| int | AddKeyFrame (vtkPVKeyFrame *keyframe) |
| | Forwarded to the internal vtkPVKeyFrameCueManipulator. More...
| int | GetLastAddedKeyFrameIndex () |
| void | RemoveKeyFrame (vtkPVKeyFrame *) |
| void | RemoveAllKeyFrames () |
| virtual void | SetAnimatedElement (int) |
| | The index of the element of the property this cue animates. More...
| virtual int | GetAnimatedElement () |
| void | SetManipulator (vtkPVCueManipulator *) |
| | Get/Set the manipulator used to compute values for each instance in the animation. More...
| virtual vtkPVCueManipulator * | GetManipulator () |
| virtual void | SetEnabled (int) |
| | Enable/Disable this cue. More...
| virtual int | GetEnabled () |
| virtual void | EnabledOn () |
| virtual void | EnabledOff () |
| virtual void | BeginUpdateAnimationValues ()=0 |
| | Used to update the animated item. More...
| virtual void | SetAnimationValue (int index, double value)=0 |
| virtual void | EndUpdateAnimationValues ()=0 |
| virtual void | SetUseAnimationTime (bool) |
| | When set to true, the manipulator is skipped and the key frame value is set by using the ClockTime directly. More...
| virtual bool | GetUseAnimationTime () |
| void | Initialize () override |
| | Overridden to ignore the calls when this->Enabled == false. More...
| void | Tick (double currenttime, double deltatime, double clocktime) override |
| void | Finalize () override |
| vtkAnimationCue * | NewInstance () const |
| virtual void | SetTimeMode (int mode) |
| virtual int | GetTimeMode () |
| void | SetTimeModeToRelative () |
| void | SetTimeModeToNormalized () |
| virtual void | SetStartTime (double) |
| virtual double | GetStartTime () |
| virtual void | SetEndTime (double) |
| virtual double | GetEndTime () |
| virtual double | GetAnimationTime () |
| virtual double | GetDeltaTime () |
| virtual double | GetClockTime () |
