vtkPVContourFilter Class Reference
generate isosurfaces/isolines from scalar values More...
#include <vtkPVContourFilter.h>
Inheritance diagram for vtkPVContourFilter:
Collaboration diagram for vtkPVContourFilter:
typedef vtkContourFilter Superclass
- Public Types inherited from vtkContourFilter
typedef vtkPolyDataAlgorithm Superclass
- Public Types inherited from vtkPolyDataAlgorithm
enum  DesiredOutputPrecision
virtual int GetHTGStrategy3D ()
 Get/set the contour strategy to apply in case of a HTG input. More...
virtual void SetHTGStrategy3D (int)
virtual void SetUseImplicitArraysHTG (bool)
 Set/Get wether or not the filter should use implicit arrays to store the output contour values (stored as point data of the output contour). More...
virtual bool GetUseImplicitArraysHTG ()
virtual void UseImplicitArraysHTGOn ()
virtual void UseImplicitArraysHTGOff ()
- Public Member Functions inherited from vtkContourFilter
vtkContourFilter * NewInstance () const
vtkMTimeType GetMTime ()
void CreateDefaultLocator ()
void SetValue (int i, double value)
double GetValue (int i)
double * GetValues ()
void GetValues (double *contourValues)
void SetNumberOfContours (int number)
int GetNumberOfContours ()
void GenerateValues (int numContours, double range[2])
void GenerateValues (int numContours, double rangeStart, double rangeEnd)
virtual void SetComputeNormals (int)
virtual int GetComputeNormals ()
virtual void ComputeNormalsOn ()
virtual void ComputeNormalsOff ()
virtual void SetComputeGradients (int)
virtual int GetComputeGradients ()
virtual void ComputeGradientsOn ()
virtual void ComputeGradientsOff ()
virtual void SetComputeScalars (int)
virtual int GetComputeScalars ()
virtual void ComputeScalarsOn ()
virtual void ComputeScalarsOff ()
virtual void SetUseScalarTree (int)
virtual int GetUseScalarTree ()
virtual void UseScalarTreeOn ()
virtual void UseScalarTreeOff ()
virtual void SetScalarTree (vtkScalarTree *)
virtual vtkScalarTree * GetScalarTree ()
void SetLocator (vtkIncrementalPointLocator *locator)
virtual vtkIncrementalPointLocator * GetLocator ()
void SetArrayComponent (int)
int GetArrayComponent ()
virtual void SetGenerateTriangles (int)
virtual int GetGenerateTriangles ()
virtual void GenerateTrianglesOn ()
virtual void GenerateTrianglesOff ()
void SetOutputPointsPrecision (int precision)
int GetOutputPointsPrecision () const
- Public Member Functions inherited from vtkPolyDataAlgorithm
vtkPolyDataAlgorithm * NewInstance () const
vtkDataObject * GetInput ()
vtkPolyData * GetPolyDataInput (int port)
vtkPolyData * GetOutput ()
vtkPolyData * GetOutput (int)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVContourFilter * SafeDownCast (vtkObject *o)
static vtkPVContourFilter * New ()
- Static Public Member Functions inherited from vtkContourFilter
static vtkContourFilter * SafeDownCast (vtkObjectBase *o)
static vtkContourFilter * New ()
- Static Public Member Functions inherited from vtkPolyDataAlgorithm
static vtkPolyDataAlgorithm * New ()
static vtkPolyDataAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkPVContourFilter ()
 ~vtkPVContourFilter () override
int ContourUsingSuperclass (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector)
 Class superclass request data. More...
void CleanOutputScalars (vtkDataArray *outScalars)
 When ComputeScalars is true, the filter computes scalars for the contours. More...
- Protected Member Functions inherited from vtkContourFilter
 vtkContourFilter ()
 ~vtkContourFilter ()
- Protected Member Functions inherited from vtkPolyDataAlgorithm
 vtkPolyDataAlgorithm ()
 ~vtkPolyDataAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Static Protected Member Functions inherited from vtkContourFilter
static void InternalProgressCallbackFunction (vtkObject *caller, unsigned long eid, void *clientData, void *callData)
- Protected Attributes inherited from vtkContourFilter
vtkContourValues * ContourValues
int ComputeNormals
int ComputeGradients
int ComputeScalars
vtkIncrementalPointLocator * Locator
int UseScalarTree
vtkScalarTree * ScalarTree
int OutputPointsPrecision
int GenerateTriangles
vtkSynchronizedTemplates2D * SynchronizedTemplates2D
vtkSynchronizedTemplates3D * SynchronizedTemplates3D
vtkGridSynchronizedTemplates3D * GridSynchronizedTemplates
vtkRectilinearSynchronizedTemplates * RectilinearSynchronizedTemplates
vtkCallbackCommand * InternalProgressCallbackCommand
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
vtkPVContourFilter is an extension to vtkContourFilter. It adds the ability to generate isosurfaces / isolines for AMR dataset.
vtkPVContourFilter also handles cleaning up interpolation error in the output scalars array when ComputeScalars is set to true. For each requested contour value, the output scalar array may have an error introduced due to interpolation along an edge. This filter fixes that error so that for all points generated from a particular contour value, the scalar array will have exactly the same value.
Warning
Certain flags in vtkAMRDualContour are assumed to be ON.
See also
vtkContourFilter vtkAMRDualContour
Definition at line 33 of file vtkPVContourFilter.h.
Definition at line 36 of file vtkPVContourFilter.h.
◆ vtkPVContourFilter()
vtkPVContourFilter::vtkPVContourFilter ( )
◆ ~vtkPVContourFilter()
vtkPVContourFilter::~vtkPVContourFilter ( )
virtual const char* vtkPVContourFilter::GetClassName ( )
static int vtkPVContourFilter::IsTypeOf ( const char *  type)
virtual int vtkPVContourFilter::IsA ( const char *  type)
Reimplemented from vtkContourFilter.
static vtkPVContourFilter* vtkPVContourFilter::SafeDownCast ( vtkObject *  o)
void vtkPVContourFilter::PrintSelf ( ostream &  os,
static vtkPVContourFilter* vtkPVContourFilter::New ( )
◆ GetHTGStrategy3D()
virtual int vtkPVContourFilter::GetHTGStrategy3D ( )
By default, the strategy is vtkHyperTreeGridContour::USE_VOXELS. This method is time-efficient but can lead to bad results in the 3D case, where generated dual cells can be concave. vtkHyperTreeGridContour::USE_DECOMPOSED_POLYHEDRA allows better results in such cases (3D HTGs only). It takes advantage of the vtkPolyhedronUtilities::Decompose method to generate better contours. The dowside is that this method is much slower than vtkHyperTreeGridContour::USE_VOXELS.
Attention
This option only concerns HTG inputs.
◆ SetHTGStrategy3D()
virtual void vtkPVContourFilter::SetHTGStrategy3D ( int  )
Attention
◆ SetUseImplicitArraysHTG()
virtual void vtkPVContourFilter::SetUseImplicitArraysHTG ( bool  )
Since these values are the same fo each isosurface, some memory can be saved by storing each value only once unsing an indexed array.
Attention
This option have no effect if there is more than 256 contour values.
◆ GetUseImplicitArraysHTG()
virtual bool vtkPVContourFilter::GetUseImplicitArraysHTG ( )
Attention
◆ UseImplicitArraysHTGOn()
virtual void vtkPVContourFilter::UseImplicitArraysHTGOn ( )
Attention
◆ UseImplicitArraysHTGOff()
virtual void vtkPVContourFilter::UseImplicitArraysHTGOff ( )
Attention
◆ RequestData()
int vtkPVContourFilter::RequestData ( vtkInformation *  request,
overrideprotectedvirtual
◆ FillInputPortInformation()
int vtkPVContourFilter::FillInputPortInformation ( int  port,
vtkInformation *  info
◆ ContourUsingSuperclass()
int vtkPVContourFilter::ContourUsingSuperclass ( vtkInformation *  request,
Also handles iterating over vtkHierarchicalBoxDataSet.
◆ CleanOutputScalars()
void vtkPVContourFilter::CleanOutputScalars ( vtkDataArray *  outScalars)
However, due to interpolation errors, there's a small difference between the requested contour value and the interpolated scalar value that ends up getting computed. That makes it complicated to identify contours for a specific scalar value. This method cleans the output scalars array to exactly match requested values.
