| virtual bool | GetNeedsUpdate () |
| | Returns if the underlying VTK object needs to be updated or not. More...
| bool | IsDeprecated () |
| | Returns true if the proxy has a deprecation tag. More...
| bool | GetIsSubProxy () |
| | Return the property names that have values different from the otherProxy argument. More...
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMAnimationSceneProxy () |
| | ~vtkSMAnimationSceneProxy () override |
| int | LoadXMLState (vtkPVXMLElement *element, vtkSMProxyLocator *locator) override |
| | Overridden to prune start/end time properties if not applicable to the state being loaded. More...
| void | CreateVTKObjects () override |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| virtual void | ExecuteStream (const vtkClientServerStream &msg, bool ignore_errors=false, vtkTypeUInt32 location=0) |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | This is called by PostUpdateData to only update state for this proxy without iterative over producers. More...
| | If a proxy need to ensure a plugin is loaded, make sure it is. More...
| | Set the "EnsurePluginLoaded" XML element that is used in LoadPluginIfEnsured. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
| static bool | UpdateAnimationUsingDataTimeSteps (vtkSMProxy *scene) |
| | Setups the animation scene's playback mode and time-ranges based on the timesteps available on the time-keeper proxy set on the animation scene. More...
| virtual bool | UpdateAnimationUsingDataTimeSteps () |
| static vtkSMProxy * | FindAnimationCue (vtkSMProxy *scene, vtkSMProxy *animatedProxy, const char *animatedPropertyName) |
| | Returns the first animation cue (enabled or otherwise) that animates the given property on the proxy. More...
| virtual vtkSMProxy * | FindAnimationCue (vtkSMProxy *animatedProxy, const char *animatedPropertyName) |
