| virtual vtkSMRenderViewProxy * | GetRenderView () |
| | Get/Set the (render) View Module from which we are writing the geometry. More...
| void | SetRenderView (vtkSMRenderViewProxy *) |
| virtual void | SetAnimationScene (vtkSMProxy *) |
| | Convenience method to set the proxy. More...
| bool | Save () |
| | Begin the saving. More...
| virtual void | SetWriteTimeSteps (bool) |
| | Enable the writing of all timesteps. More...
| virtual bool | GetWriteTimeSteps () |
| virtual void | WriteTimeStepsOn () |
| virtual void | WriteTimeStepsOff () |
| void | SetFrameExporterDelegate (vtkSMExporterProxy *exporter) |
| | Set an exporter to use for single frame export. More...
| virtual void | SetAnimationScene (vtkSMAnimationScene *) |
| | Get/Set the animation scene that this writer will write. More...
| virtual vtkSMAnimationScene * | GetAnimationScene () |
| virtual void | SetFileName (const char *) |
| | Get/Set the filename. More...
| virtual char * | GetFileName () |
| virtual void | SetStartFileCount (int) |
| | Get/Set the start file count. More...
| virtual int | GetStartFileCount () |
| virtual void | SetPlaybackTimeWindow (double, double) |
| | Get/Set time window that we want to write If PlaybackTimeWindow[0] > PlaybackTimeWindow[1] that mean that we want to export the full time range available. More...
| void | SetPlaybackTimeWindow (double [2]) |
| virtual double * | GetPlaybackTimeWindow () |
| virtual void | GetPlaybackTimeWindow (double &, double &) |
| virtual void | GetPlaybackTimeWindow (double [2]) |
| void | SetFrameWindow (int window[2]) |
| | Use window to set PlaybackTimeWindow based on AnimationScene times. More...
| void | SetFrameWindow (int min, int max) |
| virtual void | SetStride (int) |
| | Set/Get The stride which is used to extract the next frame. More...
| virtual int | GetStride () |
helper class to write animation geometry in a web archive.
vtkSMAnimationSceneWebWriter is a concrete implementation of vtkSMAnimationSceneWriter that can write the geometry as a web archive. This writer can only write the visible geometry in one view.
Definition at line 22 of file vtkSMAnimationSceneWebWriter.h.
