| vtkMultiProcessController * | GetController (ServerFlags processType) override |
| | Returns the active controller used to communicate with the process. More...
| virtual bool | Connect (const char *url) |
| | Connects a remote server. More...
| bool | Connect () |
| | Overload that constructs the url using the command line parameters specified and then calls Connect(url). More...
| bool | GetIsAlive () override |
| | Returns true is this session is active/alive/valid. More...
| void | OnClientServerMessageRMI (void *message, int message_length) |
| void | OnCloseSessionRMI () |
| void | NotifyAllClients (const vtkSMMessage *) override |
| | Sends the message to all clients. More...
| void | NotifyOtherClients (const vtkSMMessage *) override |
| | Sends the message to all but the active client-session. More...
| virtual void | MultipleConnectionOn () |
| | Enable or Disable multi-connection support. More...
| virtual void | MultipleConnectionOff () |
| virtual void | SetMultipleConnection (bool) |
| virtual bool | GetMultipleConnection () |
| virtual void | DisableFurtherConnectionsOn () |
| | Enable or Disable further connections in multiple connection mode. More...
| virtual void | DisableFurtherConnectionsOff () |
| virtual bool | GetDisableFurtherConnections () |
| void | SetDisableFurtherConnections (bool disable) |
| void | SetConnectID (int newConnectID) |
| | Set/Get the server connect-id. More...
| int | GetConnectID () |
| ServerFlags | GetProcessRoles () override |
| | Returns a ServerFlags indicate the nature of the current processes. More...
| vtkPVServerInformation * | GetServerInformation () override |
| | vtkPVServerInformation is an information-object that provides information about the server processes. More...
| vtkMPIMToNSocketConnection * | GetMPIMToNSocketConnection () override |
| | This is socket connection, if any to communicate between the data-server and render-server nodes. More...
| virtual void | PushState (vtkSMMessage *msg) |
| | Push the state message. More...
| virtual void | PullState (vtkSMMessage *msg) |
| | Pull the state message. More...
| virtual void | ExecuteStream (vtkTypeUInt32 location, const vtkClientServerStream &stream, bool ignoreErrors=false, bool sendReply=false) |
| | Execute a command on the given processes. More...
| | Returns the response of the ExecuteStream() call from the location. More...
| virtual bool | GatherInformation (vtkTypeUInt32 location, vtkPVInformation *information, vtkTypeUInt32 globalid) |
| | Gather information about an object referred by the globalid. More...
| vtkSIProxyDefinitionManager * | GetProxyDefinitionManager () |
| | Get the ProxyDefinitionManager. More...
| | Returns a vtkSIObject or subclass given its global id, if any. More...
| virtual void | UnRegisterSIObject (vtkSMMessage *msg) |
| | Unregister server side object. More...
| virtual void | RegisterSIObject (vtkSMMessage *msg) |
| | Register server side object. More...
| vtkObject * | GetRemoteObject (vtkTypeUInt32 globalid) |
| | Return a vtkSMRemoteObject given its global id if any otherwise return nullptr;. More...
| virtual void | GetAllRemoteObjects (vtkCollection *collection) |
| | Allow the user to fill its vtkCollection with all RemoteObject This could be useful when you want to hold a reference to them to prevent any deletion across several method call. More...
| virtual vtkTypeUInt32 | GetNextGlobalUniqueIdentifier () |
| | Provides the next available identifier. More...
| virtual vtkTypeUInt32 | GetNextChunkGlobalUniqueIdentifier (vtkTypeUInt32 chunkSize) |
| | Return the first Id of the requested chunk. More...
| virtual bool | IsProcessingRemoteNotification () |
| | This property is used to discard ignore_synchronization proxy property when we load protobuf states. More...
| virtual void | UseSessionCoreOf (vtkPVSessionBase *other) |
| | Update internal session core in order to use the one used in another session. More...
| virtual vtkPVSessionCore * | GetSessionCore () |
| | Provides access to the session core. More...
| bool | HasProcessRole (vtkTypeUInt32 flag) |
| | Convenience method that returns true if the current session is serving the indicated role on this process. More...
| virtual bool | IsMultiClients () |
| | Allow anyone to know easily if the current session is involved in collaboration or not. More...
| bool | GetPendingProgress () |
| | Returns true if the session is within a PrepareProgress() and CleanupPendingProgress() block. More...
| virtual vtkPVProgressHandler * | GetProgressHandler () |
| | Provides access to the progress handler. More...
| void | PrepareProgress () |
| | Should be called to begin/end receiving progresses on this session. More...
| void | CleanupPendingProgress () |
| | vtkPVSessionServer () |
| | ~vtkPVSessionServer () override |
| void | GatherInformationInternal (vtkTypeUInt32 location, const char *classname, vtkTypeUInt32 globalid, vtkMultiProcessStream &) |
| | Called when client triggers GatherInformation(). More...
| void | SendLastResultToClient () |
| | Sends the last result to client. More...
| | vtkPVSessionBase () |
| | vtkPVSessionBase (vtkPVSessionCore *coreToUse) |
| | ~vtkPVSessionBase () override |
| void | RegisterRemoteObject (vtkTypeUInt32 globalid, vtkTypeUInt32 location, vtkObject *obj) |
| | Register a remote object. More...
| void | UnRegisterRemoteObject (vtkTypeUInt32 globalid, vtkTypeUInt32 location) |
| | Unregister a remote object. More...
| vtkPVSessionCore * | GetSessionCore () const |
| | Method used to migrate from one Session type to another by keeping the same vtkPVSessionCore. More...
| void | SetSessionCore (vtkPVSessionCore *) |
| void | PrepareProgressInternal () override |
| void | CleanupPendingProgressInternal () override |
| virtual bool | StartProcessingRemoteNotification () |
| | Methods used to monitor if we are currently processing a server notification Only vtkSMSessionClient use the flag to disable ignore_synchronization properties from being updated. More...
| virtual void | StopProcessingRemoteNotification (bool previousValue) |
| | vtkPVSession () |
| | ~vtkPVSession () override |
| virtual bool | OnWrongTagEvent (vtkObject *caller, unsigned long eventid, void *calldata) |
| | Callback when any vtkMultiProcessController subclass fires a WrongTagEvent. More...
| virtual void | Activate () |
| | Subclasses must call this to mark the session active. More...
| virtual void | DeActivate () |
| | Subclasses must call this to mark the session inactive. More...
| | vtkObject () |
| | vtkObjectBase () |
vtkSMSessionServer is a session used on data and/or render servers.
It's designed for a process that works with a separate client process that acts as the visualization driver.
- See also
- vtkSMSessionClient
Definition at line 22 of file vtkPVSessionServer.h.
