Slice with plane filter.
#include <vtkPVPlaneCutter.h>
Inherits vtkPlaneCutter.
This is a subclass of vtkPlaneCutter that allows selection of input vtkHyperTreeGrid, vtkOverlappingAMR.
Definition at line 22 of file vtkPVPlaneCutter.h.
◆ Superclass
◆ vtkPVPlaneCutter()
| vtkPVPlaneCutter::vtkPVPlaneCutter |
◆ ~vtkPVPlaneCutter()
| vtkPVPlaneCutter::~vtkPVPlaneCutter |
◆ GetClassName()
| virtual const char* vtkPVPlaneCutter::GetClassName |
◆ IsTypeOf()
| static int vtkPVPlaneCutter::IsTypeOf |
const char * |
type | ) |
◆ IsA()
| virtual int vtkPVPlaneCutter::IsA |
const char * |
type | ) |
◆ SafeDownCast()
◆ PrintSelf()
| void vtkPVPlaneCutter::PrintSelf |
ostream & |
os, |
vtkIndent |
indent |
◆ New()
◆ ProcessRequest()
◆ GetDual()
| virtual bool vtkPVPlaneCutter::GetDual |
If set to true, the dual grid is used for cutting.
Default is false.
Note: Only used for cutting hyper tree grids.
◆ SetDual()
| virtual void vtkPVPlaneCutter::SetDual |
bool |
◆ SetLevelOfResolution()
| virtual void vtkPVPlaneCutter::SetLevelOfResolution |
int |
Sets the level of resolution.
Default is 0.
Note: Only used for cutting overlapping AMR.
◆ GetLevelOfResolution()
| virtual int vtkPVPlaneCutter::GetLevelOfResolution |
Default is 0.
◆ SetUseNativeCutter()
| virtual void vtkPVPlaneCutter::SetUseNativeCutter |
bool |
Sets if plane cutter is used instead of the specialized AMR cutter.
Default is true.
◆ GetUseNativeCutter()
| virtual bool vtkPVPlaneCutter::GetUseNativeCutter |
Default is true.
◆ UseNativeCutterOn()
| virtual void vtkPVPlaneCutter::UseNativeCutterOn |
Default is true.
◆ UseNativeCutterOff()
| virtual void vtkPVPlaneCutter::UseNativeCutterOff |
Default is true.
◆ RequestData()
◆ RequestDataObject()
◆ FillInputPortInformation()
◆ FillOutputPortInformation()
◆ Dual
| bool vtkPVPlaneCutter::Dual = false |
◆ LevelOfResolution
| int vtkPVPlaneCutter::LevelOfResolution = 0 |
◆ UseNativeCutter
| bool vtkPVPlaneCutter::UseNativeCutter = true |
◆ AMRPlaneCutter
◆ AMRAxisAlignedPlaneCutter
◆ HTGPlaneCutter
| vtkNew<vtkHyperTreeGridPlaneCutter> vtkPVPlaneCutter::HTGPlaneCutter |
◆ HTGAxisAlignedPlaneCutter
