packages a Python module into a ParaView plugin. More...
#include <vtkPVPythonAlgorithmPlugin.h>
| ~vtkPVPythonAlgorithmPlugin () override | |
| Implementation of the vtkPVServerManagerPluginInterface. More... | |
| vtkPVPythonAlgorithmPlugin (const char *filePath) | |
| Constructors for the object. More... | |
| vtkPVPythonAlgorithmPlugin (const char *moduleName, const char *pythonSourceCode) | |
| vtkPVPlugin () | |
| virtual | ~vtkPVPlugin () |
| virtual void | GetBinaryResources (std::vector< std::string > &resources) |
| static bool | InitializeFromStringAndGetXMLs (const char *moduleName, const char *pythonSourceCode, std::vector< std::string > &xmls) |
| Creates the object from Python source code and gets the servermanager XMLs from all the Python filters included in the 'moduleName'. More... | |
Friends | |
| class | vtkPVPythonAlgorithmPluginLoaderInitializer |
vtkPVPythonAlgorithmPlugin helps us support loading a Python module as a ParaView plugin. The only supported type of plugin is a server-manager plugin that adds support for algorithm proxies i.e. readers, filters, and writers.
Definition at line 25 of file vtkPVPythonAlgorithmPlugin.h.
| vtkPVPythonAlgorithmPlugin::vtkPVPythonAlgorithmPlugin | ( | const char * | filePath | ) |
The first version reads the python plugin from the .py file at 'filePath'. The second version is used for plugins that include both C++ and Python filters (the Python source code is included in the .so in this case)
| vtkPVPythonAlgorithmPlugin::vtkPVPythonAlgorithmPlugin | ( | const char * | moduleName, |
| const char * | pythonSourceCode | ||
Implementation of the vtkPVPlugin interface.
Implements vtkPVPlugin.
inlineoverridevirtual |
Definition at line 46 of file vtkPVPythonAlgorithmPlugin.h.
Definition at line 47 of file vtkPVPythonAlgorithmPlugin.h.
Definition at line 48 of file vtkPVPythonAlgorithmPlugin.h.
Definition at line 49 of file vtkPVPythonAlgorithmPlugin.h.
Definition at line 50 of file vtkPVPythonAlgorithmPlugin.h.
If xmls already contains modules, this function will append the new imported one at the end of the vector.
Definition at line 64 of file vtkPVPythonAlgorithmPlugin.h.
friend |
Definition at line 83 of file vtkPVPythonAlgorithmPlugin.h.
1.8.13 on Sat Oct 10 2026
