| virtual void | SetController (vtkMultiProcessController *) |
| | Get/Set the multiprocess controller. More...
| virtual vtkMultiProcessController * | GetController () |
| virtual void | SetComponent0 (int) |
| | Set/Get the components of interest from the two arrays. More...
| virtual int | GetComponent0 () |
| virtual void | SetComponent1 (int) |
| virtual int | GetComponent1 () |
| void | SetComponent (int id, int val) |
| int | GetComponent (int id) |
| virtual void | SetNumberOfBins (int, int) |
| | Set/get the number of bins to be used per dimension (x,y) More...
| void | SetNumberOfBins (int [2]) |
| virtual int * | GetNumberOfBins () |
| virtual void | GetNumberOfBins (int &, int &) |
| virtual void | GetNumberOfBins (int [2]) |
| virtual void | SetCustomBinRanges0 (double, double) |
| | Set/Get whether to use custom bin ranges. More...
| void | SetCustomBinRanges0 (double [2]) |
| virtual double * | GetCustomBinRanges0 () |
| virtual void | GetCustomBinRanges0 (double &, double &) |
| virtual void | GetCustomBinRanges0 (double [2]) |
| virtual void | SetCustomBinRanges1 (double, double) |
| void | SetCustomBinRanges1 (double [2]) |
| virtual double * | GetCustomBinRanges1 () |
| virtual void | GetCustomBinRanges1 (double &, double &) |
| virtual void | GetCustomBinRanges1 (double [2]) |
| virtual void | SetUseCustomBinRanges0 (bool) |
| virtual bool | GetUseCustomBinRanges0 () |
| virtual void | UseCustomBinRanges0On () |
| virtual void | UseCustomBinRanges0Off () |
| virtual void | SetUseCustomBinRanges1 (bool) |
| virtual bool | GetUseCustomBinRanges1 () |
| virtual void | UseCustomBinRanges1On () |
| virtual void | UseCustomBinRanges1Off () |
| virtual void | SetUseGradientForYAxis (bool) |
| | Set/Get whether to use the gradient of the scalar array as the Y-axis of the 2D histogram. More...
| virtual bool | GetUseGradientForYAxis () |
| virtual void | UseGradientForYAxisOn () |
| virtual void | UseGradientForYAxisOff () |
| virtual void | SetUseInputRangesForOutputBounds (bool) |
| | Set/Get whether the output image bounds are obtained from input data array ranges. More...
| virtual bool | GetUseInputRangesForOutputBounds () |
| virtual void | UseInputRangesForOutputBoundsOn () |
| virtual void | UseInputRangesForOutputBoundsOff () |
| virtual void | SetOutputOrigin (double, double) |
| | Set/Get the output histogram image origin and spacing. More...
| void | SetOutputOrigin (double [2]) |
| virtual double * | GetOutputOrigin () |
| virtual void | GetOutputOrigin (double &, double &) |
| virtual void | GetOutputOrigin (double [2]) |
| virtual void | SetOutputSpacing (double, double) |
| void | SetOutputSpacing (double [2]) |
| virtual double * | GetOutputSpacing () |
| virtual void | GetOutputSpacing (double &, double &) |
| virtual void | GetOutputSpacing (double [2]) |
| vtkImageAlgorithm * | NewInstance () const |
| vtkImageData * | GetOutput () |
| vtkImageData * | GetOutput (int) |
| vtkImageData * | GetImageDataInput (int port) |
| virtual void | AddInputData (vtkDataObject *) |
| virtual void | AddInputData (int, vtkDataObject *) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPVExtractHistogram2D () |
| | ~vtkPVExtractHistogram2D () override |
| int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| void | ComputeHistogram2D (vtkImageData *histogram) |
| void | ComputeGradient (vtkDataObject *input) |
| void | InitializeCache () |
| void | GetInputArrays (vtkInformationVector **) |
| void | ComputeVectorMagnitude (vtkDataArray *, vtkDataArray *&) |
| void | ComputeComponentRange () |
| | vtkImageAlgorithm () |
| | ~vtkImageAlgorithm () |
| virtual void | CopyInputArrayAttributesToOutput (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
| virtual void | ExecuteDataWithInformation (vtkDataObject *output, vtkInformation *outInfo) |
| virtual void | ExecuteData (vtkDataObject *output) |
| virtual void | Execute () |
| virtual void | AllocateOutputData (vtkImageData *out, vtkInformation *outInfo, int *uExtent) |
| virtual vtkImageData * | AllocateOutputData (vtkDataObject *out, vtkInformation *outInfo) |
| virtual void | CopyAttributeData (vtkImageData *in, vtkImageData *out, vtkInformationVector **inputVector) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
