vtkSMAnimationSceneGeometryWriter Class Reference
helper class to write animation geometry in a data file. More...
#include <vtkSMAnimationSceneGeometryWriter.h>
Inheritance diagram for vtkSMAnimationSceneGeometryWriter:
Collaboration diagram for vtkSMAnimationSceneGeometryWriter:
typedef vtkSMAnimationSceneWriter Superclass
- Public Types inherited from vtkSMAnimationSceneWriter
virtual vtkSMProxyGetViewModule ()
void SetViewModule (vtkSMProxy *)
- Public Member Functions inherited from vtkSMAnimationSceneWriter
virtual void SetAnimationScene (vtkSMProxy *)
 Convenience method to set the proxy. More...
bool Save ()
 Begin the saving. More...
virtual void SetWriteTimeSteps (bool)
 Enable the writing of all timesteps. More...
virtual bool GetWriteTimeSteps ()
virtual void WriteTimeStepsOn ()
virtual void WriteTimeStepsOff ()
void SetFrameExporterDelegate (vtkSMExporterProxy *exporter)
 Set an exporter to use for single frame export. More...
virtual void SetAnimationScene (vtkSMAnimationScene *)
 Get/Set the animation scene that this writer will write. More...
virtual vtkSMAnimationSceneGetAnimationScene ()
 Get/Set the filename. More...
virtual char * GetFileName ()
virtual void SetStartFileCount (int)
 Get/Set the start file count. More...
virtual int GetStartFileCount ()
virtual void SetPlaybackTimeWindow (double, double)
 Get/Set time window that we want to write If PlaybackTimeWindow[0] > PlaybackTimeWindow[1] that mean that we want to export the full time range available. More...
void SetPlaybackTimeWindow (double [2])
virtual doubleGetPlaybackTimeWindow ()
virtual void GetPlaybackTimeWindow (double &, double &)
virtual void GetPlaybackTimeWindow (double [2])
void SetFrameWindow (int window[2])
 Use window to set PlaybackTimeWindow based on AnimationScene times. More...
void SetFrameWindow (int min, int max)
virtual void SetStride (int)
 Set/Get The stride which is used to extract the next frame. More...
virtual int GetStride ()
virtual void SetSession (vtkSMSession *)
static vtkSMAnimationSceneGeometryWriterNew ()
static vtkSMAnimationSceneGeometryWriterSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMAnimationSceneWriter
static vtkSMAnimationSceneWriterSafeDownCast (vtkObject *o)
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMAnimationSceneGeometryWriter ()
 ~vtkSMAnimationSceneGeometryWriter () override
bool SaveInitialize (int startCount) override
 Called to initialize saving. More...
bool SaveFrame (double time) override
 Called to save a particular frame. More...
bool SaveFinalize () override
 Called to finalize saving. More...
- Protected Member Functions inherited from vtkSMAnimationSceneWriter
 vtkSMAnimationSceneWriter ()
 ~vtkSMAnimationSceneWriter () override
void ExecuteEvent (vtkObject *caller, unsigned long eventid, void *calldata)
vtkSMExporterProxyGetFrameExporterDelegate ()
 Return the Exporter to use for a single frame export, if any. More...
bool AnimationEnabled ()
 Return true if the current configuration allows for animation export. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkSMProxyGeometryWriter
vtkSMProxyViewModule
- Protected Attributes inherited from vtkSMAnimationSceneWriter
unsigned long ObserverID
vtkSMAnimationSceneAnimationScene
bool Saving
bool SaveFailed
char * FileName
double PlaybackTimeWindow [2]
int StartFileCount
int Stride = 1
vtkSMAnimationSceneGeometryWriter is a concrete implementation of vtkSMAnimationSceneWriter that can write the geometry as a data file. This writer can only write the visible geometry in one view.
Definition at line 21 of file vtkSMAnimationSceneGeometryWriter.h.
Definition at line 26 of file vtkSMAnimationSceneGeometryWriter.h.
◆ vtkSMAnimationSceneGeometryWriter()
vtkSMAnimationSceneGeometryWriter::vtkSMAnimationSceneGeometryWriter ( )
◆ ~vtkSMAnimationSceneGeometryWriter()
vtkSMAnimationSceneGeometryWriter::~vtkSMAnimationSceneGeometryWriter ( )
static vtkSMAnimationSceneGeometryWriter* vtkSMAnimationSceneGeometryWriter::New ( )
virtual const char* vtkSMAnimationSceneGeometryWriter::GetClassName ( )
Reimplemented from vtkSMAnimationSceneWriter.
static int vtkSMAnimationSceneGeometryWriter::IsTypeOf ( const char *  type)
virtual int vtkSMAnimationSceneGeometryWriter::IsA ( const char *  type)
static vtkSMAnimationSceneGeometryWriter* vtkSMAnimationSceneGeometryWriter::SafeDownCast ( vtkObject o)
void vtkSMAnimationSceneGeometryWriter::PrintSelf ( ostream &  os,
◆ GetViewModule()
virtual vtkSMProxy* vtkSMAnimationSceneGeometryWriter::GetViewModule ( )
◆ SetViewModule()
void vtkSMAnimationSceneGeometryWriter::SetViewModule ( vtkSMProxy )
◆ SaveInitialize()
bool vtkSMAnimationSceneGeometryWriter::SaveInitialize ( int  startCount)
overrideprotectedvirtual
Implements vtkSMAnimationSceneWriter.
◆ SaveFrame()
bool vtkSMAnimationSceneGeometryWriter::SaveFrame ( double  time)
◆ SaveFinalize()
bool vtkSMAnimationSceneGeometryWriter::SaveFinalize ( )
◆ GeometryWriter
vtkSMProxy* vtkSMAnimationSceneGeometryWriter::GeometryWriter
Definition at line 53 of file vtkSMAnimationSceneGeometryWriter.h.
◆ ViewModule
vtkSMProxy* vtkSMAnimationSceneGeometryWriter::ViewModule
Definition at line 54 of file vtkSMAnimationSceneGeometryWriter.h.
