vtkSMMaterialLibraryProxy Class Reference
proxy for a camera. More...
#include <vtkSMMaterialLibraryProxy.h>
Inheritance diagram for vtkSMMaterialLibraryProxy:
Collaboration diagram for vtkSMMaterialLibraryProxy:
typedef vtkSMProxy Superclass
void Synchronize (vtkPVSession::ServerFlags from=vtkPVSession::RENDER_SERVER_ROOT, vtkPVSession::ServerFlags to=vtkPVSession::CLIENT)
 Copies the Material library on the root node of server to the client by default. More...
void LoadDefaultMaterials ()
 Reads default materials on the process. More...
void LoadMaterials (const char *)
 Reads and specified materials. More...
void UpdateVTKObjects () override
 Overridden to control load from server file system. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
vtkSMProxyGetParentProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMMaterialLibraryProxyNew ()
static vtkSMMaterialLibraryProxySafeDownCast (vtkObject *o)
static vtkSMProxyNew ()
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMMaterialLibraryProxy ()=default
 ~vtkSMMaterialLibraryProxy () override=default
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElementXMLElement
vtkSMMessageState
int InMarkModified
vtkSMProxyInternalsInternals
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
proxy for a camera.
This a proxy for controlling vtkOSPRayMaterialLibraries on various nodes. In particular we use it to ensure that all rendering processes have a consistent set of materials.
Definition at line 19 of file vtkSMMaterialLibraryProxy.h.
Definition at line 23 of file vtkSMMaterialLibraryProxy.h.
◆ vtkSMMaterialLibraryProxy()
vtkSMMaterialLibraryProxy::vtkSMMaterialLibraryProxy ( )
protecteddefault
◆ ~vtkSMMaterialLibraryProxy()
vtkSMMaterialLibraryProxy::~vtkSMMaterialLibraryProxy ( )
overrideprotecteddefault
static vtkSMMaterialLibraryProxy* vtkSMMaterialLibraryProxy::New ( )
virtual const char* vtkSMMaterialLibraryProxy::GetClassName ( )
static int vtkSMMaterialLibraryProxy::IsTypeOf ( const char *  type)
virtual int vtkSMMaterialLibraryProxy::IsA ( const char *  type)
static vtkSMMaterialLibraryProxy* vtkSMMaterialLibraryProxy::SafeDownCast ( vtkObject o)
◆ Synchronize()
void vtkSMMaterialLibraryProxy::Synchronize ( vtkPVSession::ServerFlags  from = vtkPVSession::RENDER_SERVER_ROOT,
vtkPVSession::ServerFlags  to = vtkPVSession::CLIENT
You can also specify the start and end location with from and to arguments.
◆ LoadDefaultMaterials()
void vtkSMMaterialLibraryProxy::LoadDefaultMaterials ( )
◆ LoadMaterials()
void vtkSMMaterialLibraryProxy::LoadMaterials ( const char *  )
◆ UpdateVTKObjects()
void vtkSMMaterialLibraryProxy::UpdateVTKObjects ( )
