| virtual void | SetVectorScaleMode (int) |
| | Get/set the vector scaling mode. More...
| virtual int | GetVectorScaleMode () |
| vtkMTimeType | GetMTime () override |
| | Overridden to include SourceTransform's MTime. More...
| virtual void | SetScaleFactor (double) |
| | Set/get scale factor used to change the size of glyphs. More...
| virtual double | GetScaleFactor () |
| int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| | Overridden to create output data of appropriate type. More...
| void | SetSourceConnection (int id, vtkAlgorithmOutput *algOutput) |
| | Specify a source object at a specified table location. More...
| void | SetSourceConnection (vtkAlgorithmOutput *algOutput) |
| void | SetController (vtkMultiProcessController *) |
| | Get/Set the vtkMultiProcessController to use for parallel processing. More...
| virtual vtkMultiProcessController * | GetController () |
| void | SetSourceTransform (vtkTransform *) |
| | When set, this is use to transform the source polydata before using it to generate the glyph. More...
| virtual vtkTransform * | GetSourceTransform () |
| virtual void | SetOutputPointsPrecision (int) |
| | Set/get the desired precision for the output types. More...
| virtual int | GetOutputPointsPrecision () |
| virtual void | SetGlyphMode (int) |
| | Set/Get the mode at which glyphs will be generated. More...
| virtual int | GetGlyphMode () |
| virtual void | SetStride (int) |
| | Set/Get the stride at which to glyph the dataset. More...
| virtual int | GetStride () |
| virtual void | SetSeed (int) |
| | Set/Get Seed used for generating a spatially uniform distribution. More...
| virtual int | GetSeed () |
| virtual void | SetMaximumNumberOfSamplePoints (int) |
| | Set/Get maximum number of sample points to use to sample the space when GlyphMode is set to SPATIALLY_UNIFORM_*. More...
| virtual int | GetMaximumNumberOfSamplePoints () |
| vtkPolyDataAlgorithm * | NewInstance () const |
| vtkPolyData * | GetPolyDataInput (int port) |
| vtkPolyData * | GetOutput () |
| vtkPolyData * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPVGlyphFilter () |
| | ~vtkPVGlyphFilter () override |
| int | RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| int | FillInputPortInformation (int, vtkInformation *) override |
| int | FillOutputPortInformation (int, vtkInformation *) override |
| virtual int | IsPointVisible (unsigned int index, vtkDataSet *ds, vtkIdType ptId, bool cellCenters) |
| | Returns 1 if point is to be glyphed, otherwise returns 0. More...
| bool | IsInputArrayToProcessValid (vtkDataSet *input) |
| | Returns true if input Scalars and Vectors are compatible, otherwise returns 0. More...
| vtkPolyData * | GetSource (int idx, vtkInformationVector *sourceInfo) |
| | Get the glyph source. More...
| bool | UseCellCenters (vtkDataSet *input) |
| | Returns true if input Scalars and Vectors are cell attributes, otherwise returns 0. More...
| bool | NeedsScalars () |
| | Returns true if input scalars are used for glyphing. More...
| bool | NeedsVectors () |
| | Returns true if input vectors are used for glyphing. More...
| virtual bool | Execute (unsigned int index, vtkDataSet *input, vtkInformationVector *sourceVector, vtkPolyData *output) |
| | Method called in RequestData() to do the actual data processing. More...
| virtual bool | Execute (unsigned int index, vtkDataSet *input, vtkInformationVector *sourceVector, vtkPolyData *output, vtkDataArray *inSScalars, vtkDataArray *inVectors, bool cellCenters=false) |
| | vtkPolyDataAlgorithm () |
| | ~vtkPolyDataAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
extended API for vtkGlyph3D for better control over glyph placement.
vtkPVGlyphFilter extends vtkGlyph3D for adding control over which points are glyphed using GlyphMode. Three modes are now provided:
- ALL_POINTS: all points in the input dataset are glyphed. This same as using vtkGlyph3D directly.
- EVERY_NTH_POINT: every n-th point in the input dataset when iterated through the input points sequentially is glyphed. For composite datasets, the counter resets every on block. In parallel, independent counter is used on each rank. Use
Stride to control now may points to skip.
- SPATIALLY_UNIFORM_DISTRIBUTION: points close to a randomly sampled spatial distribution of points are glyphed.
Seed controls the seed point for the random number generator (vtkMinimalStandardRandomSequence). MaximumNumberOfSamplePoints can be used to limit the number of sample points used for random sampling. This does not equal the number of points actually glyphed, since that depends on several factors. In parallel, this filter ensures that spatial bounds are collected across all ranks for generating identical sample points.
- SPATIALLY_UNIFORM_INVERSE_TRANSFORM_SAMPLING_SURFACE: points randomly sampled via an inverse transform on surface area of each cell. When used with a volume dataset, the surface mesh is extracted and used for the sampling.
Seed controls the seed point for the random number generator. MaximumNumberOfSamplePoints limits the number of sample points used for random sampling. The number of glyphs produced can be smaller since the sampling depends on several factors. In parallel and with composite dataset, this filter ensures that each piece samples only a representative number of points. Note that the mesh will be triangulated first.
- SPATIALLY_UNIFORM_INVERSE_TRANSFORM_SAMPLING_VOLUME: points randomly sampled via an inverse transform on the volume of each cell. Only 3D cells will be considered.
Seed controls the seed point for the random number generator. MaximumNumberOfSamplePoints limits the number of sample points used for random sampling. The number of glyphs produced can be smaller since the sampling depends on several factors. In parallel and with composite dataset, this filter ensures that each piece samples only a representative number of points. Note that the grid will be tetrahedralized first.
Definition at line 56 of file vtkPVGlyphFilter.h.
