| virtual void | SetDimensionality (int) |
| | Get/Set the number of dimensions used to compute the gradient when using SMOOTHED. More...
| virtual int | GetDimensionality () |
| virtual void | SetBoundaryMethod (int) |
| | Get/Set the method used to compute the gradient on the boundaries of a vtkImageData. More...
| virtual int | GetBoundaryMethod () |
| virtual void | SetHTGMode (int) |
| | Get/Set the mode used to compute the gradient on a vtkHyperTreeGrid. More...
| virtual int | GetHTGMode () |
| virtual void | SetHTGExtensiveComputation (bool) |
| | Get/Set the extensiveness mode used to compute the gradient on a vtkHyperTreeGrid. More...
| virtual bool | GetHTGExtensiveComputation () |
| virtual void | HTGExtensiveComputationOn () |
| virtual void | HTGExtensiveComputationOff () |
| vtkGradientFilter * | NewInstance () const |
| virtual void | SetInputScalars (int fieldAssociation, const char *name) |
| virtual void | SetInputScalars (int fieldAssociation, int fieldAttributeType) |
| virtual char * | GetResultArrayName () |
| virtual void | SetResultArrayName (const char *) |
| virtual char * | GetDivergenceArrayName () |
| virtual void | SetDivergenceArrayName (const char *) |
| virtual char * | GetVorticityArrayName () |
| virtual void | SetVorticityArrayName (const char *) |
| virtual char * | GetQCriterionArrayName () |
| virtual void | SetQCriterionArrayName (const char *) |
| virtual int | GetFasterApproximation () |
| virtual void | SetFasterApproximation (int) |
| virtual void | FasterApproximationOn () |
| virtual void | FasterApproximationOff () |
| virtual void | SetComputeGradient (int) |
| virtual int | GetComputeGradient () |
| virtual void | ComputeGradientOn () |
| virtual void | ComputeGradientOff () |
| virtual void | SetComputeDivergence (int) |
| virtual int | GetComputeDivergence () |
| virtual void | ComputeDivergenceOn () |
| virtual void | ComputeDivergenceOff () |
| virtual void | SetComputeVorticity (int) |
| virtual int | GetComputeVorticity () |
| virtual void | ComputeVorticityOn () |
| virtual void | ComputeVorticityOff () |
| virtual void | SetComputeQCriterion (int) |
| virtual int | GetComputeQCriterion () |
| virtual void | ComputeQCriterionOn () |
| virtual void | ComputeQCriterionOff () |
| vtkDataSetAlgorithm * | NewInstance () const |
| vtkDataSet * | GetOutput () |
| vtkDataSet * | GetOutput (int) |
| void | SetInputData (vtkDataSet *) |
| void | SetInputData (int, vtkDataSet *) |
| void | AddInputData (vtkDataSet *) |
| void | AddInputData (int, vtkDataSet *) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPVGradientFilter ()=default |
| | ~vtkPVGradientFilter () override=default |
| int | FillOutputPortInformation (int port, vtkInformation *info) override |
| int | RequestDataObject (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| | vtkGradientFilter () |
| | ~vtkGradientFilter () |
| virtual int | ComputeUnstructuredGridGradient (vtkDataArray *Array, int fieldAssociation, vtkDataSet *input, bool computeVorticity, bool computeQCriterion, bool computeDivergence, vtkDataSet *output) |
| virtual int | ComputeRegularGridGradient (vtkDataArray *Array, int fieldAssociation, bool computeVorticity, bool computeQCriterion, bool computeDivergence, vtkDataSet *output) |
| | vtkDataSetAlgorithm () |
| | ~vtkDataSetAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Filter to unify gradient implementations for different types.
This is a subclass of vtkGradientFilter that allows to apply gradient filters to different structure types through a unique filter. In practice, vtkGradientFilter can be applied to any vtkDataSet. For unstructured grids, the gradient is computed using the cell derivatives, while for structured grids, central differencing is used, except on the boundaries of the dataset where forward and backward differencing is used for the boundary elements. For vtkImageData, it is possible to use the vtkImageGradient implementation. Note that vtkImageGradient always uses central differencing by duplicating the boundary values, which has a smoothing effect. This can be done by setting the boundary handling method to 'SMOOTHED'.
Definition at line 26 of file vtkPVGradientFilter.h.
