Container class that manages appending data arrays of points. More...
#include <vtkPointAccumulator.h>
| vtkPointAccumulator () | |
| ~vtkPointAccumulator () | |
| bool | Empty () |
| Test if there is anything in the store. More... | |
| void | Accumulate (T_VTK *pts) |
| Adds an array of points at the end of the internal store. More... | |
| vtkIdType | GetNumberOfPoints () |
| Return the number of points currently in the point store. More... | |
| void | Clear () |
| Free resources and mark as empty. More... | |
| T_CPP * | Expand (vtkIdType n) |
| Extend the internal store and get a pointer to the newly added memory. More... | |
| void | Accumulate (T_CPP *pts, vtkIdType n) |
| Adds an array of points to the end of the internal store. More... | |
| vtkPoints * | BuildVtkPoints () |
| Creates a vtkPoints data structure from the internal store. More... | |
| void | GetBounds (double bounds[6]) |
| Compute axis-aligned bounding box. More... | |
| void | Print () |
| Print the contents of the internal store. More... | |
The template types are T_CPP for the c++ data type and T_VTK for the VTK data type. Eg: if T_CCP==double the T_VTK must be vtkDoubleArray. The main difference between the way this works and if you were to do the same thing with a data array is that here the memory grows by exactly what is needed, and in VTK data arrays the memory will grow by at least twice what is requested.
Definition at line 27 of file vtkPointAccumulator.h.
Definition at line 30 of file vtkPointAccumulator.h.
Definition at line 35 of file vtkPointAccumulator.h.
Definition at line 40 of file vtkPointAccumulator.h.
Definition at line 53 of file vtkPointAccumulator.h.
Definition at line 59 of file vtkPointAccumulator.h.
Definition at line 87 of file vtkPointAccumulator.h.
Definition at line 100 of file vtkPointAccumulator.h.
Caller to delete the points.
Definition at line 106 of file vtkPointAccumulator.h.
An exhaustive search is made through points every time. It's calllers responsibility to use sparingly.
Definition at line 124 of file vtkPointAccumulator.h.
Definition at line 152 of file vtkPointAccumulator.h.
Definition at line 157 of file vtkPointAccumulator.h.
