| vtkTableAlgorithm * | NewInstance () const |
| vtkTable * | GetOutput () |
| vtkTable * | GetOutput (int index) |
| void | SetInputData (vtkDataObject *obj) |
| void | SetInputData (int index, vtkDataObject *obj) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPVMergeTables () |
| | ~vtkPVMergeTables () override |
| | vtkTableAlgorithm () |
| | ~vtkTableAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
used to merge rows in tables.
Simplified version of vtkMergeTables which simply combines tables merging columns. This assumes that each of the inputs either has exactly identical columns or no columns at all. This filter can handle composite datasets as well. The output is produced by merging corresponding leaf nodes. This assumes that all inputs have the same composite structure. All inputs must either be vtkTable or vtkCompositeDataSet mixing is not allowed. The output is a flattened vtkTable.
- Todo:
- We may want to merge this functionality into vtkMergeTables filter itself.
Definition at line 29 of file vtkPVMergeTables.h.
