| void | WidgetInteraction (double eventPos[2]) override |
| | Considering an eventPosition and current interaction state, this method will adjust internal position and shape so the widget behave correctly, ie: resizable, movable, but not going over the edges of the render window. More...
| virtual void | BuildRepresentation () |
| virtual void | SetImage (vtkImageData *img) |
| virtual vtkImageData * | GetImage () |
| virtual void | SetImageProperty (vtkProperty2D *p) |
| virtual vtkProperty2D * | GetImageProperty () |
| virtual void | GetActors2D (vtkPropCollection *pc) |
| virtual void | ReleaseGraphicsResources (vtkWindow *) |
| virtual int | RenderOverlay (vtkViewport *) |
| vtkLogoRepresentation * | NewInstance () const |
| virtual vtkCoordinate * | GetPositionCoordinate () |
| virtual void | SetPosition (float x[2]) |
| virtual void | SetPosition (float x, float y) |
| virtual float * | GetPosition () |
| virtual vtkCoordinate * | GetPosition2Coordinate () |
| virtual void | SetPosition2 (float x[2]) |
| virtual void | SetPosition2 (float x, float y) |
| virtual float * | GetPosition2 () |
| virtual void | SetShowBorder (int border) |
| virtual int | GetShowBorderMinValue () |
| virtual int | GetShowBorderMaxValue () |
| virtual int | GetShowBorder () |
| void | SetShowBorderToOff () |
| void | SetShowBorderToOn () |
| void | SetShowBorderToActive () |
| virtual void | SetShowVerticalBorder (int) |
| virtual int | GetShowVerticalBorder () |
| virtual void | SetShowHorizontalBorder (int) |
| virtual int | GetShowHorizontalBorder () |
| virtual vtkProperty2D * | GetBorderProperty () |
| virtual void | SetProportionalResize (int) |
| virtual int | GetProportionalResize () |
| virtual void | ProportionalResizeOn () |
| virtual void | ProportionalResizeOff () |
| virtual void | SetMinimumSize (int, int) |
| void | SetMinimumSize (int[2]) |
| virtual int * | GetMinimumSize () |
| virtual void | GetMinimumSize (int &, int &) |
| virtual void | GetMinimumSize (int[2]) |
| virtual void | SetMaximumSize (int, int) |
| void | SetMaximumSize (int[2]) |
| virtual int * | GetMaximumSize () |
| virtual void | GetMaximumSize (int &, int &) |
| virtual void | GetMaximumSize (int[2]) |
| virtual void | SetTolerance (int) |
| virtual int | GetTolerance () |
| virtual double * | GetSelectionPoint () |
| virtual void | GetSelectionPoint (double data[2]) |
| virtual void | SetMoving (int) |
| virtual int | GetMoving () |
| virtual void | MovingOn () |
| virtual void | MovingOff () |
| virtual void | StartWidgetInteraction (double eventPos[2]) |
| virtual void | GetSize (double size[2]) |
| virtual int | ComputeInteractionState (int X, int Y, int modify=0) |
| virtual int | RenderOpaqueGeometry (vtkViewport *) |
| virtual int | RenderTranslucentPolygonalGeometry (vtkViewport *) |
| virtual int | HasTranslucentPolygonalGeometry () |
| vtkBorderRepresentation * | NewInstance () const |
| virtual void | PickingManagedOn () |
| virtual void | PickingManagedOff () |
| virtual void | SetPickingManaged (bool) |
| virtual bool | GetPickingManaged () |
| virtual void | SetRenderer (vtkRenderer *ren) |
| virtual vtkRenderer * | GetRenderer () |
| virtual void | PlaceWidget (double *vtkNotUsed(bounds[6])) |
| virtual void | EndWidgetInteraction (double newEventPos[2]) |
| virtual int | GetInteractionState () |
| virtual void | Highlight (int vtkNotUsed(highlightOn)) |
| virtual void | SetPlaceFactor (double) |
| virtual double | GetPlaceFactor () |
| virtual void | SetHandleSize (double) |
| virtual double | GetHandleSize () |
| virtual int | GetNeedToRender () |
| virtual void | SetNeedToRender (int) |
| virtual void | NeedToRenderOn () |
| virtual void | NeedToRenderOff () |
| virtual double * | GetBounds () |
| virtual void | ShallowCopy (vtkProp *prop) |
| virtual void | GetActors (vtkPropCollection *) |
| virtual void | GetVolumes (vtkPropCollection *) |
| virtual int | RenderOverlay (vtkViewport *vtkNotUsed(viewport)) |
| virtual int | RenderOpaqueGeometry (vtkViewport *vtkNotUsed(viewport)) |
| virtual int | RenderTranslucentPolygonalGeometry (vtkViewport *vtkNotUsed(viewport)) |
| virtual int | RenderVolumetricGeometry (vtkViewport *vtkNotUsed(viewport)) |
| vtkWidgetRepresentation * | NewInstance () const |
| vtkProp * | NewInstance () const |
| virtual void | Pick () |
| virtual bool | HasKeys (vtkInformation *requiredKeys) |
| virtual void | BuildPaths (vtkAssemblyPaths *paths, vtkAssemblyPath *path) |
| virtual void | SetVisibility (int) |
| virtual int | GetVisibility () |
| virtual void | VisibilityOn () |
| virtual void | VisibilityOff () |
| virtual void | SetPickable (int) |
| virtual int | GetPickable () |
| virtual void | PickableOn () |
| virtual void | PickableOff () |
| virtual void | SetDragable (int) |
| virtual int | GetDragable () |
| virtual void | DragableOn () |
| virtual void | DragableOff () |
| virtual vtkMTimeType | GetRedrawMTime () |
| virtual void | SetUseBounds (bool) |
| virtual bool | GetUseBounds () |
| virtual void | UseBoundsOn () |
| virtual void | UseBoundsOff () |
| virtual void | InitPathTraversal () |
| virtual vtkAssemblyPath * | GetNextPath () |
| virtual int | GetNumberOfPaths () |
| virtual void | PokeMatrix (vtkMatrix4x4 *vtkNotUsed(matrix)) |
| virtual vtkMatrix4x4 * | GetMatrix () |
| virtual vtkInformation * | GetPropertyKeys () |
| virtual void | SetPropertyKeys (vtkInformation *keys) |
| virtual int | RenderVolumetricGeometry (vtkViewport *) |
| virtual bool | RenderFilteredOpaqueGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
| virtual bool | RenderFilteredTranslucentPolygonalGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
| virtual bool | RenderFilteredVolumetricGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
| virtual bool | RenderFilteredOverlay (vtkViewport *v, vtkInformation *requiredKeys) |
| virtual double | GetEstimatedRenderTime (vtkViewport *) |
| virtual double | GetEstimatedRenderTime () |
| virtual void | SetEstimatedRenderTime (double t) |
| virtual void | RestoreEstimatedRenderTime () |
| virtual void | AddEstimatedRenderTime (double t, vtkViewport *vtkNotUsed(vp)) |
| virtual void | SetAllocatedRenderTime (double t, vtkViewport *vtkNotUsed(v)) |
| virtual double | GetAllocatedRenderTime () |
| void | SetRenderTimeMultiplier (double t) |
| virtual double | GetRenderTimeMultiplier () |
| virtual bool | GetSupportsSelection () |
| virtual int | GetNumberOfConsumers () |
| void | AddConsumer (vtkObject *c) |
| void | RemoveConsumer (vtkObject *c) |
| vtkObject * | GetConsumer (int i) |
| int | IsConsumer (vtkObject *c) |
A Representation to manipulate an interactive view link widget.
This Representation creates and manages a custom vtkLogoRepresentation which is precented to go over the edge of the viewport
Definition at line 19 of file vtkPVInteractiveViewLinkRepresentation.h.
