxy *proxy) |
| void | RemoveAllExtractSelectionProxies () |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | This is called by PostUpdateData to only update state for this proxy without iterative over producers. More...
| | If a proxy need to ensure a plugin is loaded, make sure it is. More...
| | Set the "EnsurePluginLoaded" XML element that is used in LoadPluginIfEnsured. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
