| void | AddFrustum (double vertices[32]) |
| | Set a frustum to choose within. More...
| virtual void | SetArrayName (const char *) |
| | For threshold and value selection, this controls the name of the scalar array that will be thresholded within. More...
| void | AddGlobalID (vtkIdType id) |
| | Add global IDs. More...
| void | RemoveAllGlobalIDs () |
| void | AddPedigreeID (const char *domain, vtkIdType id) |
| | Add integer pedigree IDs in a particular domain. More...
| void | RemoveAllPedigreeIDs () |
| void | AddPedigreeStringID (const char *domain, const char *id) |
| | Add string pedigree IDs in a particular domain. More...
| void | RemoveAllPedigreeStringIDs () |
| void | AddID (vtkIdType piece, vtkIdType id) |
| | Add a (piece, id) to the selection set. More...
| void | RemoveAllIDs () |
| void | AddValue (vtkIdType piece, vtkIdType value) |
| | Add a (piece, value) to the selection set. More...
| void | RemoveAllValues () |
| void | AddCompositeID (unsigned int composite_index, vtkIdType piece, vtkIdType id) |
| | Add IDs that will be added to the selection produced by the selection source. More...
| void | RemoveAllCompositeIDs () |
| void | AddHierarhicalID (unsigned int level, unsigned int dataset, vtkIdType id) |
| | The list of IDs that will be added to the selection produced by the selection source. More...
| void | RemoveAllHierarchicalIDs () |
| void | AddThreshold (double min, double max) |
| | Add a value range to threshold within. More...
| void | RemoveAllThresholds () |
| void | AddBlock (vtkIdType blockno) |
| | Add the flat-index/composite index for a block. More...
| void | RemoveAllBlocks () |
| void | AddLocation (double x, double y, double z) |
| | Add a point in world space to probe at. More...
| void | RemoveAllLocations () |
| void | AddBlockSelector (const char *selector) |
| | Add/Remove block-selectors to make selections with vtkSelectionNode::BLOCK_SELECTORS as the content-type. More...
| void | RemoveAllBlockSelectors () |
| virtual void | SetProcessID (int) |
| | Get/Set which process to limit the selection to. More...
| virtual int | GetProcessID () |
| virtual void | SetFieldType (int) |
| | Set the field type for the generated selection. More...
| virtual int | GetFieldType () |
| virtual void | SetContainingCells (int) |
| | When extracting by points, extract the cells that contain the passing points. More...
| virtual int | GetContainingCells () |
| virtual void | SetInverse (int) |
| virtual int | GetInverse () |
| virtual void | SetQueryString (const char *) |
| | Set/get the query expression string. More...
| virtual char * | GetQueryString () |
| virtual void | SetNumberOfLayers (int) |
| | Specify number of layers to extract connected to the selected elements. More...
| virtual int | GetNumberOfLayers () |
| virtual void | SetRemoveSeed (bool) |
| | Set/Get the flag the control if, when using the number of layers to extract connected elements, the initial selection seed should be removed. More...
| virtual bool | GetRemoveSeed () |
| virtual void | SetRemoveIntermediateLayers (bool) |
| | Set/Get the flag the control if, when using the number of layers to extract connected elements, the intermediate layers should be removed. More...
| virtual bool | GetRemoveIntermediateLayers () |
| vtkSelectionAlgorithm * | NewInstance () const |
| vtkSelection * | GetOutput () |
| vtkSelection * | GetOutput (int index) |
| void | SetInputData (vtkDataObject *obj) |
| void | SetInputData (int index, vtkDataObject *obj) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPVSelectionSource () |
| | ~vtkPVSelectionSource () override |
| int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| | vtkSelectionAlgorithm () |
| | ~vtkSelectionAlgorithm () |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
