| void | SetRenderViewProxy (vtkSMProxy *rvProxy) |
| | Set the render view proxy to extract camera properties from. More...
| virtual void | SetFileDescription (const char *) |
| virtual char * | GetFileDescription () |
| virtual void | SetFileExtension (const char *) |
| virtual char * | GetFileExtension () |
| virtual const char * | GetWriterVersion () |
| | Return the writer version string. More...
| virtual int | WriteConfiguration (ostream &os) |
| | Write the proxy's state to a stream, in PV state format. More...
| virtual vtkSMProxy * | GetProxy () |
| | Set the proxy to write out. More...
| virtual void | SetPropertyIterator (vtkSMPropertyIterator *iter) |
| | Set the ieterator used to traverse properties during the write. More...
| virtual vtkSMPropertyIterator * | GetPropertyIterator () |
| virtual void | SetFileName (const char *) |
| | Set/Get the file name. More...
| virtual char * | GetFileName () |
| virtual void | SetFileIdentifier (const char *) |
| | Set/get file meta data. More...
| virtual char * | GetFileIdentifier () |
| virtual int | WriteConfiguration () |
| | Write the proxy's state directly to an XML file, in PV state format. More...
| virtual int | WriteConfiguration (const char *fileName) |
A writer for XML camera configuration.
A writer for XML camera configuration. Writes camera configuration files using ParaView state file machinery.
- See also
- vtkSMCameraConfigurationReader, vtkSMProxyConfigurationWriter
- This class was contributed by SciberQuest Inc.
Definition at line 27 of file vtkSMCameraConfigurationWriter.h.
