| virtual int | GetMergeStrategy () |
| | MergeStrategy indicates the merging strategy used for merging the tables. More...
| virtual void | SetMergeStrategy (int) |
| vtkDataObjectAlgorithm * | NewInstance () const |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPVMergeTablesComposite () |
| | ~vtkPVMergeTablesComposite () override |
| int | RequestDataObject (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| | vtkDataObjectAlgorithm () |
| | ~vtkDataObjectAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
used to merge rows in tables from composite datasets.
This filter operates on composite datasets and simply combines tables by merging columns. The output will have the intersection of all columns from all tables that have at least one row.
The merging behavior is controlled by the MergeStrategy property:
- ALL: All tables from all leaf nodes across all inputs are merged into a composite dataset with a single vtkTable
- LEAVES: Tables are merged per corresponding leaf node, preserving the composite structure.
This assumes that when using LEAVES strategy, all inputs have the same composite structure. All inputs must be a vtkMultiBlockDataSet/vtkPartitionedDataSetCollection of vtkTables. The output is a vtkMultiBlockDataSet/vtkPartitionedDataSetCollection of vtkTables.
Definition at line 33 of file vtkPVMergeTablesComposite.h.
