vtkPVWebExporter Class Reference
vtkPVWebExporter is used to produce vtkjs export in the ParaView application. More...
#include <vtkPVWebExporter.h>
Inherits vtkJSONSceneExporter.
typedef vtkJSONSceneExporter Superclass
virtual void SetParaViewGlanceHTML (std::string)
 Specify file name of the custom ParaViewGlance HTML file to use to embed the data in. More...
virtual std::string GetParaViewGlanceHTML ()
virtual bool GetExportToGlance ()
 In addition to writing the scene as a .vtkjs file, bundle its content encoded in base64 into a Kitware Glance viewer standalone HTML file. More...
virtual void SetExportToGlance (bool)
virtual bool GetAutomaticGlanceHTML ()
 Ignore ParaViewGlanceHTML file path and try to find the ParaViewGlance.html file coming with the ParaView distribution. More...
virtual void SetAutomaticGlanceHTML (bool)
virtual bool GetDisableNetwork ()
 Disable components requiring network access through Girder in the Glance application, by forcing the URL parameter 'noGirder'. More...
virtual void SetDisableNetwork (bool)
static vtkPVWebExporterNew ()
static vtkPVWebExporterSafeDownCast (vtkObject *o)
 vtkPVWebExporter ()
 ~vtkPVWebExporter () override
void Write () override
vtkPVWebExporter is used to produce scene export for web sharing.
Definition at line 17 of file vtkPVWebExporter.h.
typedef vtkJSONSceneExporter vtkPVWebExporter::Superclass
Definition at line 21 of file vtkPVWebExporter.h.
◆ vtkPVWebExporter()
vtkPVWebExporter::vtkPVWebExporter ( )
◆ ~vtkPVWebExporter()
vtkPVWebExporter::~vtkPVWebExporter ( )
static vtkPVWebExporter* vtkPVWebExporter::New ( )
virtual const char* vtkPVWebExporter::GetClassName ( )
static int vtkPVWebExporter::IsTypeOf ( const char *  type)
virtual int vtkPVWebExporter::IsA ( const char *  type)
static vtkPVWebExporter* vtkPVWebExporter::SafeDownCast ( vtkObject o)
void vtkPVWebExporter::PrintSelf ( ostream &  os,
override
◆ SetParaViewGlanceHTML()
virtual void vtkPVWebExporter::SetParaViewGlanceHTML ( std::string  )
◆ GetParaViewGlanceHTML()
virtual std::string vtkPVWebExporter::GetParaViewGlanceHTML ( )
◆ GetExportToGlance()
virtual bool vtkPVWebExporter::GetExportToGlance ( )
Defaults to true.
◆ SetExportToGlance()
virtual void vtkPVWebExporter::SetExportToGlance ( bool  )
Defaults to true.
◆ GetAutomaticGlanceHTML()
virtual bool vtkPVWebExporter::GetAutomaticGlanceHTML ( )
This file is supposed to be in [PARAVIEW ROOT]/share/paraview-[VERSION]/web/glance/ParaViewGlance.html Defaults to true.
◆ SetAutomaticGlanceHTML()
virtual void vtkPVWebExporter::SetAutomaticGlanceHTML ( bool  )
◆ GetDisableNetwork()
virtual bool vtkPVWebExporter::GetDisableNetwork ( )
This will inject a script reloading the page if the 'noGirder' parameter is not set, effectively preventing any external network call from the Glance webapp. Defaults to true (Girder disabled).
◆ SetDisableNetwork()
virtual void vtkPVWebExporter::SetDisableNetwork ( bool  )
◆ Write()
void vtkPVWebExporter::Write ( )
