Executes a user supplied python script on its input dataset to produce an output dataset.
| void | ClearParameters () |
| | Clear all name-value parameters. More...
| void | SetNumberOfInputPorts (int numberOfInputPorts) override |
| | Set the number of input ports This function is explicitly exposed to enable a vtkClientServerInterpreter to call it. More...
| bool | GetNeedsUpdate () |
| | Application code can call GetNeedsUpdate to check if the algorithm can use an update to show updated information. More...
| virtual void | SetNeedsUpdate (bool) |
| | CheckNeedsUpdateScript should call SetNeedsUpdate(true) to indicate that the algorithm has new data and hence may be updated. More...
| virtual void | SetScript (const char *) |
| | Set the text of the python script to execute. More...
| virtual char * | GetScript () |
| virtual void | SetInformationScript (const char *) |
| | Set the text of the python script to execute in RequestInformation(). More...
| virtual char * | GetInformationScript () |
| virtual void | SetUpdateExtentScript (const char *) |
| | Set the text of the python script to execute in RequestUpdateExtent(). More...
| virtual char * | GetUpdateExtentScript () |
| virtual void | SetCheckNeedsUpdateScript (const char *) |
| | For "live" sources, this script, if provided, if used to determine if the source needs an update. More...
| virtual char * | GetCheckNeedsUpdateScript () |
| void | SetParameterInternal (const char *name, const char *value) |
| | Set a name-value parameter that will be available to the script when it is run. More...
| void | SetParameter (const char *name, const char *value) |
| void | SetParameter (const char *name, int value) |
| void | SetParameter (const char *name, double value) |
| void | SetParameter (const char *name, double value1, double value2) |
| void | SetParameter (const char *name, double value1, double value2, double value3) |
| void | AddParameter (const char *name, const char *value) |
| | To support repeatable-parameters. More...
| void | ClearParameter (const char *name) |
| virtual void | SetOutputDataSetType (int) |
| | Changes the output data set type. More...
| virtual int | GetOutputDataSetType () |
| virtual void | SetPythonPath (const char *) |
| | A semi-colon (;) separated list of directories to add to the python library search path. More...
| virtual char * | GetPythonPath () |
| vtkProgrammableFilter * | NewInstance () const |
| void | SetExecuteMethod (void(*f)(void *), void *arg) |
| void | SetExecuteMethodArgDelete (void(*f)(void *)) |
| vtkPolyData * | GetPolyDataInput () |
| vtkStructuredPoints * | GetStructuredPointsInput () |
| vtkStructuredGrid * | GetStructuredGridInput () |
| vtkUnstructuredGrid * | GetUnstructuredGridInput () |
| vtkRectilinearGrid * | GetRectilinearGridInput () |
| vtkGraph * | GetGraphInput () |
| vtkTable * | GetTableInput () |
| virtual void | SetCopyArrays (bool) |
| virtual bool | GetCopyArrays () |
| virtual void | CopyArraysOn () |
| virtual void | CopyArraysOff () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPythonProgrammableFilter () |
| | ~vtkPythonProgrammableFilter () override |
| void | Exec (const char *, const char *) |
| | For internal use only. More...
| int | FillOutputPortInformation (int port, vtkInformation *info) override |
| int | RequestDataObject (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| | Creates whatever output data set type is selected. More...
| int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| int | ProcessRequest (vtkInformation *request, vtkInformationVector **inInfo, vtkInformationVector *outInfo) override |
| | We want to temporarilly cache request to be used in the Python code so we override this method to store request for later use since otherwise we won't have access to it. More...
| | vtkProgrammableFilter () |
| | ~vtkProgrammableFilter () |
| int | RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| virtual int | RequestUpdateTime (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
This filter will execute a python script to produce an output dataset. An new interpretor is created at the beginning of RequestInformation(). The state of the python interpretor is preserved until the next execution of RequestInformation(). After the interpretor is creates the vtk module is imported with "from paraview import vtk".
Then the interpretor runs the InformationScript during RequestInformation(). This script is run in a python function called RequestInformation(). An argument named self that refers to the programmable filter is passed to the function. The interpretor also runs the Script during RequestData(). This script is run in a python function called RequestData(). An argument named self that refers to the programmable filter is passed to the function. Furthermore, a set of parameters passed with the SetParameter() call are defined as Python variables inside both scripts. This allows the developer to keep the scripts the same but change their behaviour using parameters.
Definition at line 38 of file vtkPythonProgrammableFilter.h.
